POV-Ray : Newsgroups : povray.binaries.utilities : Wood program but still develop Server Time
6 Apr 2026 11:19:50 EDT (-0400)
  Wood program but still develop (Message 61 to 68 of 68)
Subject: Re: Wood program but still develop
Date: 4 Sep 2023 20:10:00
Message: <web.64f671425b6ed241f9dae3025979125@news.povray.org>
I have to tell you, this is a tough problem, to make a fully procedural wood
texture.
I think a lot of things have to be "fixed" in order to get good results - like
color-map cycling, the behaviour of the modulo operator across the origin, and
the domain of user generated functions.
I got a very rough simulation, but it's a layered texture, to get the checking
(cracks) and spalting.
To get a better wood, there would have to be knots and burls in 3D so that it
could also be used as an isosurface.
- BW
Download 'radialfunctions.png' (322 KB)
Preview of image 'radialfunctions.png'
Date: 13 Sep 2023 08:35:00
Message: <web.6501ab845b6ed24810660feaa81652d@news.povray.org>
> texture.
No no...
Make a fully procedural wood texture is interesting to me. It is keep my
attention these days.
I solved color-map cycling by creating main part of pigment (using function) ,
such function change its value from 0~1~0 every year. It has been done, so I
don't concern it anymore.
"The domain of user generated function" means I needs provide something flexible
for user to apply their own function. Before that time I can offer the standard
function which I developed.
How do you get such black spalting?
> - BW
I will add knots in my output pigment pattern when I prepare enough code. But
they are just pattern, not a 3D shape.
Date: 13 Sep 2023 13:25:00
Message: <web.6501eff25b6ed241f9dae3025979125@news.povray.org>
#declare Crack1 =
color_map {
 [0.00 rgb 1]
 [0.50 rgb 1]
 [0.50 rgb 0]
 [0.55 rgb 0]
 [0.51 rgb 1]
 [1.00 rgb 1]
#declare Spalting = function {pigment {leopard turbulence 1 color_map {Crack1}}}
Date: 17 Oct 2023 03:55:00
Message: <web.652e3d565b6ed24103bf166aa81652d@news.povray.org>
I think I should learn Javafx first to rewrite it. My knowledge of design
program is not enough.
Date: 14 Feb 2024 17:05:00
Message: <web.65cd38fc5b6ed241f9dae3025979125@news.povray.org>
Here's a dispersion pattern I found that seems to also make a good wood ring
pattern.
https://en.wikipedia.org/wiki/Dispersion_(water_waves)#Dispersion_relation
https://www.desmos.com/calculator/dzrqmexxik
#declare T_wave = 0.5; // -10 to 10 in example
#declare FWave1 = function {sum (k_wave, 0.3, 3, mod ( (sqrt(x*x+y*y) - sqrt
(9.81*k_wave*3)*T_wave)*k_wave*3, 2*pi) <= 1)}
#declare FWave2 = function {sum (k_wave, 0.3, 3, abs ( (sqrt(x*x+y*y) - sqrt
(9.81*k_wave*3)*T_wave)*k_wave*3) <= 0.3)}
#declare Formula201 = function {(FWave1 (x, y, z) + FWave2 (x, y, z))/2}
plane {z, 0 pigment {function {Formula201 (x,y,z)} } }
Add 2 different color maps for light and dark wood, and it should look a lot
better.
Download 'mathpatterns1.png' (334 KB)
Preview of image 'mathpatterns1.png'
Date: 10 Apr 2024 02:15:00
Message: <web.66162d0a5b6ed24a432d90aa81652d@news.povray.org>
> pattern.
> better.
I see this idea describing...
"when annual ring pattern is not very clear"
Date: 11 Apr 2024 07:00:00
Message: <web.6617c21b5b6ed241f9dae3025979125@news.povray.org>
I just posted it to show that there are a lot of functions out there, and we can
mix and match them to eventually get the final result that we're looking for.
Whereas some base patterns may be well suited to modification and perturbation
in certain ways, others may not be.
So I think that at the present, in the absence of anything concrete, it's good
to compile a list of options, and then see what the strengths and weaknesses of
them are, and proceed from there.
And at some future point, someone may find it useful for some thing that's - not
wood.
- BE
Date: 15 Apr 2024 23:30:00
Message: <web.661df07d5b6ed24b242481caa81652d@news.povray.org>
> wood.
> - BE
Well.
