POV-Ray : Newsgroups : povray.general : pov 4 feature dream Server Time
18 Aug 2025 08:30:33 EDT (-0400)
  pov 4 feature dream (Message 1 to 10 of 11)
Subject: pov 4 feature dream
Date: 27 Nov 2001 17:21:19
Message: <3c0411df@news.povray.org>
It's so simple, it can be done with a little patch if anyone wants to -
How about having a command for POV to print out the post-preprocessed file -
that is, the parsed file - so that if you have tons of macros and while's
and if's you can generate a parsed file with a single command and quickly
render an animation without re-parsing?
Or just saving time?
Or using the same file with minor changes?
Or making a POV X.X scene backwards compatible easily? (If it has functions
like trace())
Or just for fun?
this must be pretty easy to implement.
may your beard grow long and prosper,
Noam Lewis.
Subject: Re: pov 4 feature dream
Date: 28 Nov 2001 05:08:02
Message: <3C04B783.B4896963@atosorigin.com>
> like trace())
> Or just for fun?
Your asking for a kind of POB format (text readable, but still same as POB).
It could be done at the end of the parsing, running through each object,
 if you add a function for each object & pigment & finish & interior & ...
 that would get its data structures and produces a text output.
Beware, you might save parsing time (next time) but not space.
 (a small set of #while can save you millions of lines).
Interestingly, it might convert all meshes in mesh2 format...
Date: 28 Nov 2001 05:31:04
Message: <3c04bce8@news.povray.org>
nLewis <noa### [at] writemecom> wrote:
: It's so simple, it can be done with a little patch if anyone wants to -
: How about having a command for POV to print out the post-preprocessed file -
: that is, the parsed file - so that if you have tons of macros and while's
: and if's you can generate a parsed file with a single command and quickly
: render an animation without re-parsing?
  So if you have a 1-kilobyte pov-file which creates a million spheres,
you'll end up with a 50-megabyte parsed file?
  And this idea about having a byte-compiled version of the scene has been
already discussed 100 times before. It is possible, but not simple.
Date: 29 Nov 2001 20:47:32
Message: <tom.stone-3011010313280001@d212-151-227-115.swipnet.se>
Here's another little idea then.
It would be a nice shortcut to be able to open an .inc file from within
the .pov file by Control-Clicking on the name of the .inc file in the
source.
But maybe that is a platform specific idea, I don't know.
Tom Stone
Domarebacken 42, 14557 Norsborg, Sweden
Phone: Int+46 8 5318 4318, Tel: 08-5318 4318
http://home5.swipnet.se/~w-52256/index.htm
Date: 29 Nov 2001 20:50:42
Message: <slrna0dpfl.t5q.ron.parker@fwi.com>
> source.
It is, just because there's no cross-platform editor.  But if you had
a real computer (snerk!) you'd be able to right-click and select "open
whatever.inc" from the menu.
#local R=rgb 99;#local P=R-R;#local F=pigment{gradient x}box{0,1pigment{gradient
y pigment_map{[.5F pigment_map{[.3R][.3F color_map{[.15red 99][.15P]}rotate z*45
translate x]}]#local H=pigment{gradient y color_map{[.5P][.5R]}scale 1/3}[.5F
pigment_map{[.3R][.3H][.7H][.7R]}]}}}camera{location.5-3*z}//only my opinions
Date: 30 Nov 2001 02:48:10
Message: <3c0739ba@news.povray.org>
"nLewis" <noa### [at] writemecom> wrote in message
news:3c0411df@news.povray.org...
file -
functions
> like trace())
> Or just for fun?
> Noam Lewis.
AFAIK, you can do this with the preprocessor from gcc.  Unfortunately, I
don't remember how :)
...Chambers
Date: 30 Nov 2001 07:43:49
Message: <3c077f05$1@news.povray.org>
> > Noam Lewis.
    Just had to point out this personal hygiene tip.
Date: 30 Nov 2001 08:30:16
Message: <3c0789e8@news.povray.org>
In article <tom### [at] d212-151-227-115swipnetse> ,
> source.
In the Mac version you can open the file via the #include file menu of the
currently open window.  No double-clicking yet, but very close.
As far the Windows version, I _think_ this feature is already there, but i
don't know for sure how it works.
    Thorsten
e-mail: tho### [at] trfde
Date: 30 Nov 2001 08:38:29
Message: <3c078bd5@news.povray.org>
Thorsten Froehlich <tho### [at] trfde> wrote:
: As far the Windows version, I _think_ this feature is already there, but i
: don't know for sure how it works.
  It is there and it works. Right-click and select 'Open "whatever.inc"' from
the menu.
  In fact, it's a quite handy feature.
Date: 1 Dec 2001 13:56:23
Message: <3c084e33.4487878@localhost>
On Wed, 28 Nov 2001 00:21:48 +0200, "nLewis"
snip
	What would you do about a .pov file that generates a
.pov/.inc file and then includes it?
Pete
