POV-Ray : Newsgroups : povray.binaries.images : Ringworld Server Time
15 Mar 2026 16:40:47 EDT (-0400)
  Ringworld (Message 31 to 40 of 61)
Subject: Re: Ringworld
Date: 14 Oct 2013 03:35:00
Message: <web.525b9e2df2e6f38c5b7d07940@news.povray.org>
> On 13-10-2013 0:41, posfan12 wrote:
> > "posfan12" <nomail@nomail> wrote:
> >> One thing I'd like to know is how many shadow squares are there supposed to be?
> >> If they're supposed to be 2500000 miles long and 13000000 miles from the center
> >> of the sun, then there should be 41 of them assuming they're spaced equally
> >> apart.
> >> Is that right?
> > Damn my math!
> > That should be ~16 not 41.
> According to my macro there are 20. 18 degrees from shadow square center
> to shadow square center; 360/18. I don't remember if this is mentioned
> in Larry Niven's books but it might be.
It is mentioned, once, and I believe the number is indeed 20. He also specifies
their orbit radius, which is sufficient information to render them correctly
(assuming night and day are of equal length).
Bill
Date: 14 Oct 2013 03:40:01
Message: <web.525b9ec8f2e6f38c5b7d07940@news.povray.org>
> For this see e.g.:
> http://news.povray.org/povray.binaries.images/thread/%3C4c249911@news.povray.org%3E/
> Thomas
Another, earlier, detailed discussion here:
http://news.povray.org/povray.binaries.images/thread/%3C43635ed8%241%40news.povray.org%3E/
Subject: Re: Ringworld - a few solutions
Date: 14 Oct 2013 03:57:14
Message: <525ba3da@news.povray.org>
First problem solved.
1) comment out the atmosphere.
2) In your cloud texture, replace the finish either by:
   finish {ambient1 diffuse 1}	// no radiosity
or:
   finish {emission 1 diffuse 1}	// radiosity
3) In your cloud texture, replace the scale by:
   scale ring_width/2000
Now the clouds become visible above the camera. The scale is important
for this view. The Ringworld is so incredibly huge that what looks right
from space is only a grey expanse seen from ground level. Cloud patterns
like on Earth would look tiny on the Ringworld.
4) The problem is your atmosphere which generates the artefact in the
foreground of the image. This seems probably to be an epsilon effect but
I am not so sure about that as without atmosphere the scene renders
properly. I would like the opinion of experts on this.
In any case replace the scattering by:
   scattering {4, <0.1, 0.3, 1.0> * 1000000/ring_radius}
This will make the atmosphere visible.
See the attached image for the state of the art.
Download 'ringworld_new_scaled.png' (79 KB)
Preview of image 'ringworld_new_scaled.png'
Date: 14 Oct 2013 04:01:27
Message: <525ba4d7$1@news.povray.org>
Ah! Thanks Bill! That is the one I wanted also to find and just forgot :-)
It confirms clearly the epsilon precision problem here.
Date: 14 Oct 2013 04:41:29
Message: <525bae39@news.povray.org>
I'm going to focus on long range pics now instead of shots from the surface.
I got rid of the atmosphere and replaced it with a simple faded pigment.
I also switched the texture for the water surface with a highly
reflective one.
I'm not real happy with the render since you can't see much color. About
all you can see are the clouds.
Mike
Download 'ringworld_new_flattened_01.png' (32 KB)
Preview of image 'ringworld_new_flattened_01.png'
Date: 14 Oct 2013 04:53:00
Message: <525bb0ec$1@news.povray.org>
Here's a render with the faded "atmosphere" pigment removed and the
water returned to its original non-reflective texture.
It looks too cartoon-ey and fake.
http://isometricland.net
Download 'ringworld_new_flattened_03.png' (26 KB)
Preview of image 'ringworld_new_flattened_03.png'
Date: 14 Oct 2013 06:51:05
Message: <525bcc99$1@news.povray.org>
The first one may be more realistic, this one looks more believable
taking artistic licence into account. This is more or less how Larry
Niven describes the first views of the Ringworld.
However, I think that the oceans are not only concentrated in the middle
of the ring. And there are some very large ones too.
Date: 14 Oct 2013 12:26:21
Message: <525c1b2d@news.povray.org>
I've tweaked the landscape a bit and added two belts of clouds. I'm not
sure the two belts make sense on the ringworld. On Earth there is one
cloud belt around the equator, and several jet streams I think.
Download 'ringworld_new_smaller_05.png' (553 KB)
Preview of image 'ringworld_new_smaller_05.png'
Date: 14 Oct 2013 12:28:49
Message: <525c1bc1$1@news.povray.org>
> Thomas
I wasn't satisfied with my other attempts at generating the landscape.
There are supposed to be mountains along each edge of the ring, correct?
Also, I liked the idea of having a navigable water corridor circling the
entire structure.
Date: 14 Oct 2013 19:40:33
Message: <525c80f1@news.povray.org>
> or:
> Thomas
Thanks so much! I will try out these settings next time I do a close-up
shot.
Mike
