POV-Ray : Newsgroups : povray.binaries.tutorials : How to render mirrored objects into _real_ pictures Server Time
27 Mar 2026 03:22:30 EDT (-0400)
  How to render mirrored objects into _real_ pictures (Message 1 to 4 of 4)
Subject: How to render mirrored objects into _real_ pictures
Date: 12 Jan 2009 17:20:00
Message: <web.496bc004fe4d566620776f0@news.povray.org>
This is a simple tutorial that shows you to render chrome-textured objects into
real pictures, taken by your photo-camera.
You need:
-A camera (optional a stand)
-A Chrome-Ball
-Megapov
- Put the ball almost to the place, where you like to have the 3d-object.
- Make a Photo (best, from far away with a narrow angle. Otherwise, you see your
self..)
- Make a second picture without the ball from almost the same place (best with a
stand)
- Crop the Ball picture
- Use the cropped picture as image-map for the environment sphere
(shrinkwraped!!),"no_image"
- Use the other picture as image.map for the background-plane
(screen.inc),"no_reflection"
have fun :)
PS.: Compare the image-numbers in the scene with the numbers in the uploaded
image.
#include "screen.inc"
Set_Camera_Location(<0.0, 0.5, -4.0>)
Set_Camera_Look_At(<0.0, 0.0,  0.0>)
Set_Camera_Aspect(image_width,image_height)
#declare T=texture{pigment{
image_map {
  jpeg "3.jpg"
  map_type 0
  interpolate 2
finish{ambient 1}
object{
Screen_Plane (T, 1000, <0,0>, <1,1>)
no_reflection
sphere {
  0.0, 1
image_map {
  jpeg "2.jpg"
  map_type 7
  interpolate 2
finish{ambient 1}
scale <-1,1,1>
scale 1000
rotate y*180
no_image
julia_fractal {
  <-0.083,0.0,-0.83,-0.025>
  quaternion
  cube
  max_iteration 4
  precision 20
finish{reflection 1}
//optional...
rotate <frame_number,frame_number*2,frame_number*4>
scale 0.3
translate <.35,-0.2,0>
Download 'chrome-map.png' (112 KB)
Preview of image 'chrome-map.png'
Subject: Re: How to render mirrored objects into _real_ pictures
Date: 14 Jan 2009 22:05:00
Message: <web.496ea74bcb35516a245002290@news.povray.org>
This has tripped me up, but I believe that the image of the mirror ball, and the
megapov "maptype 7" mapping are different. Paul Debevec explains it on
http://www.debevec.org/probes/
steradians. Also note that the mapping being used is different than the mapping
one observes in a mirrored ball -- the mapping we're using avoids the problems
of poor sampling near the backwards-facing directions around the circumference
of the image."
Cheers,
Edouard.
Date: 15 Jan 2009 06:00:00
Message: <web.496f16c5cb35516aaf8dfc8f0@news.povray.org>
They are different indeed.
For the plain viewing effect it doesn't make a difference though. And if you
need correct mapping, "HDRShop" is what you want to go for.
Date: 16 Jan 2009 09:15:02
Message: <web.49709630cb35516a7fad02d40@news.povray.org>
That explaines a view strange things, I've had in a view scenes.
Thanx :)
