POV-Ray : Newsgroups : povray.binaries.images : workbench9.png Server Time
15 Jan 2025 05:23:46 EST (-0500)
Subject: workbench9.png
Date: 19 Apr 2023 16:00:00
Message: <web.644047384e5c02659197626dabc9342@news.povray.org>
Progress rendering of workbench area with more destressed surfaces. Increased
the cmu mortar depth and deepened the texture and grunge. I have a few more
surfaces to dirty-up. Still tweaking the conduit pipe material. Need to fix a
few bitmap stretch marks.
Miller
Download 'workbench9.png' (3809 KB)
Preview of image 'workbench9.png'
Subject: Re: workbench9.png
Date: 19 Apr 2023 16:45:00
Message: <web.64405241299a4b841f9dae3025979125@news.povray.org>
> Miller
I have to say - you work FAST!  :O
Also, you went straight from "this is my artisanal repurposed hardwood workbench
in my newly constructed 1.4 mil suburban basement" to "OMG - I just wound up in
the basement of the serial killer in Suspect Zero ...  is that blood spatter?"
I think once you add in that totally creeptastic Jack, you're going to be
achieving one scary as F render!
Throw in a few rusty dental and surgical implements, and some repurposed human
flesh for the Jack....   You've got a real horror show there.
Quaternions:
https://news.povray.org/povray.binaries.scene-files/thread/%3C3f81dba5%40news.povray.org%3E/
Date: 19 Apr 2023 17:35:00
Message: <web.64405e79299a4b8459197626dabc9342@news.povray.org>
> > Miller
> Quaternions:
Haha...now you got me thinking. :)
This basement could be the backdrop to lots of creepy concepts.
> Quaternions:
https://news.povray.org/povray.binaries.scene->files/thread/%3C3f81dba5%40news.povray.org%3E/
Thank you!... I've been looking for this. And if you pointed me to this earlier,
my apologies. I tried adding quaternion rotations to my Blender export utility
and got hung up on the 'convert to euler' math.
I have a question and I'm sure it's been asked many time:
In run time, can you access/read the pixel values in a loaded bitmap?
Thanks, Mike.
Date: 19 Apr 2023 18:35:00
Message: <web.64406c46299a4b841f9dae3025979125@news.povray.org>
I somehow knew you'd be inspired.  :D
> > Quaternions:
Yes Sir.
In "functions.inc" you will find a macro as a wrapper for a function.
#macro eval_pigment(pigm, vec)
    #local fn = function { pigment { pigm } }
    #local result = (fn(vec.x, vec.y, vec.z));
    result
POV-Ray of course loads it into a unit square, and so you have to scale it, but
that can be done with some extent calculations and scaling.
My standard cut-n-paste code for that is:
#declare Feet = 12;
#declare XSize = 4*Feet;
#declare ImageMap = pigment {image_map {png "AlphaMirror4.png" once} };
#declare Resolution = max_extent (ImageMap);
#declare Resolution = Resolution + <0, 0, 1>;
#declare Photo1 =
 box {0, 1
   ImageMap
  translate <-0.5, -0.5, -0.5>
  scale Resolution2*(1/Resolution2.x)*XSize
If you need implementation code for eval_pigment, just let me know.
- BW
Date: 19 Apr 2023 20:05:00
Message: <web.644080a4299a4b8459197626dabc9342@news.povray.org>
> > > Quaternions:
> Yes Sir.
>     result
> #end
> #declare Feet = 12;
> #declare Photo1 =
>  box {0, 1
>   texture {
>    ImageMap
> - BW
Thank you so much! This is perfect.
I'll let you know if I need help on this once I review the macros. First
thoughts are maps for object placement or scatter restrictions.
You rock.
Date: 21 Apr 2023 11:10:40
Message: <6442a770@news.povray.org>
> Miller
Initially, it was a brand new work area, all freshly painted.
Now, we have the same place, but about 10 years later.
