POV-Ray : Newsgroups : povray.general : sphere_sweep woes Server Time
22 Oct 2026 19:12:16 EDT (-0400)
  sphere_sweep woes (Message 1 to 15 of 15)
Subject: sphere_sweep woes
Date: 17 Sep 2002 10:37:55
Message: <3d873e43@news.povray.org>
Hi all,
I'm working on a scene with sphere_sweeps, but it renders unusually slow -
there's only 10 points on a cubic spline with just a pigment and the render
drops to 2000 pps. The sphere_sweep seems to be bound incorrectly as well.
Is there anything I can do to speed things up a little? - I've already
adjusted to tolerance to 0.1.
thanks in advance
jim
ps here's the code (cm and mm are just [arbitrary] definitions of units i.e.
cm = 1, mm = 0.1)
#local N=10;
#local Length = 10*cm;
#local Height = 5*mm;
#local Width = 5*mm;
#local y_period = 4;
#local z_period = 4;
#local R1 = 1*mm;
#local R2 = 0.1*mm;
#local i=-1;
sphere_sweep{
    b_spline
    N+1
    #while(i<N)
        <Length/N*i,Height*sin(y_period*pi*i/N),Width*sin(z_period*pi*i/N)>
R1 + (R2-R1)/N*i
        #local i=i+1;
    pigment{White}
    tolerance 0.1
Subject: Re: sphere_sweep woes
Date: 17 Sep 2002 10:45:25
Message: <htfeousevu87ok20jb9u3mo8d49oh6mbns@4ax.com>
On Tue, 17 Sep 2002 15:36:07 +0100, "James Taylor"
I can't promise anything but
http://news.povray.org/d1venucb9u3r431pj99pritqpbddo2fbcb%404ax.com
http://news.povray.org/povray.unofficial.patches/27251/
ABX
Date: 17 Sep 2002 10:47:03
Message: <3D874172.B15F7F1A@pacbell.net>
James Taylor wrote:
> Hi all,
> drops to 2000 pps.
2000 pps is slow ? I have render running right now at 11 ppm!
Ken Tyler
Date: 17 Sep 2002 10:59:00
Message: <3d874334@news.povray.org>
not normally, but this is a test render with no textures and just 1 object -
I was planning on adding focal blur + media etc
jim
Date: 17 Sep 2002 11:25:20
Message: <3d874960@news.povray.org>
James Taylor <jim### [at] blueyondercouk> wrote in message
news:3d873e43@news.povray.org...
That would render in a few seconds with my Cheap_Sweep macro. It makes a csg
sweep object. It is limited when compared to a genuine sphere_sweep, but it
will very quickly make a curvy line.
http://news.povray.org/povray.binaries.images/23308/
http://news.povray.org/povray.binaries.scene-files/23501/
To be honest, I wouldn't use this macro myself anymore because I pretty much
only code meshes now, but it may be the quickest way to get from a to b for
what you are trying to do.
 -Shay
Date: 17 Sep 2002 14:28:34
Message: <3d877452@news.povray.org>
"Shay" <sah### [at] simcopartscom> wrote
thanks for the links, Shay - I'll take a look
I might even consider thinking about writing a sphere sweep mesh macro,
although I'm not sure that there would be any benefit in most cases.
jim
Date: 17 Sep 2002 15:02:13
Message: <3d877c35$1@news.povray.org>
news:3d877452@news.povray.org...
Too late, you've already done it! <g>
It would certainly be faster in most cases. I like mesh a lot. I am
currently working on an IRTC entry made entirely out of meshes. My memory
might run out before time does, however. I'm already at 100k vertices (no,
not grass or any other clones) and I've just started.
 -Shay
Date: 17 Sep 2002 16:04:02
Message: <3d878ab2$1@news.povray.org>
"Shay" <sah### [at] simcopartscom> wrote in message
news:3d877c35$1@news.povray.org...
do you plan to publish?
in which case it's time to buy more memory ;)
>...however. I'm already at 100k vertices (no,
go on...give us a clue
jim
Date: 17 Sep 2002 16:18:35
Message: <3d878e1b$1@news.povray.org>
news:3d878ab2$1@news.povray.org...
I haven't made anything, I was just kidding about your wierd sentence.
I'll only say that it will most likely be the only "landscape" entry with no
10k clones, no heightfields, and no naked poser chicks.
 -Shay
Date: 17 Sep 2002 16:24:34
Message: <3d878f82$1@news.povray.org>
Shay <sah### [at] simcopartscom> wrote in message
news:3d878e1b$1@news.povray.org...
Whoops...forgot. I did code a mesh spline sweep once, don't have the code
anymore, however.
http://news.povray.org/povray.binaries.images/23424/
 -Shay
Date: 17 Sep 2002 20:38:48
Message: <3D87CB3F.403@enter.net>
I used several sphere_sweeps in a recent IRTC entry, and yes, they
are rather slow to render. They are slow rendering creatures to
begin with but I initially felt there was a problem with
auto-bounding too. After recently reading some past problems others
had, I tried dropping the bounding threshold to 0 (my test cases
were all with one or two sweeps, so double duh to me), and
experienced results comparable to manual bounding of the same
object.
Still, if any given sweep extends across a significant portion of
your image, it'll be quite slow.  It's quite intensive calculating a
sphere swept along a multi-segmented spline. If you can simulate the
same effect by breaking it into multiple smaller sweeps each in its
own section of the image that might help somewhat (untested, but it's
an idea).
There was recently some mention of improved bounding for sphere_sweeps
(the words "heirarchal bounding" caught my attention), but that's an
unofficial patch that's being worked on. For the time being, just be
sure your sweeps are properly bounded and take up a second hobby.
Me, I'm teaching myself matrix math. :)
@C[$F];
The Silver Tome ::  http://www.silvertome.com
"You may sing to my cat if you like..."
Date: 18 Sep 2002 14:01:53
Message: <1fiq1kw.ers1sq1sx9bvkN%jlippert@ubcom.de>
The problem with the current bounding of a sphere_sweep is, as you may
have guessed, that the whole sweep is put into one large bounding box.
In the worst case, if the sweep goes from say <-10, -10, -10> to <10,
10, 10>, this box will cover a unneccessary large volume. Every time the
box get hit, all segments (whose number depends roughly on the number of
spheres in the sphere_sweep description) of the sweep are tested against
the ray, which can be slow for cubic and b-spline sweeps.
The idea behind this is to put each segment of the sweep into its own
bounding box. Much less space wasted, much faster calculations
hopefully. You can have the same effect with manual bounding, but it's
hard to figure out the correct boxes, as you seem to have noticed. :)
That's always good. :) A simple solution for b-splines is to put every
four consecutive spheres of the sweep description into a box. The sweep
can't be outside of this box. Same goes for linear sweep and two
consecutive spheres. Cubic (Catmull-Rom) sweeps are much harder to
track, though.
Jochen Lippert
No smilies were harmed in the making of this message ;)
Date: 18 Sep 2002 20:06:17
Message: <3D89154E.9000701@enter.net>
 > hopefully.
Ah... I see. Yes, this sounds like a sensible approach given the
nature of the object.
 > sweep can't be outside of this box. Same goes for linear sweep and two
 > track, though.
Hmmm... this makes me idly ponder: until such time as there is
heirarchal bounding, perhaps one could use a macro to make
sphere_sweeps. This macro would take an array of control points and
build not one sweep but rather a lot of single segment sphere_sweeps,
duplicating control points at the appropriate places so that the ends
of the each segment smoothly connected to the next. Auto-bounding would
work it's magic on each individual segment instead of the whole group,
and the speed up effect might be comparable (?)
Don't know how much of a difference this would make in practice, but
this is an example...
// A utility macro called in Multisweep (below)
#macro _MultipleRadii(Num,RArray,This)
     #if (Num>1)
         RArray[This]
     #else
         RArray[0]
// SplineType is a string, Nodes and Radii are arrays. Note, if you
// want only a uniform radius, declare one element in the Radii array.
// This would be more convenient that having to type a lot of values
// when you only want one throughout.
// Tolerance and material are a float and declared material as you'd
// expect.
#macro MultiSweep(SplineType,Nodes,Radii,Tolerance,Material)
      #ifndef(STRINGS_INC_TEMP)
          #include "strings.inc"
      #local ThisNode = 0;
      #local NodeCount = dimension_size(Nodes,1);
      #local RadCount = dimension_size(Radii,1);
      #while (ThisNode < NodeCount-3)
          sphere_sweep {
              Parse_String(SplineType)
              #if (strcmp(SplineType,"linear_spline")!=0)
                 4,
              #else
                 2,
              Nodes[ThisNode],
                       _MultipleRadii(RadCount,Radii,ThisNode)
              Nodes[ThisNode+1],
                       _MultipleRadii(RadCount,Radii,ThisNode+1)
                  Nodes[ThisNode+2],
                       _MultipleRadii(RadCount,Radii,ThisNode+2)
                  Nodes[ThisNode+3],
                       _MultipleRadii(RadCount,Radii,ThisNode+3)
              tolerance Tolerance
              material { Material }
          #local ThisNode = ThisNode +1;
#end //Start_MultiSweep
@C[$F];
Date: 19 Sep 2002 15:01:23
Message: <1firz97.1aekpbd1g52pzuN%jlippert@ubcom.de>
Not a bad idea at all. :) One problem might be the overlap between two
adjacent segments of this sphere_sweep-in-parts, but since there is a
similar problem with the implementation as it is now, this may work
quite well. Maybe the partial sweeps should be merged together, though,
or does this affect the bounding in a negative way?
Jochen Lippert
Date: 19 Sep 2002 19:33:59
Message: <3D8A5F3E.90008@enter.net>
> Jochen Lippert
Well, I just tried it out to see. Unions, of course, get split up
unless POV is told otherwise, so the bounding still works the same,
but merge, apparently can't be similarly split. On an aside, this
might at least contribute to the slowness of the merge vs. union.
Of course, this only affects transparency, but still, it limits the
usefulness of the macro sweep technique. It is, however, useful to
demonstrate the value that internal heirarchal bounding would provide.
Here are a few limited statistics all from an array of the same 14
spline points. The equivalent 14 point sweep (not through the macro)
is listed on the right for comparison purposes... This if, of course,
just some quick data on a single sweep (I'll attach the array of points
at the end), but it is promising as far as it goes. All tests on a P4
1.6ghz with 512megs of memory (milage may vary :) )
Notes               With Macro  ...     Whole Sweep
linear_spline         6 seconds         10 seconds
cubic_spline         36 seconds         43 seconds
b_spline             27 seconds         38 seconds
linear as union       6 seconds          n/a
cubic as union       36 seconds          n/a
b_spline as union    27 seconds          n/a
linear as merge**    1 min 6 seconds     n/a
cubic as merge       1 min 53 seconds    n/a
b_spline as merge    1 min 43 seconds    n/a
So, as expected, merge did ruin the speed up, and in fact resulted
in much worse times than just using the whole sweep. Additionally
the ** beside "linear as merge" indicates some curious artifacts which
looked like the nodes between the segements were breaking up (all the
other tests ran fine, and looked largely indistinguishable from the
whole sweep.
Even this brief test shows between a 17% and 40% speed up. I think
it suggests that heirarchal bounding would be a large benefit to the
sphere_sweep object. In most cases the macro provides a temporary
workaround for it, thought it is less convenient to set up, and of
course, won't work properly with transparency. Here are the
camera, lights, and points array used in the test, FWIW. Mutlisweep()
used per my last post, and the whole sweep was just hand written from
the points given.
   location  <      5.318,      -3.000,       5.191>
   sky       <    0.00000,     0.00000,     1.00000>
   up        <        0.0,         0.0,         1.0>
   right     <    1.42078,         0.0,         0.0>
   angle         70.30414    // Vertical      52.728
   look_at   <     -0.041,       0.062,       1.087>
light_source {  <0.0, 0.0, 0.0>  color rgb <1.000, 1.000, 1.000>
   translate  <0.757616, -21.704405, 40.352578>
#declare Nodes =
array[14]
     <-0.464448, -2.841777, 0.275671>,<-1.154055, -1.827648, 0.275671>,
     <-1.913265, -1.005762, 0.525671>,<-2.159817, 0.085617, 0.775671>,
     <-1.827648, 1.154055, 1.025671>,<-1.005762, 1.913265, 1.275671>,
     <0.085617, 2.159817, 1.525671>,<1.154055, 1.827648, 1.775671>,
     <1.913265, 1.005762, 2.025671>,<2.159817, -0.085617, 2.275671>,
     <1.827648, -1.154055, 2.525671>,<1.005762, -1.913265, 2.775671>,
     <-0.085617, -2.159817, 3.025671>,<-1.302571, -2.443773, 3.025671>
#declare Radii = array[1]{ 0.2 } //i.e. used uniform radius
@C[$F];
