POV-Ray : Newsgroups : povray.bugreports : Odd behaviour with sphere_sweep Server Time
30 Mar 2026 10:07:56 EDT (-0400)
  Odd behaviour with sphere_sweep (Message 1 to 6 of 6)
Subject: Odd behaviour with sphere_sweep
Date: 10 Jan 2016 11:20:01
Message: <web.5692847b8bcbbc2219f71b680@news.povray.org>
I'm using sphere_sweep with cubic_spline to try to get a nice smooth curve, but
part of it is missing:
#version 3.5;
global_settings { ambient_light 0 assumed_gamma 1 }
background { rgb 0.05 }
light_source { <0,+1000,0> rgb 1 }
sphere_sweep
    cubic_spline
        6,
        < 0 ,  48 ,  277 >, 1
        < 0 ,  88 ,  166 >, 1
        < 0 , 115 ,   55 >, 1
        < 0 , 115 ,  -55 >, 1
        < 0 ,  88 , -166 >, 1
        < 0 ,  48 , -277 >, 1
        tolerance 0.1
        pigment { color < 1 , 1 , 1 > }
        finish { emission 1 }
camera
    perspective
    location < 320 , 100 , 0 >
    angle 80
    look_at  <   0 ,   0 , 0 >
The behaviour with linear_spline is also odd, there's a spike in the middle.  I
can't see what I might be doing wrong.  I'm using version
3.7.0.msvc10-sse2.win32 on Windows XP.  Any suggestions?
Chris
Subject: Re: Odd behaviour with sphere_sweep
Date: 10 Jan 2016 12:35:17
Message: <56929655@news.povray.org>
rve, but
> #version 3.5;
Are you sure ? (if yes... then emission in finish is not a good idea )
> sphere_sweep
>     cubic_spline
>         6,
>         < 0 ,  48 ,  277 >, 1
>         < 0 ,  88 ,  166 >, 1
>         < 0 , 115 ,   55 >, 1
>         tolerance 0.1
There is something strange with cubic spline:
* povray 3.6 binary gives a continuous curve
* povray 3.7 (stable, master, and others...) gives a curve splitted in
the middle.
Such split does not happen with linear_spline
> camera
>     perspective
>     angle 80
ddle.  I
Download 'strange.png' (8 KB) Download 'strange.pov.txt' (1 KB) Download 'strange36.png' (9 KB)
Preview of image 'strange.png'
Preview of image 'strange36.png'
Date: 10 Jan 2016 12:55:10
Message: <56929afe@news.povray.org>
> the middle.
I see the same, but will add if you gradually move the Y position of the
camera 100 -> 500 results gradually look better until at about 500
things look OK.
Internal bounding issue?
Bill P.
Date: 10 Jan 2016 15:12:58
Message: <5692bb4a$1@news.povray.org>
Am 10.01.2016 um 18:55 schrieb William F Pokorny:
>> the middle.
> things look OK.
Looks pretty much like that. 3rd-order polynomial (e.g. cubic) splines
are known to sometimes botch the bounding box computation.
Date: 26 Apr 2016 09:44:13
Message: <571f70ad$1@news.povray.org>
>>> the middle.
>> things look OK.
I was reminded of this issue the other day and have been doing some more
investigation.
I spent a lot of time comparing 3.6 to 3.7 code given 3.6 works only to
find nothing. I finally stumbled across the fact the bounding mechanism
is always on in 3.7. In other words (-MB<n> / +MB<n>) doesn't function 3.7.
In 3.6 we need 3 shapes (I think) or more for the bounding mechanism to
trigger and we have 1 so internal bounding is off.
Is this the -MB / +MB mechanism supposed to work in 3.7 ? We changed the
default threshold in the docs to 25 so guessing yes. I could find no 3.6
-> 3.7 change notes related to it.
The issue behind is just another issue with the bounding computation as
you thought Christoph, and it is sitting there in 3.6 too - if we turn
bounding on with +MB1.
Basically the current mechanism multiplies the radius of each sphere by
2 and in this case here where the radius is small, but the range is a
couple orders of magnitude larger, that 2x just isn't enough. This even
though the curve is a pretty gentle cubic as curves go.
The multiplier should probably fudge upward from 2 by default if the
range for the curve is large compared to the radius. Another more
general option would be to add a new keyword to the sphere_sweep which
lets the user optionally control the bounding radius multiplier?
Bill P.
Date: 27 Apr 2016 07:25:09
Message: <5720a195$1@news.povray.org>
> investigation.
I opened a github issue for this. See:
https://github.com/POV-Ray/povray/issues/59
Bill P.
