POV-Ray : Newsgroups : povray.documentation.inbuilt : Reference:Arrays note about 40 character identifier limit. Server Time
12 May 2025 08:45:37 EDT (-0400)
  Reference:Arrays note about 40 character identifier limit. (Message 1 to 8 of 8)
Subject: Reference:Arrays note about 40 character identifier limit.
Date: 12 Dec 2016 06:44:25
Message: <584e8d99$1@news.povray.org>
Ref:
http://wiki.povray.org/content/Reference:Array
There is this:
Where IDENTIFIER is the name of the identifier up to 40 characters long
and INT is a valid float expression which is internally truncated to an
integer which specifies the size of the array.
I believe identifiers can be longer than 40 characters & that we've
recently added such notes elsewhere. Perhaps we need not mention the
identifier limit specifically for arrays should we want to avoid another
change note.
Bill P.
Subject: Re: Reference:Arrays note about 40 character identifier limit.
Date: 12 Dec 2016 07:38:55
Message: <584e9a5f$1@news.povray.org>
On 12/12/2016 6:44 AM, William F Pokorny wrote:
> Ref:
> change note.
i've already addressed that here:
http://wiki.povray.org/content/Reference_Talk:Array
but haven't moved it over yet ... was waiting for some kind of heads up
that the other feature add/change was going to make it into release branch
Date: 12 Dec 2016 08:58:40
Message: <584ead10$1@news.povray.org>
>> Ref:
>> change note.
I didn't think to look there - cool! :-)
Bill P.
Date: 12 Dec 2016 13:05:54
Message: <584ee702$1@news.povray.org>
Am 12.12.2016 um 13:38 schrieb Jim Holsenback:
>> Ref:
>> change note.
Then let it hereby be known that flexible-size arrays, mixed-type arrays
and dictionaries have joined the master branch on November 25th. ;)
Also included are two pseudo-dictionaries, `local` and `global`,
representing the "most local" identifiers and the global identifiers,
respectively. For example:
    #declare local.Foo = 4711;
    #undef global.Foo;
will declare a local variable named "Foo", and undefine any global
variable of the same name, respectively.
*NOTE*: These pseudo-dictionaries *REPLACE* the `local()` and `global()`
pseudo-functions, which are currently mentioned in the tutorial's "New
features" section, the "Identifier Name Collisions" section in the
reference page on #declare and #local, and in the "Optional Parameters"
section in the reference page on macros.
Date: 13 Dec 2016 11:52:10
Message: <5850273a$1@news.povray.org>
>>> Ref:
>>> change note.
>     #undef global.Foo;
ok so some clean up and one add ... local and global are /still/ keywords?
Date: 13 Dec 2016 12:25:55
Message: <58502f23@news.povray.org>
Am 13.12.2016 um 17:52 schrieb Jim Holsenback:
Yes.
`local` is now a special keyword that essentially evaluates to the
directory of "most local" variables.
`global` is now a special keyword that essentially evaluates to the
directory of "least local" (i.e. global) variables.
In addition to that, `local` of course retains its well-established
meaning after `#` to form the `#local` directive. (Technically, all the
directives are actually the `#` token followed by a keyword.)
Date: 13 Dec 2016 12:26:11
Message: <58502f33$1@news.povray.org>
>>>> Ref:
>>>> another
>>>> change note.
>>> branch
>>     #undef global.Foo;
one more question ... id name collisions it's just a delete but optional
params part i see in 1st note reference to /local/ should the link now
point to the add i'll be doing to the array page? what about example
just below the note ... still valid example?
Date: 13 Dec 2016 19:37:30
Message: <5850944a$1@news.povray.org>
Am 13.12.2016 um 18:26 schrieb Jim Holsenback:
>> keywords?
I think we should keep some mention of the mechanism in the "Identifier
Name Collisions" section, except of course that it needs to be re-worded
to fit the dictionary-ish version rather than the function-ish one. And
it may be shortened to a reference to the section on dictionaries.
Where the "Optional Parameters" note links to depends on where we want
to put the primary information on the "local" pseudo-dictionary: In the
dictionaries reference, or the identifier name collision section. I'd
advocate the former.
The text "... make use of the `local()` pseudo-function..." of course
needs to be replaced with "... make use of the `local`
pseudo-dictionary...", and the example indeed needs fixing as well:
    #macro Foo(P1, optional P2)
      #ifndef(local.P2) #local P2 = 0; #end // provide default for P2
    #declare X=1;
    #declare Y=2;
    Foo(X,Y);
    #undef Y;
    Foo(X,Y);
    Foo(X,);
