![](/i/fill.gif) |
Sample image in p.b.i.
Paolo
%<-------------------------- cut here ----
// POV-color picker
// Paolo Gibellini 2005
// A simple wallpaper: +H1280 +W1024 +A0.1 (for straight lines AA 0.1 is
better)
Parameters
cubes: size of the color cube
n.b. increasing this number could be very memory-consuming (with 256 Mb I
cannot use more than 100 cubes)
tipo: type of the color 0=solid, 1=semitransparent, 2=metallic
random seed determines position (picking) of the color dropper and the color
of the dropper itself
#version 3.5;
// Impostazioni globali ------------------------------------
global_settings {
assumed_gamma 1.0
max_trace_level 5
// Ambiente ------------------------------------------------
sky_sphere {
gradient y
color_map {
[0.0 rgb <0.6,0.7,1.0>]
[0.7 rgb <0.0,0.1,0.8>]
light_source {
<0, 0, 0> // light's position (translated below)
color rgb <1, 1, 1> // light's color
translate <-30, 30, -30>
// Parameters ----------------------------------------------
#declare cubes=8; /* Size of the color cube */
#declare tipo=2; /* 0=solid, 1=semitransparent, 2=metallic */
#declare s=seed(39); /* Random seed (determines position of the color
dropper and the color of the dropper itself) */
// Random --------------------------------------------------
#macro r(m)
rand(s)*m
// Textures ------------------------------------------------
#declare t_cromata=texture {
color rgb <0.8,0.8,1.0>
finish{
diffuse 0.3
ambient 0.0
specular 0.6
reflection {
0.8
metallic
conserve_energy
#declare t_onde= texture {
normal {
waves
finish{
diffuse 0.3
ambient 0.0
specular 0.6
reflection {
0.8
// Moray's NBoldglass
#declare NBoldglass = material {
color rgbf <0.8, 0.9, 0.85, 0.85>
finish {
ambient 0.1
diffuse 0.1
specular 1.0
roughness 0.001
reflection 0.25
interior {
ior 1.5
// Camera --------------------------------------------------
location <-cubes*0.8, cubes*0.6, -cubes*3.5>
direction 1.5*z
look_at cubes/2
// Un po' di scena -----------------------------------------
plane {
y, -3
texture {t_onde scale cubes}
sphere {
<-cubes/2,cubes/1.8,cubes/2>, cubes/3
texture {t_cromata}
// color dropper -------------------------------------------
#declare cx=(r(cubes))*0.6+cubes*0.2;
#declare cy=(r(cubes))*0.6+cubes*0.2;
#declare cz=(r(cubes))*0.6+cubes*0.2;
cylinder {<cx,cy,cz> <cubes*0.8,cubes*0.9,-cubes*1> 0.2*(cubes/10)
pigment {color rgbft <cx/cubes,cy/cubes,cz/cubes,0.6,0.3>}
cylinder {<cubes*0.8,cubes*0.9,-cubes*1> <cubes*0.8,cubes*0.7,-cubes*1.35>
0.2*(cubes/10)
pigment {color rgbft <cx/cubes,cy/cubes,cz/cubes,0.3,0.3>}
// Glass ---------------------------------------------------
difference {
cylinder {<cubes*0.8,cubes*0.8,-cubes*1.3>
<cubes*0.8,cubes*0.35,-cubes*1.3> 1.1*(cubes/10)}
cylinder {<cubes*0.8,cubes*0.8,-cubes*1.3> <cubes*0.8,cubes*0.4,-cubes*1.3>
1*(cubes/10)}
material {NBoldglass}
cylinder {<cubes*0.8,cubes*0.7,-cubes*1.3> <cubes*0.8,cubes*0.4,-cubes*1.3>
1*(cubes/10)
pigment {color rgb <cx/cubes,cy/cubes,cz/cubes>}
// Colors --------------------------------------------------
#declare rx=0;
#declare gy=0;
#declare bz=0;
#while (rx<cubes)
#declare gy=0;
#while (gy<cubes)
#declare bz=0;
#while (bz<cubes)
#switch(tipo)
#case(1)
box {<rx,gy,bz>, <rx+0.8,gy+0.8,bz+0.8> pigment {color rgbft
<rx/cubes,gy/cubes,bz/cubes,0.6,0.3>}}
#break
#case(2)
<rx/cubes,gy/cubes,bz/cubes> } finish{diffuse 0.3 ambient 0.0 specular 0.6
reflection {0.8 metallic}}}
#break
#else
<rx/cubes,gy/cubes,bz/cubes>}}
#declare bz=bz+1;
#declare gy=gy+1;
#declare rx=rx+1;
Download 'color_picker_03_en.zip' (2 KB)
![](/i/fill.gif) |
