POV-Ray : Newsgroups : povray.binaries.images : New Characters for Master of Puppets Font Server Time
18 May 2024 08:32:37 EDT (-0400)
  New Characters for Master of Puppets Font (Message 8 to 17 of 27)
<<< Previous 7 Messages Goto Latest 10 Messages Next 10 Messages >>>
Subject: Re: New Characters for Master of Puppets Font
Date: 6 Apr 2022 10:01:36
Message: <624d9d40$1@news.povray.org>
Le 2022-04-06 à 08:27, jr a écrit :
> hi,
> "Dave Blandston" <IsN### [at] protonmailch> wrote:
>> #declare MOP_UseFrenchQuoteMarks = yes;
>> Let me know if I didn't do it right...
> you didn't do it right !!  :-)
> File 'mopfont.inc' line 3704: Parse Error: Unable to file seek in macro.
> Fatal error in parser: Cannot parse input.
> Render failed
> attached renders fine until enabling the new quotes.
> regards, jr.
When I try to render your scene, I get this error on line 520 of
MasterOfPuppetsFont.inc :
«Parse error: No matching }, ; found instead.»
          #local A1 = 2 * ComputeCornerLength (180 + A_A0, 0, R,
CornerRadius); //Width of flat part
Date: 6 Apr 2022 10:07:24
Message: <624d9e9c$1@news.povray.org>
Le 2022-04-05 à 22:14, Dave Blandston a écrit :
> Alain Martel <kua### [at] videotronca> wrote:
>> How about the French quotes ? « »
> That was a great idea! Support for French quotes has been implemented. Just set
> this variable in your scene file:
> Kind regards,
> Dave Blandston
Sorry, but, I can't use your font.
I get this error on line 520 of MasterOfPuppetsFont.inc :
Latest official version 3.8 under Windows 11.
Date: 6 Apr 2022 10:50:00
Message: <web.624da6b580354cb3fc0c8de6cde94f1@news.povray.org>
hi,
my bad, the above was using alpha.9945627.  tried 'beta.1' and 'beta.2', both
same as the alpha, all on a Slackware GNU/Linux box.  interestingly, WFP's
'povr' sees same/similar error as yours, but on a different line.  </grin>
File 'mopfont.inc' line 578:
Parse Warning:
Should have at least 2 objects in csg.
File 'mopfont.inc' line 577:
Possible Parse Error:
Unmatched {
Parse Error:
regards, jr.
Date: 6 Apr 2022 16:30:00
Message: <web.624df77580354cb3ee1b05ae607c1b34@news.povray.org>
"jr" <cre### [at] gmailcom> wrote:
> hi,
> Render failed
> regards, jr.
Oh my, I think this may be an issue with different versions of POV-Ray. I'm
still using version 3.7. Those error messages that you guys are getting don't
seem to make sense but I don't have version 3.8 installed to duplicate the
problem. I tried your scene without any changes except I put the version back to
3.7 and added a plain white texture to the objects and here's what I got:
(I really like the quote, by the way!)
Download 'quote1.png' (35 KB)
Preview of image 'quote1.png'
Message: <web.624df7bf80354cb3ee1b05ae607c1b34@news.povray.org>
And enabling the French quotes:
Download 'quote2.png' (35 KB)
Preview of image 'quote2.png'
Date: 7 Apr 2022 09:30:00
Message: <web.624ee63d80354cb35834ab476cde94f1@news.povray.org>
hi,
same here, v3.7.0.8 works when making those changes.  it would be useful to hear
a developer's view.  (is there a reason you do not want to run v3.8?)
"ancient wisdom"  ;-)
regards, jr.
Date: 7 Apr 2022 10:38:39
Message: <624ef76f$1@news.povray.org>
>> hi,
>> Render failed
>> regards, jr.
Yes. It works using version 3.7, but not when using version 3.8.
Strange...
Date: 7 Apr 2022 11:02:27
Message: <624efd03$1@news.povray.org>
> Parse Warning:
> Unmatched {
> Parse Error:
The issue is the newer versions of the parser see the second of two
semicolons - ';;' - as meaningful.
This partly due parser optimizations / changes. It's also a good idea
for ';;' to cause parse errors as the extra semicolons - from macros
especially - can cause difficult to understand behavior where unluckily
positioned in the SDL.
The definition of the ComputeCornerLength macro ends with:
abs (L0 * cos (radians (MiddleAngle)));
It should be something like:
(abs (L0 * cos (radians (MiddleAngle))))
given it's calculating a return value.
Bill P.
Aside: My current povr issues warnings for the bounded_by usage in the
include file. This user bounding is likely getting stripped given +UR
now long the default. My v3.7 and v3.8 official versions issue no
warnings at all(a). I don't remember making any changes specifically to
get the warnings - FWIW.
(a) - Despite claims all user bounding is getting stripped by default,
there are a few obscure exceptions in the official versions of POV-Ray
where user bounds are respected no matter the +ur/-ur settings. The povr
fork changed the code so +ur/-ur always strips the user bounding, or
not, on the +ur/-ur setting. It might be the difference in warnings here
is due bounded_by usage that happens to be one of the v3.7/v3.8,
official release, 'hidden / always use a user's bounded_by' exceptions.
I didn't investigate.
Date: 7 Apr 2022 15:30:00
Message: <web.624f3ad380354cb3ee1b05ae607c1b34@news.povray.org>
Thank you Bill! That works for version 3.7 and I hope it works for everyone else
as well. I posted the updated file. It's been my experience that different
macros seem to need to return values in different ways, and each macro requires
some experimentation to figure what will work for that particular one. Sometimes
the semicolon needs to be inside the macro, sometimes it needs to be outside,
sometimes the parenthesis method works and sometimes not, and I even have one
macro that I use regularly that can't seem to return a value at all - I have to
assign the value to a global variable inside the macro then access that
variable. I guess that's one of the charms of the particular build of POV-Ray
that I'm using.
Regarding the bounded_by feature, I made that particular object so long ago that
I don't even remember if I was using the command line switches or not. The
Metallica logo was the first object I made with POV-Ray about thirty years ago.
Have a wonderful day everyone!
Kind regards,
Dave Blandston
Date: 7 Apr 2022 22:54:32
Message: <624fa3e8$1@news.povray.org>
I decided long ago to sidestep bounded_by issues by avoiding bounded_by
altogether. When I need to bound something manually, I just do an
intersection with the bounding shape.
