POV-Ray : Newsgroups : povray.general : Fire Textures anyone? Server Time
18 Feb 2025 18:18:01 EST (-0500)
  Fire Textures anyone? (Message 1 to 10 of 15)
Subject: Fire Textures anyone?
Date: 28 Sep 2003 14:51:54
Message: <3f772dca$1@news.povray.org>
Anyone know where to find some good fire textures?
I'm trying to create a torch (kind of like you'd find in a dungeon),
and can't seem to find any good textures to use for the fire.
Also...any tips on animating the fire would be appreciated.
(i.e.  getting the flame to MOVE with each frame)
Subject: Re: Fire Textures anyone?
Date: 28 Sep 2003 16:29:21
Message: <3f7744a1@news.povray.org>
You can try with something like this:
--------8<------------8<------------8<------------8<-----------8<-------
// -w300 -h600 +a +kff50 +kc
#include "functions.inc"
camera { right x*30/60 location -z*7.5 look_at 0 angle 35 }
light_source { <10,20,-30>, .5 }
#declare TorchWood =
  texture
  { pigment
    { wood color_map { [0 rgb <.7,.4,.2>][1 rgb <.9,.5,.3>] }
      turbulence .5
    normal
    { wood 1
      turbulence .5
    finish { specular .2 }
    scale <.1,1,.1>
#declare SphericalF = function { pattern { spherical } }
#declare NoiseF =
  function
  { (1-f_noise3d(x*5,y*5,z*5)*.9)*
    (1-f_noise3d(x*15,y*15,z*15)*.4)
#declare Torch =
  union
  { sphere
    { 0,1.2 hollow scale <1,2,1> translate y
      pigment { rgbt 1 }
      interior
      { media
        { emission .5
          density
          { function
            { SphericalF(x,y,z)*
              (NoiseF(x,y-clock*3,z)*(1-clock) +
               NoiseF(x,y-clock*3+3,z)*clock)
            density_map
            { [0 rgb 0]
              [.2 rgb <.8,.4,0>]
              [.21 rgb <1,1,.2>]
              [.5 rgb <1,.9,.8>]
              [1 rgb 1]
        media
        { emission .5
          density
          { function
              (NoiseF(x,y*2-clock*3,z)*(1-clock) +
               NoiseF(x,y*2-clock*3+3,z)*clock)
            density_map
            { [0 rgb 0]
              [1 rgb 1]
          scale <1.2,2,1.2>
          translate y*1.4
      scale <1.5,3,1.5>
      rotate z*-5
      translate <.2,1.2,0>
    cone { -y*4,.15, 0,.25 }
    sphere { 0,.25 }
    texture
    { pigment_pattern
      { gradient y color_map { [0 rgb 0][1 rgb 1] }
        scale 4.25 translate -y*4
      texture_map
      { [.7 TorchWood]
        [.8 pigment { rgb 0 }]
        [.9 pigment { rgb x*.8 } finish { ambient 1 }]
        [1 pigment { rgb <1,.2,.2> } finish { ambient 1 }]
object { Torch translate -y*3 }
Date: 28 Sep 2003 16:37:06
Message: <3f774672@news.povray.org>
Took me WAY too long to figure out what that is...
Man, I must be tired! I'll have to remember that one though...
Date: 28 Sep 2003 16:46:00
Message: <3f774888@news.povray.org>
MUCH appreciated!!!
thanks!
(now if I can just get that into Moray!  hahaha)
news:3f7744a1@news.povray.org...
>   texture
>   { pigment
>       turbulence .5
>     normal
>     { wood 1
>       turbulence .5
>     scale <.1,1,.1>
> #declare NoiseF =
>   function
> #declare Torch =
>   union
>   { sphere
>       pigment { rgbt 1 }
>       interior
>       { media
>         { emission .5
>           density
>           { function
>             density_map
>             { [0 rgb 0]
>               [.2 rgb <.8,.4,0>]
>               [.21 rgb <1,1,.2>]
>               [.5 rgb <1,.9,.8>]
>               [1 rgb 1]
>         media
>         { emission .5
>           density
>           { function
>             density_map
>             { [0 rgb 0]
>               [1 rgb 1]
>           scale <1.2,2,1.2>
>           translate y*1.4
>       scale <1.5,3,1.5>
>       rotate z*-5
>     sphere { 0,.25 }
>     texture
>     { pigment_pattern
>       texture_map
>       { [.7 TorchWood]
Date: 28 Sep 2003 17:01:28
Message: <3f774c28@news.povray.org>
Okay.....maybe this is a different kind of question.
I took this texture definition, pretty much created the same thing
in Moray.  When I preview the texture, it looks fine.
But when I actually assign it to a sphere, or cone, or something,
it doesn't show up at all.
Any clues?
>   texture
>   { pigment
>       turbulence .5
>     normal
>     { wood 1
>       turbulence .5
>     scale <.1,1,.1>
> #declare NoiseF =
>   function
> #declare Torch =
>   union
>   { sphere
>       pigment { rgbt 1 }
>       interior
>       { media
>         { emission .5
>           density
>           { function
>             density_map
>             { [0 rgb 0]
>               [.2 rgb <.8,.4,0>]
>               [.21 rgb <1,1,.2>]
>               [.5 rgb <1,.9,.8>]
>               [1 rgb 1]
>         media
>         { emission .5
>           density
>           { function
>             density_map
>             { [0 rgb 0]
>               [1 rgb 1]
>           scale <1.2,2,1.2>
>           translate y*1.4
>       scale <1.5,3,1.5>
>       rotate z*-5
>     sphere { 0,.25 }
>     texture
>     { pigment_pattern
>       texture_map
>       { [.7 TorchWood]
Date: 28 Sep 2003 17:22:36
Message: <3f77511c@news.povray.org>
  The fire (and the smoke) is not a texture but a media which is defined
in the inside of the sphere (the texture in my code is just the wooden
texture of the torch).
  That is, you can't use it as texture but you have to use it as media
inside a hollow sphere, as in my code.
  Btw, the "smoke" is actually not smoke, but some light-emitting media.
You might need to change it to absorbing media or remove it completely.
Date: 29 Sep 2003 11:37:52
Message: <3f7851d0$1@news.povray.org>
3f774888@news.povray.org...
> MUCH appreciated!!!
> thanks!
There is Luis's "InsertCode" pluggin which allows you to insert any POV code
into a Moray scene
http://lightning.generator.tuxfamily.org/modules.php3?op=modload&name=Moray_
plugins&file=index
And I don't know if it works in Moray 3.3 or if it is a 3.5 feature but in
the material editor
create a new material, delete texture, select material, right click you can
find a direct code option
then type your code or right click in code window and paste formerly copied
code
HTH
Marc
Date: 29 Sep 2003 11:40:28
Message: <3f78526c@news.povray.org>
3f77511c@news.povray.org...
Yes, as wrote Warp, the key word is "hollow"
in the modify tab of your sphere, check the hollow checkbox
Marc
Date: 29 Sep 2003 11:56:11
Message: <4glgnvon1e6nbndomtr8qr8i558b76r089@4ax.com>
On Mon, 29 Sep 2003 17:39:18 +0200, "Marc Jacquier" <jac### [at] wanadoofr>
>the material editor
Ver 3.5 :-{
Regards
Date: 29 Sep 2003 13:09:49
Message: <3f78675d@news.povray.org>
that's EXACTLY what I am looking for!  Thanks a BUNCH!
"Marc Jacquier" <jac### [at] wanadoofr> wrote in message
news:3f7851d0$1@news.povray.org...
> > MUCH appreciated!!!
> > thanks!
code
> into a Moray scene
> plugins&file=index
> the material editor
can
copied
> code
> HTH
> Marc
