POV-Ray : Newsgroups : povray.binaries.images : Rotation matrices Server Time
25 Mar 2026 00:45:37 EDT (-0400)
  Rotation matrices (Message 2 to 11 of 15)
<<< Previous 1 Messages Goto Latest 10 Messages Next 4 Messages >>>
Subject: Re: Rotation matrices
Date: 4 Apr 2021 19:10:00
Message: <web.606a463b565eea12d6f19eb189db30a9@news.povray.org>
> Since we use a left-handed coordinate system, and rotation matrices can be a bit
> confusing - especially at first - I made a sketch, and then decided it ought to
> be added to the collection of documentation diagrams I'm making.
> Here is a supplementary illustration - it could probably use some polishing.
Nice illustration.
To improve it I suggest that you remove the decimals. This will give you some
more space and make it easier to read.
I also suggest that you insert a note to the reader that POV-Ray's trigonometric
functions use radians, not degrees as in you basis vector lists.
Further; some of the equal signs have become minus signs. Could this be caused
by some scaling of the image ?
Tor Olav
http://subcube.com
https://github.com/t-o-k
Date: 4 Apr 2021 20:10:00
Message: <web.606a545e565eea121f9dae3025979125@news.povray.org>
"Tor Olav Kristensen" <tor### [at] TOBEREMOVEDgmailcom> wrote:
> Nice illustration.
Thank you, Sir.
Yes, I was waffling on that - too many, too few...   hard to judge.
It's always tough to try to squeeze a lot of information into a limited space.
There's a weird 3-fold aspect to the way the vectors are represented in the
matrices that I'm trying to capture, but unsure what the best way to go about it
is.   Each row is an x, y, z basis vector.   Each column of that row is an x, y,
z vector component.  And then the final transform is the "sumproduct" for all of
the columns - the x' vector is x.x + y.x + z.x + w.x
So I left all of that criss-crossing out for now. ;)
> functions use radians, not degrees as in you[r] basis vector lists.
I will keep that in mind.  I have one or two other "documentation illustrations"
in mind.  I would also like to figure out if there's a nice
degrees-to-fractions-of-pi algorithm out there, and I could implement that.
I'll probably just hard-code an array of text objects.
IIRC, it's an antialiasing thing.  I noticed it, but let it slide, hoping for
more feedback before I revised the entire thing.   Maybe I'll see if I can find
a bold font to replace 'timrom' with.
Or maybe I'll just scale the font in the y-direction a little bit to thicken the
horizontal lines.
Do you watch 3blue1brown's channel?   It's - peaceful, and elegant, and
mesmerizing.  It's one of the best things to happen to math in a long while.
Date: 5 Apr 2021 02:24:25
Message: <606aad19$1@news.povray.org>
Op 05/04/2021 om 02:05 schreef Bald Eagle:
> horizontal lines.
or use stochastic aa. That would solve the problem in an elegant way.
Nice work, sir. Very useful indeed.
Date: 5 Apr 2021 07:10:00
Message: <web.606aefb5565eea121f9dae3025979125@news.povray.org>
You've gotta school me in that black art.   Although I have delved deeply into
some of the more esoteric areas of POV-Ray, through neglect, I still have the
lowest level of understanding with regard to the antialiasing settings.
is that the +ua or the +am3, or another one... ?
Date: 5 Apr 2021 11:38:28
Message: <606b2ef4$1@news.povray.org>
Op 5-4-2021 om 13:08 schreef Bald Eagle:
I currently use:
// +am3 +a0.01 +ac0.90 +r3
Which gives me good results. Higher settings, but slower, would be:
// +am3 +a0.001 +ac0.99 +r4
And faster, but uglier, good for testing, something like:
// +am3 +a0.1 +ac0.80 +r2
Date: 5 Apr 2021 16:55:00
Message: <web.606b78af565eea121f9dae3025979125@news.povray.org>
I tried that, but even that wasn't good enough to make the "=" fully visible.
scaling along y by 1.2 improved matters, but then I just switched over to Times
New Roman Bold and kept the scaling as well.
Changed the angles to radians.
Slight color changes on the tori.
I didn't feel like going full utf8 to get a proper pi character - yet.
Download 'rotationmatrices.png' (416 KB)
Preview of image 'rotationmatrices.png'
Date: 6 Apr 2021 02:07:27
Message: <606bfa9f@news.povray.org>
Op 05/04/2021 om 22:53 schreef Bald Eagle:
It is the results that count. :-)
Date: 6 Apr 2021 13:10:00
Message: <web.606c948f565eea12d98418916e066e29@news.povray.org>
> > trigonometric functions use radians, not degrees as in you[r] basis
> > vector lists.
> in mind.
I usually like to use trig functions in degrees rather than radians-- just
easier to visualize for me. "math.inc" has some simple little 'converter'
functions, sind() and cosd()
So in your diagram, for example...
T5: y'= <0,cosd(180), sind(180>
But for your matrix illustrations, I don't know if they should be used (since I
don't know enough about matrix math).
    like,  -sind  instead of  -sin  ??
Date: 6 Apr 2021 17:20:00
Message: <web.606cd03d565eea121f9dae3025979125@news.povray.org>
I was playing around with some things the other day, writing my function
document,  and noticed that we don't need "math.inc" anymore - at least not in
3.8.   :)
I just put sin and cos because everyone everywhere knows what that is and I
would hope that most people would assume that it's implied that there's a
degrees - to - radians conversion...   But "matrix math" is no different than
"spreadsheet math" or pencil and paper math or chalkboard math....   it's just a
way of laying things out so that the values in the places are operated on by the
appropriate values in the places of other matrices.  Or that the formulas for
things like determinants are using the right values.   No magic.
It's just an organizational thing to make the notation compact.
Just think about it as: array {Vec.x, Vec.y, Vec.z} and then make a 2D array
with 2 or 3 more vectors....
Date: 7 Apr 2021 00:50:00
Message: <web.606d38e0565eea128e52cc8789db30a9@news.povray.org>
> ...  I would also like to figure out if there's a nice
You can divide the angle by 180 and convert the resulting decimal number to a
fraction. Then you can use David Eppstein's "find rational approximation to
given real number" code as suggested in the first answer here:
https://stackoverflow.com/questions/95727/how-to-convert-floats-to-human-readable-fractions
Yes, I've seen some of his videos. Very good =)
I'm looking forward to the rest of them.
Tor Olav
http://subcube.com
