POV-Ray : Newsgroups : povray.binaries.images : Dielectric experiments Server Time
6 Mar 2026 09:17:42 EST (-0500)
  Dielectric experiments (Message 1 to 9 of 9)
Subject: Dielectric experiments
Date: 8 Feb 2011 22:50:01
Message: <web.4d520c7e32b9a63f94d713cc0@news.povray.org>
According to Wikipedia, Mental Ray's *Dielectric Physical Phenomenon* shader
"uses Fresnel equations to simulate reflectance and transmittance of light
passing through the dielectric interface, as well as using Snell's law to
determine the angle of refraction. In addition Beer's law is used to determine
absorption of rays passing through dielectric materials."
Well, after looking over some basic dielectric equations I came up with this
simple POV-SDL setup for the following basic dielectric material in POV-Ray. The
transparency and reflection of the material automatically tune themselves
according to the material's IOR value:
// Dielectric Ball
global_settings { photons { spacing 0.01 } }
#declare IOR   = 1.33;
#declare REFL  = pow(((1-IOR)/(1+IOR)), 2);
#declare TRANS = 1 - REFL;
sphere { 0, 1
      pigment { rgb 0 transmit TRANS }
      finish {
         reflection {0, REFL fresnel on } conserve_energy
         specular REFL roughness 0.005
   interior { ior IOR }
   photons {
      target
      refraction on
      reflection on
      collect off
With an IOR at 1.0 the object is completely invisible and reflectionless,
although I see some hint of a photon ring at the invisible sphere's base (so, a
dielectric material might make a good cloaking device, but just like in sci-fi
movies there'll still be the occasional photon ripples to give your position
away).
I found it really interesting that the transmit and reflection values changed so
exponentially, with very quick changes from completely transparent at IOR 1.0 to
50% transparent at IOR 5.83, but it took an astonishing IOR 8000 to get to 0%
transparent and become totally opaque! Regardless, I think the circular photon
ring contracting into a dissipating glow dot is a really cool effect. I'm going
to have to render an animation of this...
Cheers,
Rob
www.McGregorFineArt.com
Download 'dielectric_series.png' (1504 KB)
Preview of image 'dielectric_series.png'
Subject: Re: Dielectric experiments
Date: 9 Feb 2011 00:45:06
Message: <web.4d5228f693e5ac671df6284f0@news.povray.org>
That does sound very interesting!
Dave Blandston
Date: 9 Feb 2011 03:19:07
Message: <4d524dfb$1@news.povray.org>
"Dave Blandston" <nomail@nomail> schreef in bericht
news:web.4d5228f693e5ac671df6284f0@news.povray.org...
>> going
I didn't *hear* Robert, but it *looks* quite exciting indeed  ;-)
Date: 10 Feb 2011 02:18:23
Message: <4d53913f$1@news.povray.org>
Am 09.02.2011 04:44, schrieb Robert McGregor:
> // Dielectric Ball
> sphere { 0, 1
>     texture {
>        finish {
>     photons {
>        target
>        refraction on
>        reflection on
>        collect off
Hmm, this does not look right to me - as far as I understand this
dielectric matter. Sadly Kari Kivisalo seems to be no more around, the
one that did just *know* such things.
Anyway it reminds me that I've never done any glass objects so thanks
for the inspiration on that ;)
-Ive
Date: 10 Feb 2011 06:59:02
Message: <op.vqorkcapufxv4h@go-dynamite>
Does this mean transparency + ior + fresnel is wrong for glass?
I haven't grasped this dielectric stuff yet. Is there a more simple way to
explain it?
-Nekar Xenos-
Date: 10 Feb 2011 16:56:58
Message: <4d545f2a@news.povray.org>
As I had no time this morning here is a more detailed response:
> // Dielectric Ball
> sphere { 0, 1
>     texture {
>        finish {
>     photons {
>        target
>        refraction on
>        reflection on
>        collect off
Sorry, this is pointless. But step by step...
this is the reflectance when seen *parallel* to the surface normal (or
get 4% reflection and 96% refraction at this angle.
But when seen from a very swallow angle for *every* IOR reflection gets
close to 100% and refraction to 0%. Again for glass, when seen from an
refraction only 1.4%.
Everybody can verify this easily by looking at a *very* swallow angle at
some glass window. The glass becomes an almost perfect mirror.
In POV-Ray-syntax this would be
reflection (REFL, 1) and definitely not reflection (0, REFL)
but it is completely unnecessary to compute the value for REFL because
for this purpose we have the keyword fresnel.
reflection (0, 1 fresnel on)
already calculates exactly e.g. 4% reflection for a given IOR of 1.5 and
The keyword transmit is meant to simulate something like light that
falls through thin paper or through silk or something like this.
To simulate a dielectric it is much better to use filter. It makes
things like colored glass possible and makes it also possible to take
conservation of energy into account and therefor we have the
conserve_energy keyword. So there is no need to calculate something
like
especially since the whole point of fresnel reflection is that the
relation between reflected and refracted (or transmitted as you did put
it) rays is not constant but depends on the viewing angle.
A dielectric like window glass within POV-Ray is just as simple as this:
material {
   pigment {rgbf 1}
   finish {
     ambient 0  diffuse 0
     reflection {0, 1 fresnel on} conserve_energy
   interior {ior 1.5}
A solution for colored dielectric materials within POV-Ray would be this
macro:
#macro Dielectric (COLOR, IOR)
   material {
       pigment {rgb COLOR filter 1}
       finish {
         ambient 0 diffuse 0
         reflection {0 1 fresnel on}  conserve_energy
     interior {
       ior IOR
       fade_power 1001 fade_distance 1/IOR
       fade_color rgb <pow(COLOR.red,3), pow(COLOR.green,3),
pow(COLOR.blue,3)>
   photons {
     target
     refraction on
     reflection on
     collect off
It should even be possible to model something like porcelain (with some
quite high IOR value) but dielectrics like this are more problematic as
light scattering becomes more important.
Attached is a quick dielectric doodle and the source for it.
Note that the environment is (on purpose) quite boring so we have no
interesting reflections on that thingies.
-Ive
Download 'dielectricthing.jpg' (95 KB) Download 'us-ascii' (5 KB)
Preview of image 'dielectricthing.jpg'
Date: 12 Feb 2011 14:10:02
Message: <web.4d56d7e593e5ac6794d713cc0@news.povray.org>
LOL, thanks Ive, I guess I got so caught up in what I was reading about
dielectrics I didn't take into account that POV already does all that, and I was
actually breaking it by redoing it!
Which is pretty funny to me because I already knew this (re: fresnel, etc), but
was somewhat thrown off by Mental Ray jargon and the equations I was looking at
(and the problem compounded by this video: http://vimeo.com/18586657). And yes,
I had the reflection params swapped (doh!). Thanks for setting me straight.
Which left me with a very simple glass material like I would have made had I
avoided all that confusion:
sphere { 0, 1
      pigment { rgbt 1 }
      finish { reflection { 0, 1 fresnel on } conserve_energy }
   interior { ior 80000 }
   photons {
      target
      refraction on
      reflection on
      collect off
What I did learn from all of this is the rather obvious (in hindsight) fact that
higher reflectivity corresponds to less light transmission, and that a
dielectric material does in fact become "opaque" at around ior=80,000 (at 4
decimal places of accuracy) because the reflectivity hits 100% and light can
no longer pass through. The attached image uses the above material.
Download 'dielectric.ior.80000.png' (457 KB)
Preview of image 'dielectric.ior.80000.png'
Date: 13 Feb 2011 12:10:52
Message: <4d58109c$1@news.povray.org>
Am 12.02.2011 20:06, schrieb Robert McGregor:
> dielectrics I didn't take into account that POV already does all that...
that was what I assumed as you have already shown that you do know better ;)
Not so sure about the usefulness of such high values but anyway glass
(and diamonds for that matter) are actually quite boring dielectrics. My
favorite personal challenge is still porcelain where the refracted light
does not simply travel along but gets scattered. I own a tea set made of
Chinese porcelain (and have made a digital model of some parts of it)
and I can render it and it might be even be recognized as porcelain but
yet I do completely fail to capture the *beauty* of the light
interacting with it.
-Ive
Date: 15 Feb 2011 18:00:01
Message: <web.4d5b042193e5ac6794d713cc0@news.povray.org>
> -Ive
I've never tried rendering procelain before, that sounds interesting. I have a
few pieces here that I can use as reference, I think I'll give it a shot.
As for the higher IOR values becoming boring, I agree, but I wanted to observe
the changes that occur as the index changes from 1 (completely transparent) to
80,000 (completely solid/reflective) so I made this video and posted it on
Vimeo:
http://www.vimeo.com/19916827
I didn't realize the default Vimeo aspect ratio would distort my shot so much
until after it uploaded, so my orb looks like an egg (I'm re-rendering at the
Vimeo's default 800x480 to fix it).
The refraction and photons are fun to watch, the reflection not so much, so I
used a spline to control the IOR and "speed up" most of the reflection frames. I
was especially suprised by the lens-flare-like photon effect that happens on
that table between IOR 3-4; pretty cool. Enjoy!
Cheers,
Rob
Download 'dielectric.pov.txt' (6 KB)
