POV-Ray : Newsgroups : povray.documentation.inbuilt : Mysterious function argument Server Time
13 Aug 2026 09:23:17 EDT (-0400)
  Mysterious function argument (Message 11 to 20 of 20)
Subject: Re: Mysterious function argument
Date: 2 Oct 2021 15:35:00
Message: <web.6158b39c3ec630374cef624e6e066e29@news.povray.org>
William F Pokorny <ano### [at] anonymousorg> wrote:
> On 10/1/21 3:13 PM, Kenneth wrote:
>#declare F0 = function {pattern {bozo}}
> ..throws a fatal error just by itself, "Expected 'Rvalue to declare', pattern
> found instead"
> Hmm. Do others on windows see this sort of fail?
> The code parses for me with v3.7 and v3.8.
Good question. I just ran that 'pattern' version in v3.7.0 (Windows), and it
fails there too, same error message. I have a faint recollection that it parsed
OK in some earlier version of POV-ray like v3.6; but I could be wrong. It seems
to be a strange result in the Windows version nevertheless.
Date: 2 Oct 2021 22:40:00
Message: <web.615917b73ec630374cef624e6e066e29@news.povray.org>
>  found instead"
[and...]
> fails there too, same error message...
MY ERROR! I mixed up my various tests :-\  Those two #declared functions DO
parse OK in Windows, in both v3.7.0 and v3.8.0 beta 1. Very sorry for the
confusion.
What I actually *tested* was this comparison, by mistake (but still interesting,
and maybe odd- but certainly off-topic here):
#declare PATT =
pattern{bozo}
... which fails parsing
or..
#declare PATT =
pigment{bozo}
...which parses successfully
Date: 3 Oct 2021 08:23:06
Message: <6159a0aa$1@news.povray.org>
>>   found instead"
> [and...]
> confusion.
> #declare PATT =
> pattern{bozo}
> or..
> #declare PATT =
> pigment{bozo}
Ah, good. Thanks for following up.
Aside: In my tcl wrapper for SDL, I have functions which allow me to
declare Patterns, Warps, Radiosity, and other blocks(1) by name so they
can just be references later by name as needed(1). The capability to
pre-declare certain blocks by ID unfortunately isn't / wasn't
implemented for some features of POV-Ray's SDL.
(1) - Underneath it creates macros which then are, repeatedly, inserted
as needed.
The missing declare ability I trip over frequently, when writing raw
SDL, is: #declare Warp00 = warp{...}.
Bill P.
Date: 3 Oct 2021 12:10:00
Message: <web.6159d5353ec630371f9dae3025979125@news.povray.org>
I've gotten tripped up with the pattern vs pigment issue myself on numerous
occasions.  I suppose that's another thing that will have to be clarified with
some example scenes, etc.
I might have tried that in the past, but the other one (IIRC) that I was
surprised at was the inability to predeclare a matrix for use in transforms.
There are a lot of things in SDL that have similar structures, but are
separate/isolated from each other.  matrices, splines, prisms --- it would be
nice if their internal data were all addressable/accessible like arrays.
Date: 3 Oct 2021 13:02:37
Message: <6159e22d$1@news.povray.org>
> (*) - POV-Ray proper has unique default color maps for each continuous
> pattern. Be sure to always specify the color map you want!
> Bill P.
Not quite accurate. Several continuous patterns do have an unique
default colour_map, but not all.
Those don't have a specific default map, unless this counts as a
specific colour_map
colour_map{[0 rgb 0][1 rgb 1]}
bumps, spotted, leopard, quilted, ripples, waves, granite, crackle,
marble, dents, spherical, boxed, cylindrical, planar.
Those have continuous gradients, but they repeat abruptly, and don't
have default colour map :
gradient, onion.
The first two are identical to a bozo pattern, but without the colour_map.
Date: 3 Oct 2021 17:33:45
Message: <615a21b9$1@news.povray.org>
>> Bill P.
> specific colour_map
> gradient, onion.
Thank you for the correction Alain.
Bill P.
Date: 3 Oct 2021 19:10:00
Message: <web.615a364e3ec630374cef624e6e066e29@news.povray.org>
> // povray +mv3.8 +iThisParseTest.inc
> #declare F1 = function {pigment {bozo}}
> #declare F2 = function {pigment {bozo
>          color_map {[0,rgbft 0][1,rgbft 1]}
> #declare F3 = function { F0(x+1,y/2,z) }
> //#declare V0 = F0(x+1,y/2,z);
> // Parse Error: Float expected but vector or color expression found.
> #declare V1 = F1(1,2,3);
> #declare V2 = F2(1,2,3);
> #declare V3 = F3(1,2,3);
> #debug concat("\nV1 = ",vstr(5,V1,",",1,3),"\n")
> #debug concat("V2 = ",vstr(5,V2,",",1,3),"\nV3 = ",str(V3,1,3),"\n\n")
> #error "Parse Test. Stop early"
Hi again!
I've been looking at your code examples in detail for several days, and running
animation tests(!) while varying some of the function parameters (my usual
method of 'discovery' when I do not fully understand how certain code constructs
work... to *visually* see what's going on.) I am actually learning some new and
basic things about functions and their uses, that always mystified me--
specifically, plugging integers (or even floats) into a function, like your
In the past, Bald Eagle has valiantly tried to beat such stuff into my brain,
but I've been kind of a dunce and just didn't grasp it. :-\  Well, I think I've
finally had one of those 'eureka' moments.
My big discovery(??):
From experimenting, it looks like your integers (1,2,3) are pulling a
*point-sample* color  from  F1's  'continuous' bozo function,  from a specific
location point in bozo's 3-D spatial pigment... the location being <1,2,3>.  And
with the corresponding #debug results of  <0.000,1.000,0.000,0.000,0.000> as the
color at that spatial point. Am I correct??
For example, by  giving your F1 and V1 functions some different values:
#declare F1 = function{pigment{gradient x}}
#declare V1 = F1(0.5,0,0);
..... the #debug result-- AND the resulting *single* V1 color applied to a 1X1
box
as pigment{V1} )--  is  <0.500,0.500,0.500,0.000,0.000> -- the linear gray
'color' found halfway across the gradient x  map (which has a default grayscale
color_map of its own).  Very neat!
(BTW, for animation tests, I can even do this:
#declare V1 = F1(clock, 0.5 ,0.7) or whatever)
But going back to your original F1 and V1 functions:, I am curious about two of
the #debug results:
Question 1:
> v3.7/3.8 returns:
> V1 = 0.000,1.000,0.000,0.000,0.000
Yes, for me as well.
> The povr branch returns:
> V1 = 0.421,0.421,0.421,0.000,0.000
> (***) The povr branch defaults to rgb [0...1] color_maps for all
> continuous patterns.
*If* I am correct about my analysis of function use as I described, your 0.421
results are an interesting mystery to me-- especially for *all 3* red-green-blue
channels, rather than just the green channel alone, as in Windows. The bozo
pigment/pattern has discrete color areas that don't 'blend', AFAIK, so I'm
curious as to which part(s) of your own color_map are producing that value...
and for all 3 channels! My own logic tells me that the Windows and povr results
should match-- that is, producing only a single value in the green channel,
regardless of what that value might be.
Question 2:
Your F3 function  is
and the V3 function is
Those have 3 components <x...,y...,z...>, yet your #debug for V3 uses just
'str' to pull out some kind of  *single* value (not 'vstr' to pull out all 3 or
5). I thought  str  would outright *fail* with a 3-component function... yet it
does not, interestingly. Is your F3 function 'continuous', or does it just
create a single value? (Such distinctions are still a bit fuzzy to me.) But I'm
equally curious as to where the final result of  0.489 comes from,
mathematically (in 3-D space?). I can't figure that out, so far.
I apologize if a lot of this is off-topic-- but it's all fascinating and
instructive.
Date: 3 Oct 2021 19:30:00
Message: <web.615a3c0e3ec630374cef624e6e066e29@news.povray.org>
> ..the other one (IIRC) that I was
Works for me! (With a transform wrapper)
#declare VIRGINIA =
transform{
matrix < 1, 1, 0,
       0, 1, 0,
       0, 0, 1,
       0, 0, 0 >
box{0,1
transform{VIRGINIA}
Date: 4 Oct 2021 04:42:18
Message: <615abe6a$1@news.povray.org>
Close. When you make a function call to a function{pattern{}} or a
function{pigment{}} you pass 3D positional values for x,y,z - always -
to the pattern. In the example code this is the bozo pattern. The bozo
pattern returns a single, continuous, scalar value in the [0..1)|]
range. With functions, this single value can be returned directly - or
it can be used as an index into a *_map and a vector of values from that
map can be returned.
If you use function{pattern{bozo}}, you get the scalar pattern value and
the function is considered a scalar function internal to POV-Ray.
If you use function{pigment{bozo}}, you get the 5D color vector from the
*map at the map index of scalar value returned by the bozo pattern.
Internal to POV_ray the function is then considered a vector function.
> ..... the #debug result-- AND the resulting*single*  V1 color applied to a 1X1
> box
Cool. Not something I've done and it could be useful. I've been toying
with rtr/kla scenes as a way to document certain features - supposing I
can get going some simple dynamic user control as the animation rolls
ever onward...
> the #debug results:
> Question 1:
>> v3.7/3.8 returns:
The window / povr results would match except the povr branch uses a
default color map of 0-1 for all continuous patterns - povr is set up
differently so function{pigment{}} will often - but not always - return
a different result.
> Question 2:
> Your F3 function  is
> 'str' to pull out some kind of*single*  value (not 'vstr' to pull out all 3 or
> 5). I thought  str  would outright*fail*  with a 3-component function... yet it
F3 is continuous because F0 is. F3 calls F0 which is defined as
function{pattern{bozo}} as as such it is a scalar function - it returns
a single value. F0 is continuous only because the bozo pattern is a
continuous pattern. You could instead use the discrete checker pattern
in F0 and it would then return discrete single values depending upon the
3D location.
Aside: povr, at present, uses the default color maps as they are in
POV-Ray proper for the half dozen or so discrete patters like checker,
triangular, etc.
Hope my ramblings of some help.
Bill P.
Date: 4 Oct 2021 14:55:00
Message: <web.615b4d143ec630374cef624e6e066e29@news.povray.org>
> > Question 2:
> > Your F3 function  is
> > all 3 or 5). I thought  str  would outright *fail* with a 3-component
> >  function... yet it does not, interestingly. Is your F3 function
> > 'continuous', or does it just create a single value?
> continuous pattern.
Ah! That's the 'missing piece of the puzzle' for me, in TWO ways:
1) It explains the successful  str  use in #debug-- because function F0 (the
bozo PATTERN) is a *scalar* function, not a multi-component color function. I
have always assumed that such pigment 'patterns', even though grayscale, still
contain 3 (or maybe 5) color components like <.3,.3,.3,0,0>. But they are just a
SINGLE value like .3.  Thanks! That clears up a long-standing misconception for
me.
2) It also explains to me why F0 (and F3), when actually used (as they are),
cannot have a dot operator like .gray added-- because the function is *scalar*
with only one component; the dot operator 'mechanism' assumes that there or 2 or
more components, and fails.
Much food for thought! I'm still 'putting all of the pieces together'...
