POV-Ray : Newsgroups : povray.general : Radiometry, photometry, candela, lux, etc... Server Time
19 Nov 2026 16:30:38 EST (-0500)
  Radiometry, photometry, candela, lux, etc... (Message 1 to 16 of 16)
Subject: Radiometry, photometry, candela, lux, etc...
Date: 13 May 2003 18:51:15
Message: <3ec176e3$1@news.povray.org>
Hi, I'm a newbie, and my english is very poor.
Sorry...
Exist a method (or macro, or tutorial, etc...)
to use Povray  for a "technic" simulation of artificial light?
I mean the simulation with the radiometry (or photometric) value of
a lamp (power, light intensity, or Photometric Solid, etc...).
Thanks,
             Manuel
Subject: Re: Radiometry, photometry, candela, lux, etc...
Date: 14 May 2003 01:55:07
Message: <hdm3cv04q470368qmoub0ubg36jphttrhc@4ax.com>
On Wed, 14 May 2003 00:57:06 +0200, "Manuel" <mba### [at] tiscalinetit>
Try Jaime's realistic light simulation macros (lightsys3)at
http://www.ignorancia.org/t_lightsys.php
Hope it helps.
Peter Popov ICQ : 15002700
Date: 14 May 2003 05:12:30
Message: <3ec2087e$1@news.povray.org>
> Hope it helps.
Great!!
Thanks!!!!
Date: 14 May 2003 09:50:05
Message: <web.3ec248f5a14066c9bef0bd7d0@news.povray.org>
Best way to use POV-Ray light simulation is to multiply light source color
with real light luminance (cm/m^2). Then set fade_distance using following
formula:
  sqrt(pi * A) / pi
Real world fade_power is 2. Because POV-Ray doesn't have dynamic range
compression, this isn't enough. I recommend you to define two adjusting
variables "Gamma" and "Max_Luminance" to make dynamic range compression.
Gamma is the gamma used to compress image dynamic range and Max_Luminance
is the luminance (cd/m^2) where pixel luminance at range 0..1 is "1".
Max_Luminance controls image brightness. When using these variables you can
calculate light source color multiplier using formula:
  pow(light_source_luminance / Max_Luminance, Gamma)
And global Fade_Power to *all* light sources by using formula:
  (ln(-exp(-ln(2) * Gamma) + 2) + ln(2) * Gamma) * 2 / ln(3)
To simulate photograph dynamic range compression I think that Gamma should
be ln(0.5)/ln(0.18) because gray card which reflects 18% of light looks
half bright.
Light source color luminance (without multiplier) must be one. Good starting
value for Max_Luminance is 50. Light source colours luminances without
multiplier must be one. Example for white light, light color is <1, 1, 1>.
Because you probably want to make other light sources than omnidircetional,
you need to simulate light distribution using spotlights. If light source
is flat, use spotlight radius -90 falloff 90 tightness 1 for cosine
falloff.
I don't recommend to use Jaime's lightsys because it doesn't use physically
accurate lightning. (Sorry Jaime).
Matti
Date: 14 May 2003 14:40:18
Message: <20030514204026.556cf8b0.jaimevives@ignorancia.org>
On Wed, 14 May 2003 09:47:33 EDT
> physically accurate lightning. (Sorry Jaime).
  Of course! Lightsys doesn't simulates lightning... :)
Jaime Vives Piqueres
Date: 15 May 2003 16:05:26
Message: <3ec3f306@news.povray.org>
Thanks again.
And (excuse my ignorance) about the radiosity?
I must include it for a good simulation?
Ehm...have you a sample scene that I can study?
I'm new to pov 3.5, and I only know roughly the old version...
thx,
          Manuel
"Matti Karnaattu" <nomail@nomail> ha scritto nel messaggio
news:web.3ec248f5a14066c9bef0bd7d0@news.povray.org...
> formula:
>   sqrt(pi * A) / pi
can
> half bright.
starting
omnidircetional,
> falloff.
physically
> Matti
Date: 20 May 2003 12:55:03
Message: <web.3eca5cc0a14066c984d065310@news.povray.org>
Absolutely. Use it with #default { finish { ambient 0 } }
I use these newsgroups from netcafe now, but I can put scene to net some
day.
Matti
Date: 21 May 2003 18:39:57
Message: <3ecc003d$1@news.povray.org>
> day.
Thx,
   I'm waiting...  :-)
Date: 22 May 2003 17:03:30
Message: <3ecd3b22@news.povray.org>
>   sqrt(pi * A) / pi
A is the emitter area, right?
Can you tell me about the origin of this formula?
> half bright.
Ehmm... can you explain more about this?
thx, sorry for boring questions.
         Manuel
Date: 24 May 2003 11:10:02
Message: <web.3ecf8a69a14066c984d065310@news.povray.org>
>>   sqrt(pi * A) / pi
Correct.
I solve it myself and it is based on basic geometry formulas. I also create
Cornell box scene to test it. Instrutions to Cornell Box scene are here:
  http://www.graphics.cornell.edu/online/box/data.html
It works. I can't explain better because my notes and files are home and I
have to use net from cafe until I get own Internet connection.
>> half bright.
Photographers use gray surface which reflects 18% light back to make
adjustments because it looks half bright.
  0.18^x = 0.5
  x = ln(0.5)/ln(0.18)
I'm not sure about this gamma. I'm still looking more information about
simulating camera and human eye dynamic range.
Matti
Date: 24 May 2003 11:59:07
Message: <cjameshuff-A65197.11001424052003@netplex.aussie.org>
In article <web.3ecf8a69a14066c984d065310@news.povray.org>,
>   0.18^x = 0.5
The gamma is an approximation to the non-linear response curve of CRT
phosphors: 50% gray is neither 50% intensity nor 50% apparent intensity.
Gamma currection compensates for this to give a nearly linear response.
(LCD's have an S-shaped curve, probably based on cosine, but modern LCD
displays probably compensate for this electronically.)
I don't know if a logarithmic scale would be useful given the limited
dynamic range of monitors and typical depth resolutions (usually 8 bits
per component, for 255 non-black levels). Also, people who work with
color learn to use linear values, they would have to re-learn everything
to use a logarithmic color space. It isn't more "correct", it is just a
different system.
http://tag.povray.org/
Date: 26 May 2003 07:34:43
Message: <3ed1fbd3@news.povray.org>
create
I want write a GPL python class (mainly to use it in Blender) to
write a Pov code to make a realistic-physical correct light simulation.
Can I use your formula?
Have you a site? Can you explain more?
Can you make a very simple example code?
Best regards,
                  Manuel
Date: 31 May 2003 09:35:01
Message: <web.3ed8af60a14066c984d065310@news.povray.org>
>different system.
It is useful because realistic radiosity requires real luminances.
Matti
Date: 31 May 2003 09:50:01
Message: <web.3ed8b2a1a14066c984d065310@news.povray.org>
Of course. I forgot to say.. fade_distance formula works only with flat
light sources.. For omnidirectional light you should set fade_distace to
light source radius.
No, I dont have site. fade_distance formula is derived from circle area.. I
try to explain fade_power formula and give you example code when I have
more time.
Matti
Date: 31 May 2003 12:23:43
Message: <3ed8d70f@news.povray.org>
> more time.
OK. I'm waiting :-)
thanks
Best Regards,
           Manuel
Date: 30 Jun 2003 05:10:01
Message: <web.3efffd86a14066c9192031960@news.povray.org>
Hi Matti,  I'm a newbie in radiosity so I think my question is a stupid one.
I can't understand what you really mean with "photograph dynamic range".
Is it referred to the challenge of simulating the human eye dinamic exposure
range? Or is it referred only to the photographic devices simulation? Like
film exposure range, diafragm/time exposure calculation?
Thank you in advance.
bye, save
>formula:
>  sqrt(pi * A) / pi
>half bright.
>falloff.
>Matti
