POV-Ray : Newsgroups : povray.general : Patch idea Server Time
17 Aug 2025 03:32:09 EDT (-0400)
  Patch idea (Message 1 to 9 of 9)
Subject: Patch idea
Date: 26 Aug 2003 00:40:52
Message: <3f4ae4d4$1@news.povray.org>
For anyone who plays with the povray source:
I have been toying with an idea. All objects in real life have a thickness
to them. The metal of a car is thick enough that we can see it rounded at
the edges. The idea is to treat triangles as though they have a thickness.
Rather than the ray calculated to strike the triangle it is calculated at a
point near the triangle. I was kind of thanking that this is how it worked
anyway. The ray is incremented at a constant value. The triangle strike
point might just lay between he ray steps. I would be guessing but is it not
already calculated on the assumption of when it got with in a step of the
triangle. Am I wrong here? In any case the idea that came out of my feeble
try at understanding retracing was to make the triangle thick some how. The
thickness could be a setting with in the triangle command. The edge could be
calculated by blending from a norm parallel to the triangle and the norm of
the triangle. I know I am talking as if it is simple but I do understand the
programming might be complicated.
Any one interested? If you are take it and run. I will be glad to use it.
Mike Williams
IBO#770070
www.quixtar.com
www.espring.com
www.nutrilite.com
www.blionline.com
Subject: Re: Patch idea
Date: 26 Aug 2003 03:40:33
Message: <3f4b0ef1@news.povray.org>
Sounds interesting but what would you use it for? Meshes can have a well
defined interior if there are triangles "on both sides", so to say.
Hugo
Date: 26 Aug 2003 06:27:54
Message: <tjcmkvk7j6jg2c3nqhc3fi9lm2pvb5roc7@4ax.com>
On Mon, 25 Aug 2003 23:44:57 -0500, "Micheal \(Mike\) Williams"
Such patch exist as internal function and is included in MegaPOV 1.0. It is
also available without patching as written in SDL function within IsoCSG
library. I made with it several meshes like f_teapot, see:
http://news.povray.org/povray.binaries.images/29800/. See:
http://abx.art.pl/pov/patches/f_triangle.php . Every optimization with faster
calculations is welcome.
ABX
Date: 26 Aug 2003 07:19:11
Message: <3f4b422f@news.povray.org>
  Why? What would be the advantage of this?
  No, in raytracing rays are not incremented by steps (that would be
awfully slow anyways).
  The intersection of a ray with a surface is calculated mathematically.
For example, when you want to get the intersection of a ray and a sphere
you take the function of a line representing the ray and the function
of the spherical surface, make them equal and solve where they get the
same value. See http://povray.org/documentation/view/116/ for an
example implementation of this.
Date: 26 Aug 2003 07:20:20
Message: <3f4b4274@news.povray.org>
> library.
  I don't understand how creating an isosurface from a mesh adds thickness
to the triangles.
Date: 26 Aug 2003 08:02:55
Message: <1cimkvcsi4j1006e556tnjevf2s6ups42f@4ax.com>
> to the triangles.
Tenth parameter of f_triangle is Thickness.
http://megapov.inetart.net/manual/expressions.html#f_triangle
Translating this f_function into macro with the same input parameters it could
be represented as CSG
#macro CSG_triangle(V1x,V1y,V1z,V2x,V2y,V2z,V3x,V3y,V3z,Thickness)
  #local V1 = <V1x,V1y,V1z>;
  #local V2 = <V2x,V2y,V2z>;
  #local V3 = <V3x,V3y,V3z>;
  #local R = Thickness;
  merge{
    cylinder{ V1 V2 R }
    cylinder{ V2 V3 R }
    cylinder{ V3 V1 R }
    sphere{ V1 R }
    sphere{ V2 R }
    sphere{ V3 R }
    prism{ // created and oriented to fill space between edges
      transform ...
ABX
Date: 26 Aug 2003 22:07:52
Message: <3f4c1278@news.povray.org>
Ok now I see. So it is not really tracing the ray but calculating the angles
and intersection points? I gather that this method is fast but also make the
math for radiosity hard. It also explains why media effects slow rendering
down tremendously.
As for why, To make a paper cup which is rather thin but not flat I would
have to model both the inside and out to create the thickness. That is a lot
of surfaces. And the edges still need to be beveled some how to create the
real highlight on the top rim. If the triangles could be rendered as though
they have a thickness then only the shape of the cup would need to be
rendered. The edges would naturally round over to the inside of the cup. It
would be more like the triangle only describe the center planes of the
object. It would be like using the triangle as a blob component where common
edges of each triangle would not be combined.
One of the hardest things I have tried to model is the smooth edges of
objects. Even a piece of paper bounces light off the very edges to show a
small but visible highlight. Basically I am looking for a short cut to
modeling true rounded edges. The real world does not have true sharp edges.
Now I know some are small enough to never be seen but our brains can and do
pick up these little missing parts. It is why indirect illumination is in
such use now. Trying for the most real looking images.
Take this as an artist trying to create the perfect image. Not as a
programmer and mathematician deriving algorithms.
Again thanks for that very good explanation.
news:3f4b422f@news.povray.org...
thickness
at
thickness.
x]
Warp -
Date: 27 Aug 2003 00:02:11
Message: <cjameshuff-A79A4F.00021127082003@netplex.aussie.org>
In article <3f4c1278@news.povray.org>,
It is tracing the ray by calculating the intersection points. (actually,
you generally compute the intersection distance along the ray, and use
that to compute the point)
What you are thinking of is usually called ray marching. Isosurfaces are
solved this way, which is why they are so slow compared to other shapes.
> I gather that this method is fast but also make the math for radiosity hard.
It does not affect the math for radiosity. Radiosity does not care how
intersections are found.
> It also explains why media effects slow rendering down tremendously.
Yes...media is done by marching the ray through the media, sampling it
at various points along the ray. Solving it analytically would be
faster, but far more limited.
You could simply use a macro that generates multiple triangles, 8 for
each input triangle, arranged to make a triangular prism. This would be
highly inefficient, better to just model the entire surface of the cup.
They are also small enough that the detail will probably never show up
in the rendering. Even a digitized photo would hide a lot of details you
can see with the naked eye.
http://tag.povray.org/
Date: 27 Aug 2003 08:42:25
Message: <3f4ca731@news.povray.org>
  Fog in POV-Ray is calculated analytically (instead of ray-marching).
We all know how more limited fog is compared to media (and how faster as
well)...
