POV-Ray : Newsgroups : povray.general : Help Creating parabolic mirrors Server Time
17 Aug 2025 05:15:30 EDT (-0400)
  Help Creating parabolic mirrors (Message 1 to 10 of 21)
Subject: Help Creating parabolic mirrors
Date: 7 Aug 2003 14:15:37
Message: <3F32970D.2020305@comcast.net>
If anyone has the time I could sure use some help creating three objects
First an annular parabolic mirror.
-Made of solid glass or hollow
-Having an adjustable parabolic curve in order to change the focal length
It would look like a clear or hollow  parabolic torus cut in half with
its interior surface mirrored, interior media clear or hollow and its
exterior opaque.
Second a parabolic mirror
-Made of glass and hollow
It would look like a parabolic bowl with its interior surface mirrored,
interior media clear or hollow, and its exterior surface opaque
Third an omni-directional mirror
-Having an semitransparent external mirror coating while the interior
would be fully transparent
It would look like a cone with a rounded apex with its exterior surface
  coated with a semitransparent mirrored interior surface fully transparent
Thanks
Subject: Re: Help Creating parabolic mirrors
Date: 8 Aug 2003 03:14:35
Message: <3f334ddb$1@news.povray.org>
You can create paraboloids using the quadric object.
Here's a mirror as it is used in a Newton reflector-telescope:
#default {
	pigment { color rgb <1,1,1> }
	finish { ambient 0.5 diffuse 0.5 }
#declare focal_length = 10;
#declare ms = 1/4/focal_length;
#declare mainMirror = difference {
	cylinder { <0.01,0,0>,<-ms,0,0>,1 }
	quadric {
		<0,1,1>,<0,0,0>,<1,0,0>,0
		scale <ms,1,1>
		finish { ambient 0 diffuse 0 reflection 1 }
plane { y,-2 pigment { checker } }
light_source { <-100,100,0> color rgb <1,1,1> }
camera { location <-3,1,-3> look_at <0,0,0> }
object { mainMirror }
Date: 10 Aug 2003 13:26:21
Message: <3f36803d@news.povray.org>
Wouldn't it be easier to use a lathe with _quadratic_
spline for the parabolic mirror?
Wolfgang
Date: 10 Aug 2003 14:31:00
Message: <cjameshuff-02BCEE.13281510082003@netplex.aussie.org>
In article <3f36803d@news.povray.org>, Wolfgang Wieser <wwi### [at] gmxde>
The easiest way would be to use an isosurface, a quadric is probably the
most efficient way. I wouldn't use a lathe, though it would work.
There are paraboloid shapes based on the quadric primitive in
shapes_old.inc.
http://tag.povray.org/
Date: 10 Aug 2003 15:03:27
Message: <3f3696fe@news.povray.org>
A paraboloid is essentially y=x^2 rotated around the Y axis (isn't it??)
So, using a quadratic spline and modelling just that y=x^2 curve
seems to me the most natural approach to me.
Why should I use a quadric? Is it really faster than a lathe?
Wolfgang
Date: 10 Aug 2003 17:54:07
Message: <3f36beff$1@news.povray.org>
I hope this isn't a patronizing question, but I fear you may be expecting a
raytracer to do something it cannot.  I once spent a weekend trying to use
CorelDream3D to make my own "spotlight":  a parabolic mirror with a light
source in it.  It don't work.
You'll need to use photons if you want to make "optical" use of such a
surface.
Date: 10 Aug 2003 18:09:43
Message: <3f36c2a6@news.povray.org>
  A quadric will be mathematically accurate (inside the limits of
floating point accuracy), while a lathe will only be an approximation.
  As for speed, the quadric is probably faster.
Date: 10 Aug 2003 18:10:40
Message: <3f36c2e0@news.povray.org>
  POV-Ray can make perfectly parabolic mirrors and reflect light from
them. It's far from impossible.
Date: 10 Aug 2003 18:44:09
Message: <cjameshuff-213C69.17411010082003@netplex.aussie.org>
In article <3f3696fe@news.povray.org>, Wolfgang Wieser <wwi### [at] gmxde>
A more precise description would be "y = x^2 + z^2", though it is
equivalent to sweeping a 2D curve as you described.
A quadric would be a paraboloid, while a lathe would just look like one.
As for speed, a lathe is a far more complex object. I would expect
slower rendering and much higher probability of artifacts. Also,
although there is a quadratic spline, it may not give the expected
result, and would be a bit more awkward to control...splines are
generally not used for precise mathematical curves. A lathe *can* be
used for this, but it is certainly not the best tool for the job. An
isosurface or quadric would be a perfect match for this task. A quadric
is more difficult to use than an isosurface, but the isosurface will be
less precise. Either one may be faster, it depends on the situation.
And finally, there are already predefined paraboloid quadrics in the
includes...
Date: 10 Aug 2003 18:47:39
Message: <3F36CCF5.F8EB095E@pacbell.net>
If it looks like a duck and it quacks like a duck...
Ken Tyler
