POV-Ray : Newsgroups : povray.general : Anti-aliasing option. Server Time
14 Jul 2026 04:30:50 EDT (-0400)
  Anti-aliasing option. (Message 1 to 10 of 14)
Subject: Anti-aliasing option.
Date: 7 Jun 2002 17:59:18
Message: <3d012cb6@news.povray.org>
A number of times I find that I would like certain objects to be
anti-aliased, but not the whole scene, or for some objects to be
anti-aliased at a higher level than the rest of the scene.
What would be the difficulty in programming anti-aliasing regions, such that
any pixel whose ray was shot into the region would be anti-aliased at a
certain level?   I picture syntax such as:
antialias {
  box { <-1,1,1>,<2,4,4> }
  depth 3
  precision .1
This would have the effect of forcing anti-aliasing to higher levels for
those pixels that covered the bounding region (unless AA was shut off
entirely).
This way a finely detailed object would always get the AA it needs to avoid
having parts left out (because a part falls between the rays of neighboring
pixels).
I can see that this would be tricky to implement with sampling method 2.
What think ye?
John
Subject: Re: Anti-aliasing option.
Date: 8 Jun 2002 09:10:52
Message: <3d02025c@news.povray.org>
> that any pixel whose ray was shot into the region would be anti-aliased
> at a certain level?   I picture syntax such as:
> antialias {
>   depth 3
>   precision .1
Technically feasible, I think but I suspect that the edges of the box
would often become visible as the antialiasing of the background would
change as well.
Date: 8 Jun 2002 11:20:14
Message: <3D0220AC.4242468B@hotmail.com>
> > such that any pixel whose ray was shot into the region would be
> > anti-aliased at a certain level?   I picture syntax such as:
> > antialias {
> >   depth 3
> >   precision .1
> change as well.
Well, if increasing the AA of the background changes the way it looks,
then maybe that background should have AA as well.
John
Date: 8 Jun 2002 11:36:07
Message: <3d022467$1@news.povray.org>
Technically a really hard thing to do.
If POV-Ray is going to do this, it should be able to trace the edges of
objects on the screen. Try doing this with isosurfaces ;-)
Apache
POV-Ray Cloth experiments: http://geitenkaas.dns2go.com/experiments/
Email: apa### [at] yahoocom
ICQ: 146690431
Date: 9 Jun 2002 10:32:19
Message: <3d0366f3@news.povray.org>
>> > antialias {
>> >   depth 3
>> >   precision .1
>> change as well.
> Regards,
> John
But it defeats the purpose of localised AA somewhat if you use the same settings
for the background as for your (possibly small) object.
I'm not saying that it couldn't or shouldn't be done, just that I have a
gut feeling that it would not be useful very often.
PoD.
Date: 9 Jun 2002 10:39:05
Message: <3d036889@news.povray.org>
On Sun, 09 Jun 2002 01:09:43 +0930, Apache wrote:
> Technically a really hard thing to do. If POV-Ray is going to do this,
> it should be able to trace the edges of objects on the screen. Try doing
> Apache
> ICQ: 146690431
I don't think it would be that hard.  It's not a matter of detecting
edges of objects, just detecting that a ray has hit a bounding type
object and changing the AA settings.
PoD.
Date: 9 Jun 2002 12:10:55
Message: <3d037e0e@news.povray.org>
  I think that it would require that if the ray hits the object which has
to be antialieased for the first time in the current line, we have to go
back one pixel and render it again antialiased.
  And thinking about it, it would also require rendering the same pixel in the
previous line again the first time we hit the object vertically.
Date: 9 Jun 2002 13:51:16
Message: <3D039344.2010206@web.de>
such that
 > antialias {
 >   depth 3
 >   precision .1
If we realy wanted such a feature, wouldn't it be better to define
it based on pixel rows/columns, analogous to the "partial render"
feature alredy found in POV?
And then, of course, there could be a preprocessing step
to derive the columns/rows of the bounding box of a given object.
Hermann Vosseler
Date: 9 Jun 2002 14:02:33
Message: <3d039839@news.povray.org>
Yes, I think that this kind of selective antialiasing would need
a 2-pass approach: The first pass would be a regular rendering with
no antialiasing, which marks pixels as "this pixel and its surrounding
pixels need to be antialiased" and "this pixel is not antialiased".
The second pass would raytrace the required pixels antialiased.
Date: 9 Jun 2002 14:47:32
Message: <3d03a2c4@news.povray.org>
> if you use the same settings for the background as
First, it would not always be the case that the background would even
require any AA at all. With soft backgrounds I think that object
specific AA could work pretty seamlessly.
Second, if a little AA was required for the background too, there can
still be a huge difference between low-quality AA and high-quality AA.
I think object-specific AA could work well. The biggest problem as I see
it would be to make bounding objects that were tight enough so that not
too many calculations are wasted...
Rune
Rune's World:  http://rsj.mobilixnet.dk (updated May 20)
POV-Ray Users: http://rsj.mobilixnet.dk/povrayusers/
POV-Ray Ring:  http://webring.povray.co.uk
