![](/i/fill.gif) |
Hi!
The Beta 2 of TreeDesigner is available for download at:
http://www.algonet.se/~jhubert/TreeDesigner
The Beta 1 will expire with the beginning of march, so be sure to
download the new version!
Here a few snippets from the new features list:
(more can be found at the TreeDesigner Homepage)
- A new Overview Pane has replaced the old
Create/Modify panel and the old Select dialog.
It allows for easier access to each element as
well as for a better representation of the data.
- The leaf-formats are now stored in their own
files, allowing for userdefined leaftypes by
adding your own leafdefinition files to the "Leafs"
subfolder of the TreeDesigner folder.
- There are now three different detail-levels for
the export to Moray, with the lowest level being
ideal to import a large number of background plants
into Moray.
- You can now choose to use a placeholder for pan, zoom
and rotate, which makes those actions much smoother
on slow computers or with large models.
- A better support for lefthanded-user has been added:
Depending on which hand moves the mouse, you can choose
the shortcut/hotkeys to suit your other "free" hand.
I hope you like the new version, for any opinions, ideas, suggestions
etc., don't hesitate to e-mail me:
jhu### [at] algonet se
Greetings, Johannes.
![](/i/fill.gif) |
![](/i/fill.gif) |
Hi Johannes !
The new Beta looks great. The new overview pane gives me more
freedom to work direcly with the parameters and it
is a good idea to work with userdefined leafs.
And here is the first question about the leafs.
First I read the tutorial and all seems easy.
Now I want create a oakleaf and give a series of 51 vertics
(num=51) divided by 1 (div=10), to get rounded edges.
The definition for surface is right, I think.
When I start TreeDesigner I get the following alert:
Unexpected end of file in leaf-definition file
the file will be ignored.
Are there any restrictions with num= or div= in veritcs-
description.
name="DZ_Standard"
type=flat
[Exp:Povray]
no texture
Povray\Standard.pov
[vertices]
num=13
div=20
0.0 -0.25 0.0 0.5 //p1
0.0 -0.25 2.0 0.5 //p2
0.0 -3.25 4.0 0.5 //p3
0.0 -4.50 7.25 0.5 //p4
0.0 -3.00 7.0 0.5 //p5
0.0 -4.5 8.0 0.5 //p6-------|
0.0 0.0 12.0 0.5 // midle |
0.0 4.5 8.0 0.5 //p6-------|
0.0 3.00 7.0 0.5 //p5
0.0 4.50 7.25 0.5 //p4
0.0 3.25 4.0 0.5 //p3
0.0 0.25 2.0 0.5 //p2
0.0 0.25 0.0 0.5 //p1
[surfaces]
num=2
4 = 0 1 12 13
11 = 1 2 3 4 5 6 7 8 9 10 11
When I insert the vertics (p6) and start Treedesigner
I get :
Assertion Failed Path\Leaf_Type_Flat.cpp,Line 203
Greetings Dankfried
![](/i/fill.gif) |
![](/i/fill.gif) |
The server seemed to be down for quite some time, so please excuse the
late answer!
Dankfried Zickler wrote:
> Hi Johannes !
> description.
> name="DZ_Standard"
> type=flat
> [Exp:Povray]
> no texture
> Povray\Standard.pov
> [vertices]
> num=13
> div=20
> [surfaces]
> num=2
> 4 = 0 1 12 13
> I get :
> Greetings Dankfried
![](/i/fill.gif) |
