POV-Ray : Newsgroups : povray.binaries.images : First image posting Server Time
31 Oct 2024 19:06:19 EDT (-0400)
  First image posting (Message 12 to 21 of 41)
Subject: Re: First image posting
Date: 1 May 2021 22:20:58
Message: <608e0c8a$1@news.povray.org>
On 2021-04-30 3:40 PM (-4), Chris R wrote:
> I am working on a new project with bricks around a lighthouse (cone).  I'll look
> into the blockwall macros for that as well.  I have had issues getting access to
> the POV-Object collection after the server crash.
I believe the Object Collection is still down.  It does not respond to
pings.  Chris Cason reported that bringing it back online will take more
time than he can budget right now.
In the meantime, Le Forgeron has mirrored all the modules as of April 2019:
  https://github.com/LeForgeron/PovContributions
Date: 2 May 2021 02:47:28
Message: <608e4b00$1@news.povray.org>
Op 01/05/2021 om 13:26 schreef Bald Eagle:
>> Yes, that is certainly true indeed. Try to find the balance.
>> Sometimes/often, stochastic anti-aliasing helps for the grainy distance
>> mess.
> Presumably, this is what all this "mip-mapping" business is about.   Has anyone
> ever tried to emulate that process, that we know of?
Good question. It would be interesting to try indeed. RoundTuits are
needed however!
Date: 2 May 2021 08:15:00
Message: <web.608e9704f7d27fe1f9dae3025979125@news.povray.org>
> needed however!
https://www.youtube.com/watch?v=0flY11lVCwY
He covers this briefly in the first 2 minutes.
Just shooting from the hip here, but it sounds like a functional emulation of
this would be to start with a very large, high-def version of the texture and
then make a few smaller versions.   Then just have an array of the filenames and
the texture could probably be automagically sampled at the desired resolution
using a polynomial function like I did in the vortex scene or using a spline
like Ingo is doing.
Maybe there's some kind of MOA (minutes of angle) calculation that initially
gets done to optimally set the different image_map resolutions...?
Date: 3 May 2021 02:36:24
Message: <608f99e8$1@news.povray.org>
Op 02/05/2021 om 14:11 schreef Bald Eagle:
>> needed however!
> like Ingo is doing.
By default, a factor 2 scaling is used, I understand. That is not
difficult; what is (at least for me) is how to chose the right texture
for each render or location in the scene (for instance the background of
a chequered plane smoothly grading into the foreground). Well, I have an
idea of course, but no time to test it out presently. :-/
Hmm... possibly. I have no idea at this stage however.
Date: 3 May 2021 02:48:11
Message: <608f9cab$1@news.povray.org>
Op 03/05/2021 om 08:36 schreef Thomas de Groot:
>>>> Has anyone
>>> needed however!
>> emulation of
>> texture and
>> filenames and
>> resolution
>> spline
>> like Ingo is doing.
>> initially
And I immediately come back to the matter as I suddenly realise that
this would be a crucial technique for using the same granite textures
(forgive me my present obsession with granites) in close foreground
views and landscape-sized backgrounds. Or wouldn't it? Is mipmapping
only useful with image_maps? The examples I have seen so far are just
that. Could it be applied successfully to traditional POV-Ray textures?
Date: 3 May 2021 03:25:00
Message: <web.608fa41ff7d27fe79819d986cde94f1@news.povray.org>
hi,
no idea but reading yr exchange led me to this Wiki page:
<https://en.wikipedia.org/wiki/Mipmap>
regards, jr.
Date: 3 May 2021 04:20:00
Message: <608fb230$1@news.povray.org>
Op 03/05/2021 om 09:19 schreef jr:
> hi,
Thanks, yes, I also found that page indeed :-)
Well, should have done that first of all, but the following (hot)
discussion about mimapping with POV-Ray from 2005 can be found here:
http://news.povray.org/povray.newusers/thread/%3C4282a2e9%40news.povray.org%3E/
I conclude from that, that aa is the ray-tracing answer to mipmapping,
and I guess that my initial suggestion of stochastic aa is the correct one.
Date: 3 May 2021 05:15:00
Message: <web.608fbe56f7d27fe79819d986cde94f1@news.povray.org>
hi,
> I conclude from that [thread], that aa is the ray-tracing answer to mipmapping,
taking the 'El Capitan' cliff face as an example, say I want to render two
images: object near base of, and object some distance from.  then I need to
choose a scale for the texture(s)?  I think that I (as in "numpty" etc) would
benefit from having some row/col table, in the documentation and or as array, of
all parameters involved ("lambda", "octave", such) by scale/suggested distance
(in POV-units?).  (and perhaps a macro which expands to the texture at the given
scale/index)  (just thinking aloud :-))
regards, jr.
btw, re "graveyards".  had to put on an anorak, even for a cursory read.  :-)
found out that what I associate with "granite" really is "dolerite".  thanks.
Date: 3 May 2021 06:35:00
Message: <web.608fd1a5f7d27fe1f9dae3025979125@news.povray.org>
I guess you could have a macro generate the texture, and have an AutoScale
argument.  The distance from the camera to the closest object (user-supplied
value) could be used to set the scale.  Might need to set a pov unit = real
world measurement ratio and base everything off that.
Date: 3 May 2021 07:33:04
Message: <608fdf70$1@news.povray.org>
Op 3-5-2021 om 11:11 schreef jr:
> hi,
Yes, I guess that is the crucial point here. Otoh, It can also be solved
by using a much simpler texture for the background, involving the same
colour_map scaled down, and without all the fancy stuff...
> regards, jr.
<grin> They are often mixed-up.
