POV-Ray : Newsgroups : povray.general : Direction on a spline Server Time
12 Jul 2026 14:44:01 EDT (-0400)
  Direction on a spline (Message 1 to 7 of 7)
Subject: Direction on a spline
Date: 13 Jul 2003 17:45:36
Message: <3f11d300@news.povray.org>
Ok, this is probably really simple and I'm just overlooking something
obvious....
I'm using a spline to create a path, and placing objects along the path with
a loop. How do I get the object to face the direction of the spline though?
If I use something like;
    object { My_Object translate Path(cntr) }
the object ends up in the right place, but still facing it's original
direction, when I want it to face the direction of the path.  I tried using
VAngleD( current_point, next_point ) to get a rotation angle and simply
rotating the object by that but it didn't seem to do anything.
Can somebody post a simple example of how to do this for a trigonometrically
impaired Pover?
RG
Subject: Re: Direction on a spline
Date: 14 Jul 2003 00:21:57
Message: <3f122fe5$1@news.povray.org>
> obvious....
> impaired Pover?
> RG
You use the Reorient_Trans macro from transforms.inc
Say the front of your object is facing -z
Off the top of my head :
your_object { ...
Reorient (  -z, your_spline ( count ) -  your_spline ( count - 1 ) )
translate your_spline ( count )
You get the idea?
-Jim
Date: 14 Jul 2003 11:28:44
Message: <3f12cc2c@news.povray.org>
"Jim Charter" <jrc### [at] aolcom> wrote in message
news:3f122fe5$1@news.povray.org...
> your_object { ...
> You get the idea?
> -Jim
Or:
#declare Delta = something
Reorient( -z, your_spline ( count + Delta) - your_spline ( count - Delta ) )
and make Delta small compared to the domain of the spline.
Date: 14 Jul 2003 16:40:47
Message: <3f13154f$1@news.povray.org>
Luke <Luk### [at] hotmailcom> wrote in message
news:3f12cc2c@news.povray.org...
Thanks Jim & Luke, for pointing me to that include! Never used it before,
there's some good stuff in there!
Got it working perfectly now!
But not on the first try...  so now have a question...
Your way Jim,
puts me into transforms.inc with this error; "Parse Error: Singular matrix
in MInvers."
Luke's way works fine...
Delta ) )
Reading the docs, both ways appear to be valid, I'm passing 2 vectors either
way.  Why does the first way give an error?
RG
Date: 15 Jul 2003 05:32:02
Message: <3f13ca12@news.povray.org>
"gonzo" <rgo### [at] lansetcom> wrote in message
news:3f13154f$1@news.povray.org...
> Your way Jim,
1 ) )
> in MInvers."
> Delta ) )
either
> RG
I'm always happy to help.
(but I can't help thinking I've not been on these groups long enough, and
might be breaking protocol - perhaps I should post some newbie questions to
redress the balance)
I was doing something like this not long ago and had a few problems myself.
Here's my thoughts:
1) Maybe sometimes you are getting Reorient(-z,<0,0,0>). It makes no sense
to point something in 0 direction, so you should expect an error in this
case. The fix would be something like:
#declare Direction = your_spline ( count ) -  your_spline ( count - 1 );
#if (!VectorIsZero(Direction)) Reorient(-z,Direction) #end
  -(some names have been changed to protect the innocent)
2) I think Reorient(axis1,axis2) can behave a little odd if the two vectors
are parallel. In my tests it parsed no problem, but the objects got twisted
oddly in places.
3) I also had problems with the cubic spline. I didn't really figure this
one out, I just switched to natural splines. They worked.
I should also note that, if your objects are at somewhere like:
Spline(0),Spline(1),Spline(2),...etc Jim's code will work a treat as each
object should point exactly at the next. If they are less evenly
distributed, then you'll have to use something like mine which just points
along the curve, rather than at the next object.
Hope this helps.
Luke.
Date: 15 Jul 2003 16:49:50
Message: <3f1468ee@news.povray.org>
news:3f13ca12@news.povray.org...
> Here's my thoughts:
My spline does pass through <0,0,0> so maybe that's it, but it doesn't have
a warning in the docs for that one as several of the rotation functions and
macros do...  that, and I'm pretty sure that in some of my failed attempts
before I even posted my question here I would have had the same error,
because I tried several variations of my spline positions, but it never
erred...
vectors
twisted
> oddly in places.
Could be that too, since my steps are in between points some of them could
be parallel.
Well, I'm using a cubic spline, but since it's working fine now, I doubt if
that's the reason... When you have trouble with them remember that the first
and last points are directional reference only, & not really part of the
spline.
Hmmm, maybe a little of all of the above. I'll play with something like your
#if statement using different conditions & see if I can isolate it...
But thanks all the same!
RG  -  I'm just one of those types who has to know why something didn't
work...
Date: 16 Jul 2003 17:23:58
Message: <3f15c26e$1@news.povray.org>
Yes, that is what I had in mind.  I guess what I usually do
is Loop to total
	spline ( count / total ) - spline ( (count - 1)/total )
    increment count
