POV-Ray : Newsgroups : povray.binaries.images : Space Colony Wide Angle Server Time
6 Mar 2026 09:17:06 EST (-0500)
  Space Colony Wide Angle (Message 1 to 7 of 7)
Subject: Space Colony Wide Angle
Date: 14 Feb 2011 06:40:01
Message: <web.4d5913dd16b39e34ec13f70a0@news.povray.org>
This is a wide angle view of the Island 3 space colony.  Used a "dummy"
non-rendered isosurface "Traced" to vary population compositions of objects
populated on a rendered mesh by the "Trace" command.  Mesh made from
isosurface...rendered as much as 50 times faster.
Download 'island31a16d-goodvista1a.jpg' (241 KB)
Preview of image 'island31a16d-goodvista1a.jpg'
Subject: Re: Space Colony Wide Angle
Date: 14 Feb 2011 08:31:41
Message: <4d592ebd$1@news.povray.org>
how many months rendering? ;)
Those clouds look way too good.  are they media-based?
Date: 14 Feb 2011 21:20:01
Message: <web.4d59e2cf73a21bf834d207310@news.povray.org>
I think I have a cumulative disgust for the Uncanny Valley in raytracing, even
landscapes, and that's why I like this so much-- it's so rich in non-exhaustive
realism.
Date: 15 Feb 2011 02:59:47
Message: <4d5a3273@news.povray.org>
Holy Bandersnatch! This is frumious!  :-)
[other words for "speachless"]
Date: 17 Feb 2011 09:40:01
Message: <web.4d5d332273a21bf8e62aaed0@news.povray.org>
They use "df3" media in spheres.  Actually one "df3" file rotated randomly.
There are 90 clouds here, all copies of the same cloud.  Air is a Rayleigh
scattering media, with some emission to fake multiple scattering so it would not
be totally dark in the shaded areas.  Media used only 5 intervals, ( 1 to 4
samples (was it 2 to 8?)...more intervals would make a longer render (!!!!)
Picture rendered at 1680 x 1050, antialiasing 0.1, radiosity on...only 5 or 10
samples...took about 4 to 6 hours to render on an eight core I7 with 64 bit
Windows 7 and 9 gigs of RAM.
Date: 17 Feb 2011 23:05:32
Message: <4d5df00c@news.povray.org>
What sampling method do you use? The default is method 3.
When using method 3:
intervals defaults to 1
samples defaults to 10 (must be at least 3)
Using intervals GREATLY increase the rendering time.
The second samples value is ALWAYS ignored: samples 1,4 becomes samples 1
intervals 10 samples 10 is MUCH slower than samples 100 (with default
intervals 1).
Expect you render tome to drop under 3 hours if you set only intervals 1
and increase samples around 50. It's even possible that you could use
something like samples 150 to 200 and still get faster rendering.
Date: 18 Feb 2011 07:15:01
Message: <web.4d5e623f73a21bf8e62aaed0@news.povray.org>
> intervals 1).
> Alain
Thank you for the tip -- will try that this weekend.  Will also refine some of
the inside plants, structures, etc, along with outside details (making the side
windows really transparent, which will slow render time by a factor of two or
so).
Ed
