![](/i/fill.gif) |
NetDave nous apporta ses lumieres en ce 2007/10/26 00:47:
> See discussion in pbi.
You have coincident surfaces between the bottom of the cone and the ground plane.
Change your plane to:
plane
y, -1.01
texture
T_Wood35
scale <50, 50, 50>
rotate <0, 45, 0>
OR the cone to:
cone
<0,0,0>, 5.5, <0,11,0>, 0
translate <-8, -0.99, 17>
texture
Now, the bottom of the cone is very slightly above the plane and the speckeling
goes away.
You should convert your BMP's to JPG, or PNG. Much smaller.
Add +fn to the command line or "povray.ini" tou outpus as PNG. There is no
switch to output as JPG.
Rebellion against tyrants is obedience to God.
Benjamin Franklin
![](/i/fill.gif) |
