POV-Ray : Newsgroups : povray.general : It's 90% about textures (and finishes) Server Time
12 Jul 2026 23:35:34 EDT (-0400)
  It's 90% about textures (and finishes) (Message 1 to 10 of 17)
Subject: It's 90% about textures (and finishes)
Date: 6 Mar 2003 15:22:22
Message: <3e67adfe$1@news.povray.org>
Just an observation...  (Don't kill me!)
From viewing IRTC images and some WIPs from past and present, it seems like
many of them are very complex images, for which someone probably spent TONS
of time creating.  But the one thing that strikes me so often is that the
textures/finishes are not quite right.
Textures are very hard to get right, I understand.  I spend most of my time
on textures when I create an image, and even so, I would agree that it's
still not perfect.  But often, it appears that the artist spent all of their
time creating the gadgets' shapes, and then simply said "texture {wood_12}",
and that's a shame.
I'm not sure if people simply don't notice, aren't sure what to do about it,
or run out of time, or what.  I feel like we need a phrase similar to,
"Location! Location! Location!" (Textures! Textures! Textures!).  Anyone can
create a box, but creating a box with a 3-layer texture and some sort of
normal plus a great finish can really pull it into reality.  So many images
could become incredible images if people would simply spend more time on the
textures.
I'm not trying to put down anyone's work, but rather I hope that I'm helping
to make everyone's works more impressive.  There is an entire tutorial
section (actually 2) on creating textures + finishes, etc.
Feel free to disagree with my "90%" claim, but I'm just using that to make a
point.  Lighting is a major factor, as well as other things like focal blur,
radiosity, etc., but generally those things don't require tons of time
before getting set.
(I felt this was more of a general topic, rather than simply an IRTC topic,
hence the post here...)
Slash
Subject: Re: It's 90% about textures (and finishes)
Date: 6 Mar 2003 15:35:54
Message: <3e67b12a@news.povray.org>
"Slashdolt" <jer### [at] questsoftwarecom> wrote in message
news:3e67adfe$1@news.povray.org...
<snip>
It's probably true for a large majority of irtc images that textures are the
last thing one works on, and that consequently they will often represent the
weakest link in any image.
I can't honestly see what anyone could do about it. Spend more time on
textures and you get worse modelling, and the cry would be "modelling,
modelling, modelling".
Apart from anything else, when working on the modelling for an image,
textures slow down test renders, yet it's quite hard to judge a texture out
of context.
Date: 6 Mar 2003 16:52:38
Message: <3e67c326@news.povray.org>
> it,
> can create a box, but creating a box with a 3-layer texture and some sort
> of
> images could become incredible images if people would simply spend more
> time on the textures.
In my opinion POV-Ray needs more features regarding textures similar to
other 3D applications like alpha maps, specularity maps (!!) or image based
displacement mapping. The textures in POV-Rays include files are powerfull
but in most cases not very realistic. Or you have not enough control about
them, e.g. if you need rust or specularity only on special areas. In this
cases you actually need an image map so that you can define these areas
exactly.
Andreas
http://www.render-zone.com
Date: 6 Mar 2003 17:32:01
Message: <3e67cc61$1@news.povray.org>
Regarding alpha maps, you can do that with image maps as well as using
transmit and filter components in pigments, if I understand you correctly.
Otherwise, layering textures wouldn't make sense at all.  Maybe I
misunderstood.
Either mlpov or megapov has "finish maps", which I haven't tried yet, but
which sounds intriguing.  I think it's part of mlpov.
As for the texture includes, I generally start using them for test-renders,
and then end up creating my own textures, pigments, finishes, etc., as I
generally dislike the ones in the includes.  (Sorry)
Slash
"Andreas Kreisig" <and### [at] gmxde> wrote in message
news:3e67c326@news.povray.org...
> > it,
sort
> > of
based
> exactly.
> Regards,
> Andreas
Date: 6 Mar 2003 18:01:47
Message: <cjameshuff-5D41BE.18014906032003@netplex.aussie.org>
In article <3e67c326@news.povray.org>,
Alpha maps...I've long wanted transparency separated from color. Making
transparency controllable by a pattern or function would be incredibly
powerful.
Specularity maps: better to make all finish values controllable as I
mentioned for transparency, or add a finish_map feature. I think there
are patches out there for this, I don't know how complete they are or
how well it works.
Displacement mapping: this has been discussed a *lot* on these groups.
It would require automatic tessellation of all objects, and is generally
a huge amount of work before you even get to the displacement features.
I've done a little work on it, so have a few other people.
> The textures in POV-Rays include files are powerfull but in most
Most of them were written long ago, before there was even radiosity. A
new set of includes using macros and the more modern texture features
could be far more powerful and realistic.
> exactly.
This is something you generally need to make custom textures for.
http://tag.povray.org/
Date: 6 Mar 2003 20:08:14
Message: <TwEMgAA0$+Z+EwJk@econym.demon.co.uk>
>powerful.
It's already achievable in POV 3.5. This is a texture I've used for
importing transparency maps from Poser. "transmap.jpg" is used to
control the transparency and "texture.jpg" is used to control the
colour. Obviously, the two image_maps could be replaced by any pattern
or function.
  pigment_pattern {image_map {jpeg "transmap.jpg" interpolate 2}}
  texture_map {
     [0 pigment {rgbt <0,0,0,1>}]
     [1 pigment {image_map {jpeg "texture.jpg" interpolate 2}}]
I guess the same technique could be used to manage specularity mapping,
but I've not tried it.
Mike Williams
Gentleman of Leisure
Date: 6 Mar 2003 22:03:44
Message: <cjameshuff-A715EE.22034706032003@netplex.aussie.org>
In article <TwEMgAA0$+Z+EwJ### [at] econymdemoncouk>,
> or function.
This is linearly blending between a transparent texture and a
non-transparent one, not quite the same thing.
Date: 6 Mar 2003 23:30:12
Message: <web.3e681f1d33329f4baacec0780@news.povray.org>
Andreas Kreisig wrote:
>> it,
>> of
>exactly.
The most disappointing aspect of the IRTC is how so many great images are
let down by plain, or even non-existant, textures. I'm not sure it's a lack
of tools (though I wish I could layer over a patterned texture!).
POV-Ray has a good number of texturing tools, and if you spend enough time
at it you can get wonderful results. But it does take a lot of time (to
learn and to use). POV-Ray could use better starting points than the
terrible include files that often send you in the wrong direction. The IRTC
zip files provide a resource for good textures, though not organized for
quick access.
Also, I think artistic visual ability is required to "see" an object clearly
to know what texturing it needs. Photographic references help, but a simple
change of lighting can make a reference subtly wrong. One of the most
disappointing aspects of textures is how they almost always have to be
massaged for scale, position and lighting, so simply reusing a texture is
almost never good enough.
Date: 6 Mar 2003 23:47:22
Message: <3e68245a@news.povray.org>
Slashdolt's furious key-hammering produced this:
I usually just set up a default, basic white texture (pigment{rgb 1}) and get
the scene modelling done first.
Using the ones in the includes isn't a half bad idea for tests, though.  It
might give a better idea of what the scene's going to look like.
> as I generally dislike the ones in the includes.  (Sorry)
I wouldn't really be sorry about saying that.  The ones in the includes are
pretty old.  Let's just say, the first time I downloaded POV-Ray was in 1995 and
I don't think very many new textures were added since then. :)
/*^*/light_source{100*<-5,2,-5>2}#macro I(i,n)#while(strlen(i)>=n)#local A=asc(
substr(i,n,1));#local a=asc(substr(i,n+1,1));cylinder{<div(A,8)-12,mod(A,8)-4,4
><div(a,8)-12,mod(a,8)-4,4>,0.1pigment{rgb z}}#local n=n+2;#end#end I("ScUe[]"1
/*<*/)I("mkmtlttk"1)//@_$#!,:<"Thhis polysig brought to you by Ian Burgmyer :)"
Date: 6 Mar 2003 23:59:20
Message: <3e682728@news.povray.org>
Slashdolt <jer### [at] questsoftwarecom> wrote in message
like
TONS
time
their
{wood_12}",
> and that's a shame.
I'm a texture collector. Textures can make or break an image.  I usually
work on textures a lot in an image, and I create most of my own from
scratch. The only POV textures I have used 'as is' are some in glass.inc. I
use POVs wood textures, but usually modify them.
All my 3D experience prior to learning POV was in Bryce, so I'm probably
biased, but having a texture editor like Bryce's DTE for POV textures would
be great!  Creating good textures is time consuming even in Bryce, and far
more so in POV.
I can create pigments fairly quickly using Bob's color picker (thanks Bob!),
and I can even get basic finishes fairly quickly, primarily because I've
used Bryce's editor enough to know what I'm looking for as far as diffuse,
specular etc. But fine tuning finishes takes time, and the finer it is
usually the longer it takes to render, so testing starts running into
overtime.
And normals are harder to do, take even longer to test render, only to
discover it wasn't what you thought at all, and you have to start all over.
So far I have not been able to get the kind of detail I want in my POV
textures simply because I don't have the time to spend on them.
Having an editor that lets you do all that in one place, and see what you
are doing while you do it invaluable, especially when time is critical.
RG
