POV-Ray : Newsgroups : povray.general : mesh2 to mesh Server Time
12 Jul 2026 08:29:45 EDT (-0400)
  mesh2 to mesh (Message 1 to 10 of 14)
Subject: mesh2 to mesh
Date: 22 Sep 2003 11:54:12
Message: <3f6b171e.2001613@localhost>
Greetings all
	I used Wings3d to make some objects for pov-ray.  I
imported the objects without mishap.  The objects had
extra information that I did not want, such as:
 1) a normal vector for each vertex
 2) a texture index for each triangle  (this is kind of
    annoying because I can't then apply a texture to
    occurances of the mesh later on)
	What I would like to do is strip off the normal &
texture information and also convert the mesh2 object to a
regular mesh object.  Does anyone know of a program or a
.pov script that will do this?
	Thanks (in advance).
Pete
Subject: Re: mesh2 to mesh
Date: 22 Sep 2003 23:58:29
Message: <3f6fc4e5$1@news.povray.org>
No direct answers here, but some suggestions...
Perhaps you can just delete the entire normal_vectors and normal_indices
blocks? If there are certain edges that you wanted to remain "hard", that
can be set in wings itself. I'm not sure exactly what you don't like about
having all of the normal vectors.
I've also found this feature annoying. To fix it, I select the face_indices
block, and do a search-and-replace, replacing ">,0," with ">,". This removes
all of the texture indices, except maybe the very last one.
Why do you prefer mesh over mesh2? They both contain the same data, but mesh
is (*much*) slower to parse.
 - Slime
 [ http://www.slimeland.com/ ]
Date: 23 Sep 2003 10:55:18
Message: <3f705ed6@news.povray.org>
  Have you actually measured the parsing speed difference?
  I haven't and I would be interested in knowing some percentages...
Date: 23 Sep 2003 11:30:46
Message: <Xns93FFB226167D6seed7@netplex.aussie.org>
I have, but don't remeber the exact difference, but mesh2 is indeed
faster. But, there is one tricky thing, I also compared a completely non-
optimised mesh2 with a maximal optimised mesh2. With optimised I mean have
aan as small as possible amount of vertices. The more optimised the slower
the parsing and the more it approached the speed of mesh.
Ingo
Date: 23 Sep 2003 13:40:24
Message: <3f708588$1@news.povray.org>
Not with the same mesh. However, I commonly use mesh2's, and face parsing
speeds of maybe about 5-10 seconds (long enough to make me a tiny bit
annoyed just as the parsing finished). Recently, I had to use the original
mesh format for a model with a similar amount of detail (similar number of
triangles). I could go to the bathroom and return well before the parsing
had finished. I ended up making a low-res version of it for testing
purposes, which would take a reasonable length of time (5-10 seconds), using
the other version for only overnight renders.
In any case, the difference is large enough that it's worth caring about.
Sorry I can't give any solid numbers.
 - Slime
Date: 23 Sep 2003 17:00:10
Message: <wtLQlAAiMLc$EwQu@econym.demon.co.uk>
Here's the results of a quick test that I ran. I took an OBJ file and ran it through a
convertor that can output both mesh and mesh2 formats.
The OBJ file is 16.7Mb, and has 99213 vertices and 170376 faces.
The Mesh2 parsed in 45% of the time and used 72% of the memory. The Mesh1 is shown as
having 86 frame level objects because there's a separate mesh1 object for each part
that
has a different texture.
Scene contains 86 frame level objects; 0 infinite.
Statistics for C:\My Documents\Poser\MyStuff\Spacegirl\AlienM1.pov, Resolution 640 x
480
Pixels:          307840   Samples:          363544   Smpls/Pxl: 1.18
Rays:            363544   Saved:                 0   Max Level: 1/5
Ray->Shape Intersection          Tests       Succeeded  Percentage
Mesh                            387596          105567     27.24
Bounding Box                  11443310         3850760     33.65
Light Buffer                   1512203          649452     42.95
Vista Buffer                   1346432          769933     57.18
Calls to Noise:                  0   Calls to DNoise:             10
Shadow Ray Tests:           132628   Succeeded:                30319
Smallest Alloc:                 25 bytes   Largest:          1179672
Peak memory used:         46350651 bytes
Time For Parse:    0 hours  0 minutes  49.0 seconds (49 seconds)
Time For Trace:    0 hours  0 minutes   6.0 seconds (6 seconds)
    Total Time:    0 hours  0 minutes  55.0 seconds (55 seconds)
POV-Ray finished
Scene contains 1 frame level objects; 0 infinite.
480
Pixels:          307840   Samples:          363912   Smpls/Pxl: 1.18
Rays:            363912   Saved:                 0   Max Level: 1/5
Mesh                            445143           85352     19.17
Bounding Box                  14542692         4389902     30.19
Shadow Ray Tests:            81231   Succeeded:                31723
Smallest Alloc:                 25 bytes   Largest:         12267096
Peak memory used:         33609623 bytes
Time For Parse:    0 hours  0 minutes  22.0 seconds (22 seconds)
    Total Time:    0 hours  0 minutes  28.0 seconds (28 seconds)
POV-Ray finished
Mike Williams
Gentleman of Leisure
Date: 24 Sep 2003 15:42:05
Message: <cjameshuff-142DD2.15401424092003@netplex.aussie.org>
In article <Xns### [at] netplexaussieorg>,
> faster.
The exact difference will depend on the mesh. The more vertices shared
among multiple triangles, the better.
I can't think of anything that would cause this. With the same number of
triangles, fewer vertices should be better...duplicates waste space and
need more computations to remove.
http://tag.povray.org/
Date: 24 Sep 2003 16:10:15
Message: <Xns9400E188D7A46seed7@netplex.aussie.org>
in news:cja### [at] netplexaussieorg Christopher
What if POV-Ray internally expands the mesh2? If it does, that would take
some parsing time.
Ingo
Date: 24 Sep 2003 19:22:54
Message: <3f72274e@news.povray.org>
> some parsing time.
  Expands to what?
Date: 24 Sep 2003 19:57:59
Message: <3f7224e9.30888918@localhost>
On Mon, 22 Sep 2003 23:58:21 -0400, "Slime" <fak### [at] emailaddress>
I make "greebly"[1] angular linear shapes.  The normals make
everything kind of, umm, plush and rounded ... sort of
melted.  It looks really bad.
This is a very good idea.  Thank you!
The mesh object is much better for hand text editing.
It's hard for me to keep track of points while
editing a mesh2 object.
> - Slime
[1] Example of "greebles": hull plating of the
    Millenium Falcon
