POV-Ray : Newsgroups : povray.bugreports : Parse error: Uncategorized error thrown at parser/parsertypes.cpp line 62 Server Time
26 Feb 2026 20:55:37 EST (-0500)
  Parse error: Uncategorized error thrown at parser/parsertypes.cpp line 62 (Message 1 to 10 of 13)
Subject: Parse error: Uncategorized error thrown at parser/parsertypes.cpp line 62
Date: 19 Mar 2019 16:05:01
Message: <web.5c914a829a8674824c2823a70@news.povray.org>
Hello / Hi
I have installed PovRay 3.8.0-x.10064738.unofficial last sunday on Ubuntu with
the sources compilation.
To easily switch between several povray versions I have the following files in
'usr/local/bin' :
'povray3-7' which is the binary of the stable 3.7 branch
'povray3-8' which is the binary of the 3.8.0[etc] described above
and a file 'povray' which is a symbolic link that can point to one of the two
binaries above.
I have a scene that renders with povray 3.7 but doesn't with v3.8.
With the 3.8 version, povray outputs the following message in the console:
==== [Parsing...] ==========================================================
File 'trees/kapok.tree' line 4: Possible Parse Error: Uncategorized error thrown
 at parser/parsertypes.cpp line 62.
Fatal error in parser: Uncategorized error.
Render failed
And I don't know how to solve this problem, even after parsing by myself
'kapok.tree' file.
Here is the output of the frist lines of 'kapok.tree' :
// TREE_NAME=Defaut;
//ROOT
#declare ROOTS=4;
#declare ROOT_RANDOM=13;
#declare FIRST_ROOT_AT_TRUNK=70;
#declare ROOT_LENGTH=200;
#declare ROOT_THICKNESS_CHANGE=0.85;
In the pov file I have this line that loads 'kapok.tree' :
LoadTree("trees/kapok.tree")
And the 'LoadTree()' macro is defined like that :
#macro LoadTree(filePath)
 #include filePath
 #include "povtree/TOMTREE-1.5.inc"
When I input 'povray --version' in the console, I have the following output:
POV-Ray 3.8.0-x.10064738.unofficial
This is an unofficial version compiled by:
 Antoine FAURE <https://www.ant01.fr>
 The POV-Ray Team is not responsible for supporting this version.
Copyright 1991-2019 Persistence of Vision Raytracer Pty. Ltd.
This is free software; see the source for copying conditions.  There is NO
warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
Built-in features:
  I/O restrictions:          enabled
  X Window display:          enabled (using SDL)
  Supported image formats:   gif tga iff ppm pgm hdr png jpeg tiff openexr
  Unsupported image formats: -
Compilation settings:
  Build architecture:  x86_64-pc-linux-gnu
  Built/Optimized for: x86_64-pc-linux-gnu (using -march=native)
  Compiler vendor:     gnu
  Compiler version:    g++-8 8
  Compiler flags:      -pipe -Wno-multichar -Wno-write-strings
-fno-enforce-eh-specs -Wno-non-template-friend -Wsuggest-override -s -O3
-ffast-math -march=native -pthread
In the hope that helps...
Subject: Re: Parse error: Uncategorized error thrown at parser/parsertypes.cpp line 62
Date: 20 Mar 2019 14:27:33
Message: <5c928615$1@news.povray.org>
On 3/19/19 4:01 PM, Warren wrote:
> Hello / Hi
> 'usr/local/bin' :
> binaries above.
I can confirm the v38 issue. Also running Ubuntu 18.04 though g++7 vs
Warren's 8.
It seems the v3.8 branch (commit 74b3ebe) needs a space ahead of the
macro #end statement to work as follows:
#macro LoadThing(filePath)
     #include filePath
  #end                 // <-- Add extra space before #end and OK
LoadThing("zoomBangCrash.inc")
and whenever the include file has an empty line, C++ comment style line,
C++ comment line and then a declare line. The following for
zoomBangCrash.inc, less the line numbers, is also a v3.8 parse issue if
there is no space ahead of the main file macro #end:
01
02 //
03 //
04 #declare A=1;
Perturb the include much and things work whether there is a space before
the macro #end or not. Change the #declare A=1; to #declare Sphere00 =
sphere { 0, 1 } for example and things are fine.
Bill P.
Subject: Re: Parse error: Uncategorized error thrown at parser/parsertypes.cpp line =
Date: 21 Mar 2019 14:25:00
Message: <web.5c93d6a8d2cec0344c2823a70@news.povray.org>
> > Hello / Hi
> > 'usr/local/bin' :
> > binaries above.
> Warren's 8.
>      #include filePath
> 01
> 02 //
> 03 //
> 04 #declare A=1;
> Bill P.
Hello / Hi
I made the changes you suggested and everything works fine now (I get all the
textures I normally have when I use v3.7 but with the v3.8 this time). In fact,
I use the v3.8 because there's a bug in the v3.7 with the conic_sweep prisms
when the camera is orthographic and its direction perpendicular to the caps of
the pyramid ( I posted a message about this bug some time ago, it seemed povray
3.7 fail to find roots ). Thank you for your support :-D
Subject: Re: Parse error: Uncategorized error thrown at parser/parsertypes.cppline 62
Date: 21 Mar 2019 15:18:32
Message: <5c93e388@news.povray.org>
Am 20.03.2019 um 19:27 schrieb William F Pokorny:
> Warren's 8.
>      #include filePath
> 01
> 02 //
> 03 //
> 04 #declare A=1;
Can't reproduce on Windows; neither with DOS line endings (CR+LF) nor
with Unix line endings (LF).
I'm running a slightly modified version, but if any of those
modifications make any difference, I wouldn't know which ones.
Do you have the time and energy to investigate this further?
Subject: Re: Parse error: Uncategorized error thrown atparser/parsertypes.cppline 62
Date: 22 Mar 2019 06:44:33
Message: <5c94bc91$1@news.povray.org>
Not today with a family visit later, but I'll put it on the list to play
with the issue more this weekend.
Bill P.
Subject: Re: Parse error: Uncategorized error thrownatparser/parsertypes.cppline 62
Date: 24 Mar 2019 10:59:02
Message: <5c979b36$1@news.povray.org>
That was painful to run down, but changing Parser::IsEndOfInvokedMacro()
in the file source/parser/parser_tokenizer.cpp as in the attached file
fixes the issue.
Have to admit I'm not sure even now I completely understand what was
happening (how it could happen perhaps). We seem to have been comparing
structures in the original - which I don't think c++ does by default?
return (Cond_Stack.back().PMac->endPosition ==
CurrentFilePosition()) && ...
If this true though, why no compile warning or error? In any case, once
in a while on the structure compare some error got thrown and caught by
the parser code and no message was set which is why we get the unhelpful
generic something wrong message. Mostly calls to the compare above
seemed to work - including ones prior to the failing one for the test
case - returning false always.
I'm tempted to add a throw on a true test for the re-coded version then
run a bunch of stuff to see if it true ever really happens. Have we been
doing something like comparing pointers (and so false) always? But, I've
already spent a day on this and I don't feel like spending additional
time.
For the particular test cases you can also hard code that function to
return false always and things work because that test is always false
for it.
Lastly, I did try a debug -Og compile thinking maybe we had some
compiler issue here, but it failed in the same way.
Anyone who better understands what happened / how direct struct compares
could sort of seem to work, please feel free to jump in and explain.
Bill P.
Download 'isendofinvokedmacro_update.txt' (1 KB)
Subject: Re: Parse error: Uncategorized errorthrownatparser/parsertypes.cppline 62
Date: 25 Mar 2019 18:55:29
Message: <5c995c61$1@news.povray.org>
Am 24.03.2019 um 15:59 schrieb William F Pokorny:
> fixes the issue.
Well, that's a lead I might investigate. But as you don't seem to be
confidently understanding what's going on, I'll be going with the
presumption that this is not a proper fix but just a patch.
That's easily explained: The data is of type `LexemePosition`, which is
a struct defining an overloaded comparison operator.
(In C++, structs and classes are the same category of beasts. The only
semantic difference between `struct` and `class` is the default member
and base class access: `struct` implies `public` by default, while
`class` implies `private` by default. According to the language
standard, it is even perfectly valid to pre-declare a type as `struct`
and later define it as `class` or vice versa.)
The `LexemePosition` type holds a file offset, as well as a line and
column number.
Comparison is done by file offset, but the code also features an
assertion, which tests whether the comparison by line and column yields
the same result. If the assertion fails, debug builds bomb (i.e. core
dump or break into a debugger), and non-debug builds throw an exception
to trigger a parse error.
(Usually such assertion tests are only enabled in debug builds, but in
the parser they're currently deliberately enabled in all builds, because
I don't fully trust my current understanding of the parser and the
refactoring work I have based on that understanding.)
If `Cond_Stack.back().PMac->endPosition == CurrentFilePosition()` throws
an exception, it means either of two things:
(A) The positions compared are from two different files, which means the
calling code has failed to check whether it is even in the right file.
(B) The line/column tracking is buggy, and yields different positions in
different situations.
> In any case, once
This is the default error message for failed assertions. Unfortunately
somewhere along the chain of error message handling the location
information for the assertion seems to be lost, the original exception
should include the nformation that it was triggered in `parsertypes.h`
line 62 (in my version of the file at any rate), maybe even that it was
in function `LexemePosition::operator==` (depending on compiler). Maybe
it's worth investigating and fixing that.
Subject: Re: Parse error: Uncategorizederrorthrownatparser/parsertypes.cppline 62
Date: 25 Mar 2019 19:41:39
Message: <5c996733$1@news.povray.org>
Am 25.03.2019 um 23:55 schrieb clipka:
Well, looking at the code of `IsEndOfInvokedMacro()` again, it
_strongly_ reeks of scenario (A):
            (Cond_Stack.back().PMac->source.fileName ==
                 mTokenizer.GetInputStreamName());
should probably be swapped around, like so:
     return (Cond_Stack.back().PMac->source.fileName ==
                 mTokenizer.GetInputStreamName()) &&
                 CurrentFilePosition());
so that the `LexemePosition` comparison operator is only invoked if the
file names match.
I guess you got really lucky in your test (and the OP unlucky in their
use case), in that you happen to have created the following scenario:
- A macro is invoked.
- That macro includes a different file.
- That included file happens to have a `#` (e.g. `#declare`) at the same
file offset as the `#end` of the macro.
- However, the `#` happens to be in a different line and/or column.
In such a scenario, encountering the `#`, the parser would first test
whether this is the `#end` of the macro it has been waiting for, calling
`IsEndOfInvokedMacro()`.
`IsEndOfInvokedMacro()` in turn would checks whether the current file
position matches that of the macro's `#end` by calling
`LexemePostition::operator==`.
`LexemePostition::operator==` in turn would find that the file position
does match. It would then verify that the match also reflects in line
and column, and find that they differ, and report this inconsistency via
an Exception.
`IsEndOfInvokedMacro()` wouldn't even get a chance to test whether it is
looking at the right file, because its author (duh, I wonder who that
stupid git might have been...) chose to do the two tests in the wrong order.
Now aside from the stupid git who authored `IsEndOfInvokedMacro()`
there's someone else to blame for the situation, namely whoever thought
it was a good idea to keep the stack of include files separate from the
stack of pending "conditions". If they were using one and the same
structure, having `INVOKING_MACRO_COND` on top of the stack would imply
that we're in the file with the `#end`, and the file name test would be
redundant.
I think it should be possible to merge the include stack into the
"condition" stack without adverse effects, but I haven't finished work
on that yet.
I should note that I haven't tested this hypothesis and fix for the
error yet; I intend to do that as soon as I find the time, but of course
you're welcome to beat me to it.
Subject: Re: Parse error: Uncategorizederrorthrownatparser/parsertypes.cppline62
Date: 26 Mar 2019 06:46:20
Message: <5c9a02fc$1@news.povray.org>
>> throws an exception, it means either of two things:
>> the calling code has failed to check whether it is even in the right
>> file.
>> in different situations.
> file names match.
> an Exception.
> order.
> redundant.
> on that yet.
Thanks for the detailed explanations and, though I'm busy with RL
starting in a little while today, I think you've figured it out.
I know from looking at the values the position was matching and the line
and column were not. Further, when I look at my test cases (all some
pretty close variation of Warren's original) the failing ones all have
the # of the declare in just the right spot as you suggested. I'd not
recognized this was so.
My patch, then, just avoided the assertion in the
LexemePosition::operator== I suppose. I also didn't know the parser
assertions were today on always and I wasn't thinking an assert could
cause the exception.
Quick additional question. Is it the --enable-debug configure flag that
- normally - turns on the pov asserts? I've never verified this
assumption of mine by creating a pov assert in the code I know should
fail.
Bill P.
Subject: Re: Parse error:Uncategorizederrorthrownatparser/parsertypes.cppline62
Date: 26 Mar 2019 08:10:24
Message: <5c9a16b0$1@news.povray.org>
Am 26.03.2019 um 11:46 schrieb William F Pokorny:
> assumption of mine by creating a pov assert in the code I know should fail.
To be honest, I haven't a clue. I'm not sure what the `--enable-debug`
flag does exactly (it's some standard mechanism in the Automake tools),
nor whether and how assertions are enabled or disabled in Unix builds.
I'm pretty sure that `--enable-debug` does enable the creation of debug
information in the binaries, so that a debugging tool can correlate
binary code addresses with original source code lines, so that you can
e.g. set breakpoints and step through the code line by line with a
debugger. I also wouldn't be surprised if it turns off optimizations by
default, because those tend to re-order instructions and make a
line-by-line correlation impossible. Whether it does anything beyond
that I do not know. It might dictate whether `NDEBUG` is defined or not,
which would conceivably disable/enable assertions.
