POV-Ray : Newsgroups : povray.general : fade_power in finish Server Time
18 Aug 2025 07:09:01 EDT (-0400)
  fade_power in finish (Message 1 to 5 of 5)
Subject: fade_power in finish
Date: 1 Jun 2003 15:15:34
Message: <3eda50d6@news.povray.org>
I know that from POV 3.5 fade_power, etc. is moved to interior. Yet, the
help file says it should still work in the finish statement, but a warning
will be issued. When I try to run a scene file that works but has fade_power
in the finish statement, it bombs out saying:
"Parse Error: No matching } in 'finish', fade_power found instead"
So, is the help file wrong? I'm using the Windows version of 3.5 with the
IDE.
Jon
Subject: Re: fade_power in finish
Date: 1 Jun 2003 17:49:58
Message: <3eda7506@news.povray.org>
"Jon S. Berndt" <a@b.c> wrote in message news:3eda50d6@news.povray.org...
fade_power
ior was moved. So refraction, which did use fading, might be what you are
thinking of. I took a look at section 6.7.3 Finish and it didn't suggest
fade_power (and fade_distance, fade_color) were also acceptable. If you can
point out a particular document section stating otherwise please let us know
and I'm sure it can be changed. Maybe at least to add a note about that if
nothing says it specifically already.
Bob H.
Date: 1 Jun 2003 22:31:26
Message: <3edab6fe$1@news.povray.org>
"Hughes, B." <omn### [at] charternet> wrote in message
warning
fade_power
can
know
> Bob H.
Bob:
See section 6.6.6 (... ooh, bad number ;-)
"The fade_power and fade_distance keywords were originally specified in
finish but are now properly specified in interior. They are accepted in
finish for backward compatibility and generate a warning message."
I found the above statement to be not true.
Jon
Date: 2 Jun 2003 10:45:07
Message: <Xns938EAAF266F12seed7@povray.org>
I'll have a look and may make some changes,
Thanks,
Ingo
Date: 2 Jun 2003 10:57:37
Message: <3edb65e1@news.povray.org>
"Jon S. Berndt" <a@b.c> wrote in message news:3edab6fe$1@news.povray.org...
Right you are, Jon, so thanks for telling where that incorrect sentence is
at. Just in case it's missed here, I'll let the POV-Team know about it. As
per other such instances, "accepted" should always mean it'll still parse
okay and then render. Maybe someone in the POV-Team can answer which way it
ought to be.
Bob H.
