POV-Ray : Newsgroups : povray.bugreports : mesh camera ouput uv-mapping has a seam when I using the texture : Re: mesh camera ouput uv-mapping has a seam when I using the texture Server Time
21 Jul 2026 03:50:44 EDT (-0400)
Date: 16 Feb 2025 04:15:00
Message: <web.67b1ab9a2273a31e4a994e21aa81652d@news.povray.org>
> "And" <49341109@ntnu.edu.tw> wrote:
> > Maybe I have post this issue several years ago.
> > When I use mesh_camera to output a uv-map texture(for other 3D software), I
> > found that the rendered area is not enough, it should extend the render area.
> > Has these problem been solved?
> > attachment is POV-Ray's output.
> We're going to need WAY more information to figure that one out.
> What model are you using?
> What is the POV-Ray scene and mesh camera setup you're using to generate your uv
> map?
> What uv vectors are being used to wrap the generated image for uv-mapping?
> 1. That's a pretty complex work flow, where SO many things can go wrong, if only
> because of floting point precision, etc.
> 2. I'm sure people here would love to learn how to use this method for their own
> work - thus ensuring that all of the tools needed to make this work get the
> attention and fixing that they need!
> - BW
Every model it has this issue.
mesh_camera {
    distribution_type 3
Because its color only covers the area of the model.
I show you a uv-mapping texture generated by Blender 3D:
Its color covers not only the area of the model, it generate a margin area, too.
It can control margin size (for this example I set 16 px), type("extend" or
using "adjacent faces")
Download 'block color.png' (469 KB)
Preview of image 'block color.png'
