POV-Ray : Newsgroups : povray.binaries.images : old lantern Server Time
16 Mar 2026 16:28:18 EDT (-0400)
  old lantern (Message 11 to 20 of 33)
Subject: Re: old lantern
Date: 21 Mar 2013 07:55:00
Message: <web.514af47f985589668f98288b0@news.povray.org>
The texture is below, just realised I have missed out one of the light dirt
textures on the rust surface, will add that and reduce the reflection a bit on
the rust surface then do another render.
#declare lampBaseNormal =   normal {
    bozo
    scallop_wave
    scale 0.55
    turbulence 0.575
    lambda 2.5
    omega 0.75
    normal_map {
        [ 0.0 agate 0.1 scale 0.75 agate_turb 0.6 ]            // reduced all by
0.1
        [ 0.1 agate 0.1 scale 0.75 agate_turb 0.6 ]
        [ 0.2 wrinkles 0.1 scale 0.15 turbulence 0.6 ]
        [ 0.956 wrinkles 0.05 scale 0.15 turbulence 0.6 ]
        [ 0.975 agate 0.1 scale 0.75 agate_turb 0.6 ]
        [ 1.0 agate 0.1 scale 0.75 agate_turb 0.6 ]
#declare ldirt = texture {
    pigment { bozo scallop_wave turbulence 0.8753 omega 0.775 lambda 3.2 octaves
7
    colour_map {
        [ 0.0 rgbt 1 ]
        [ 0.8 rgbt 1 ]
        [ 0.8 rgbt <0.5, 0.34, 0.25, 1> ]
        [ 0.925 rgbt <0.25, 0.2, 0.15, 0.8> ]
        [ 1.0 rgbt <0.5, 0.34, 0.25, 1.0> ]
    scale 0.02
    normal { granite 0.5 scale 0.001 }
    finish { diffuse albedo 0.81 reflection { 0.001 0.01 fresnel on } }
#declare dirt = texture {
7
    colour_map {
        [ 0.0 rgbt 1 ]
        [ 0.75 rgbt 1 ]
        [ 0.75 rgbt <0.5, 0.34, 0.25, 1> ]
        [ 0.9 rgbt <0.25, 0.2, 0.15, 0.5> ]
    scale 0.02
#declare vdirt = texture {
7
    colour_map {
        [ 0.0 rgbt 1 ]
        [ 0.55 rgbt 1 ]
        [ 0.55 rgbt <0.25, 0.14, 0.09, 1> ]
        [ 0.9 rgbt <0.08, 0.06, 0.045, 0.125> ]
        [ 1.0 rgbt <0.25, 0.14, 0.09, 0.45> ]
    scale 0.02
    finish { diffuse albedo 0.75 reflection { 0.001 0.005 fresnel on } }
#declare lampBaseTex = texture
        pigment {rgb <0.3, 0.025, 0.003> }
        finish { specular albedo 0.1 roughness 0.01 diffuse albedo 0.75
reflection { 0.01 0.05 fresnel on } }
        normal { lampBaseNormal scale 0.5}
    texture
            bozo
            turbulence 0.456
            omega 0.8
            lambda 2
            octaves 8
            colour_map
                [ 0 rgbt 1 ]
                [ 0.3 rgbt 1 ]
                [ 0.3 rgbt <0.45, 0.2, 0.07, 1> ]
                [ 0.4 rgbt <0.45, 0.2, 0.07, 0.975> ]
                [ 0.5 rgbt <0.45, 0.2, 0.07, 1> ]
                [ 0.6 rgbt <0.45, 0.2, 0.07, 0.985> ]
                [ 0.7 rgbt <0.45, 0.2, 0.07, 1> ]
                [ 0.8 rgbt <0.45, 0.2, 0.07, 0.975> ]
                [ 0.9 rgbt <0.45, 0.2, 0.07, 1> ]
                [ 1.0  rgbt <0.45, 0.2, 0.07, 0.96> ]
            scale <0.075, 0.15, 0.075>
        finish { specular albedo 0.1 roughness 0.01 diffuse albedo 0.875
reflection { 0.01 0.025 fresnel on } }
        normal {average normal_map {
            [ 1 lampBaseNormal scale 0.5 ]
            [ 1 granite 0.8 scale 0.05 ]
texture { ldirt }
#declare lampBaseTexDirt = texture { lampBaseTex }
    texture { dirt }
#declare lampBaseTexVDirt = texture { lampBaseTex }
    texture { vdirt }
#declare lampBubblePaint = texture
        pigment { gradient x turbulence 0.73 omega 0.4 colour_map
        [ 0 rgb <0.3, 0.025, 0.003> ]
        [ 0.6 rgb <0.3, 0.025, 0.003> ]
        [ 0.7 rgb <0.325, 0.06, 0.01> ]
        [ 0.8 rgb <0.325, 0.06, 0.01> ]
        [ 1.0 rgb <0.3, 0.025, 0.003> ]
        scale <0.01, 0.1, 0.02>
        normal { crackle 3 turbulence 0.05 scale 0.025 }
    texture
            bozo
            turbulence 0.456
            omega 0.8
            lambda 2
            octaves 8
            colour_map
                [ 0 rgbt 1 ]
                [ 0.3 rgbt 1 ]
        normal { crackle 3 turbulence 0.05 scale 0.03 }
#declare lampBubblePaintDirt = texture { lampBubblePaint }
    texture { dirt }
#declare lampBubblePaintVDirt = texture { lampBubblePaint }
    texture { vdirt }
#declare lampRust = texture {
        pigment { granite turbulence 0.35 omega 0.7 lambda 2.2
            colour_map {
            [ 0.0 rgb <0.015, 0.0045, 0> ]
            [ 0.3 rgb <0.05, 0.0175, 0.00075> ]
            [ 1.0 rgb <0.03, 0.009, 0.002> ]
            scale 0.2
        finish { specular albedo 0.1 roughness 0.01 brilliance 5 diffuse albedo
0.575 reflection { 0.05 0.09 metallic 0.6 fresnel on } }
        normal { granite 0.12 turbulence 0.35 scale 0.05}
#declare  lampRustDirt = texture { lampRust }
texture { dirt }
#declare  lampRustVDirt = texture { lampRust }
texture { vdirt }
#declare  lampRustLDirt = texture { lampRust }
texture { ldirt }
#declare lampPaintRust = texture {
wrinkles
cubic_wave
turbulence 0.0625
omega 0.675
octaves 7
//sine_wave
//agate
//agate_turb 0.375
texture_map {
[ 0.0 lampBaseTex scale 4 ]
[ 0.6 lampBaseTex scale 4 ]
[ 0.625 lampBubblePaint scale 2 ]
[ 0.675 lampBubblePaint scale 2 ]
[ 0.7 lampRust scale 3 ]
[ 1.0 lampRust scale 3 ]
scale 0.25
#declare lampPaintRustDirt = texture {
wrinkles
cubic_wave
turbulence 0.0625
omega 0.675
octaves 7
//sine_wave
//agate
//agate_turb 0.375
texture_map {
[ 0.0 lampBaseTexDirt scale 4 ]
[ 0.6 lampBaseTexDirt scale 4 ]
[ 0.625 lampBubblePaintDirt scale 2 ]
[ 0.675 lampBubblePaintDirt scale 2 ]
[ 0.7 lampRustDirt scale 3 ]
[ 1.0 lampRustDirt scale 3 ]
scale 0.25
#declare lampPaintRustVDirt = texture {
wrinkles
cubic_wave
turbulence 0.0625
omega 0.675
octaves 7
//sine_wave
//agate
//agate_turb 0.375
texture_map {
[ 0.0 lampBaseTexVDirt scale 4 ]
[ 0.6 lampBaseTexVDirt scale 4 ]
[ 0.625 lampBubblePaintVDirt scale 2 ]
[ 0.675 lampBubblePaintVDirt scale 2 ]
[ 0.7 lampRustVDirt scale 3 ] // was VDirt
[ 1.0 lampRustVDirt scale 3 ] // was VDirt
scale 0.25
#declare lampPaintRustLDirt = texture {
wrinkles
cubic_wave
turbulence 0.0625
omega 0.675
octaves 7
//sine_wave
//agate
//agate_turb 0.375
texture_map {
[ 0.7 lampRustLDirt scale 3 ]
[ 1.0 lampRustLDirt scale 3 ]
scale 0.25
material {
texture { gradient y turbulence 0.025
texture_map {
    [ 0.0  lampRust ]
    [ 0.025  lampPaintRustVDirt ]     //VDirt
    [ 0.15  lampPaintRustDirt ]       //Dirt
    [ 1.0  lampPaintRustDirt ]        //Dirt
translate <0, -0.05, 0>
interior { ior 1.6 }
Seab
Date: 21 Mar 2013 08:22:21
Message: <514afb7d@news.povray.org>
On 21-3-2013 12:35, s.day wrote:
>> On 20-3-2013 22:47, s.day wrote:
>>> Trying to age my lantern, HDR seems to look better with new shiny objects
>>> though...
>> IMHO this is looking really excellent. I can see no fault with it.
>> Thomas
> Thanks Thomas, it is alwasy easier to find the faults when you created the model
> though. There are some not perfect joins on the glass (coincident surface at the
> very top and where the sphere is connected to the cone the angle/join is not
> perfect). However, I suppose often glass objects have these imperfections anyway
> so maybe I meant to do it ;-)
I did not see those, and even now, I think those imperfections are
acceptable as RL proxies ;-)
> Also, the object is not fully accurate, it was modelled from a photo and I could
> not really see how the wire around the glass was connected up so I didn't
> connect it to anything. Having found a few more photo's now I see that it is
> connected to the bottom wire and this wire runs around (not through) the lamp
> base.. I should fix this but am suffering from the 80:20 rule..
Ah yes! That is more obvious indeed. I wondered how the glass was lifted
up with the bottom wire going through the base. I think there should be
some kind of handle attached to it?
Otherwise, it is an excellent piece of modelling.
Date: 21 Mar 2013 08:26:39
Message: <514afc7f$1@news.povray.org>
On 21-3-2013 12:48, s.day wrote:
> The texture consists of several layered textures in a texture map ....
You are very good at this. I often use texture avatars from your Old
Royal IRTC scene.
Date: 21 Mar 2013 08:30:01
Message: <web.514afc75985589668f98288b0@news.povray.org>
"Trevor G Quayle" <Tin### [at] hotmailcom> wrote:
> > though...
> No, I think this looks just as good this way, maybe even better.  Making things
> look shiny and new is easy, making them look old or worn or dirty or dusty is a
> real challenge.
> -tgq
Yes, I agree. I have often had a good model only to wreck it with a bad texture.
Dust is probably the most difficult to add with realism, especially if it is a
close up view.
Sean
Date: 21 Mar 2013 08:48:13
Message: <514b018d@news.povray.org>
On 21/03/2013 11:48 AM, s.day wrote:
> next I need to try to add a tiger lily to the scene
I don't know if you have used PlantStudio? Version 1.0 is free.
http://www.kurtz-fernhout.com/PlantStudio/
Regards
Date: 21 Mar 2013 10:05:02
Message: <web.514b1265985589668f98288b0@news.povray.org>
> Regards
>      Stephen
Thanks, some of the sample images look pretty good, I will take a look at this.
This lily will be fairly large/close so maybe difficult to get the detail level
good enough (alghough if I attempt it with CSG it may look more like a lego
flower ;-)
Sean
Date: 21 Mar 2013 10:33:24
Message: <514b1a34$1@news.povray.org>
> flower ;-)
> Sean
It will probably make a good starting point, where you can export it to
PoseRay to subdivide it. Then use your own textures.
Regards
Date: 21 Mar 2013 18:50:01
Message: <web.514b8e66985589668f98288b0@news.povray.org>
> Royal IRTC scene.
> Thomas
Thanks Thomas, I never did finish off the rest of that train model (adding the
carriages etc). I had lots of ideas for scenes to use that model in but it they
all needed the carriages completed etc. Still on my to do list then..
Date: 22 Mar 2013 04:14:47
Message: <514c12f7$1@news.povray.org>
I know that feeling :-)
Date: 22 Mar 2013 10:50:02
Message: <web.514c6ec5985589662b49da7c0@news.povray.org>
> > objects though...
>    Very nice modeling... proportions look perfect, with all the tiny
> details at the correct scale. Lighting is very good too... I cannot see
> any obvious artifacts. Texturing on the paint is also impressive, but
> the rusty parts look like too reflective... I guess you didn't go for a
> texture_map?
> Jaime
Hi Jaime,
Thanks for noticing the shiny rust, I have modified this and think the result is
a  subtle but good improvement.
Sean
Download 'lantern_rust.png' (587 KB)
Preview of image 'lantern_rust.png'
