POV-Ray : Newsgroups : povray.binaries.images : We need a gamma 1.0 color-picker app (?) Server Time
22 Mar 2026 01:25:29 EDT (-0400)
  We need a gamma 1.0 color-picker app (?) (Message 11 to 15 of 15)
Subject: Re: We need a gamma 1.0 color-picker app (?)
Date: 17 Jan 2011 15:55:01
Message: <web.4d34ac4ac140d037196b08580@news.povray.org>
Sorry for the delay; I was working on an idea.
If there's even the slightest chance of having a gamma-1.0 GUI color-picker
built-in to POV-Ray, some initial concepts might be useful.
Here's my first-thought idea (a mock-up based on the COLRSCR32 app.) It may or
may not be the best way to do this, or even visually appealing (perhaps a
PAINTER-like color wheel would be more appropriate than sliders); but it
embodies some structural ideas that I think might be important. These are
debatable, of course; comments/criticisms/alternative ideas are welcome.
1) This model assumes that we will use either assumed_gamma 1.0 or assumed_gamma
2.2 in POV-Ray--no other in-between values. At this point in POV-Ray's
evolution, I don't know whether that's good or bad. ;-)
2) Meant to be simple, straightforward, no 'bells and whistles', no fancy
out-of-the-ordinary GUI interface. (Perhaps my own example isn't simple enough.)
3) It's fundamentally a *visual* color picker, by moving the sliders; but also
allows values to be entered.
4) It shows the color in both gamma 1.0 space AND the 'typical' gamma 2.2 space.
The two sets of sliders and data boxes are to make it easy to choose the values
in *either* color space, and get the gamma 1.0 equivalents. The gamma 2.2
color-picker may seem unnecessary, but it's there for those not wishing to use
assumed_gamma 1.0; and if nothing else, this dual set-up might prove useful as
an 'instructional comparison' between the different values. The basic idea is
that you can choose a color from EITHER square--whichever you feel comfortable
with--and the app automatically figures out *visually identical* gamma 1.0 and
gamma 2.2 colors. Ditto entering values instead (in either set of boxes.)
5) The 'gamma 2.2' stuff is always active, but purposely grayed out slightly (at
all times) and maybe smaller overall--simply to signify that the 'gamma 1.0'
color-picker is the *recommended* one.
6)  The app itself (and the 'gamma 2.2' color square) naturally show up visually
on screen in gamma 2.2 space--i.e., the whole thing looks proper on a typical
monitor.  ONLY the 'gamma 1.0' color square shows up visually in gamma 1.0
space. But no matter which square you work with, the app automatically 'matches'
that color in the other square.
7) The rgb values should be presented as both 0.0-to-1.0 AND 0-to-255 (for those
more familiar with that way of working.)
8) After choosing a color and hitting the 'OK' button, the rgb(ft) <.......>
block is automatically placed into the SDL scene code--no need for saving to the
clipboard or cutting and pasting. (Obviously, your cursor would need to be in
the correct location in the scene for this to work.) *OR*, it might in fact be
be more straightforward for the app to simply save it to the clipboard, and ONLY
that. Then it could simply be pasted in *after the fact*--i.e., anywhere, not
necessarily where your cursor happened to be beforehand.
This code insertion is based on the assumed_gamma scene setting; if 1.0, then
the contents of the 1.0 boxes are inserted into the scene; if 2.2, then the 2.2
box contents are used.
9) The filter and transmit bars have on/off buttons; if they are off, only the
rgb<....> values show up and are used.  But if, for example, the filter slider
is active, then it would show as rgbf <.....>. Most uses of color are without f
or t, I would imagine--and this keeps unnecessary vector entries out of the
color vector, just for scene clarity. Why should most colors in a scene be
listed as <value,value,value,0.000,0.000> when only three rgb values are used?
Seems like unnecessary clutter.
10) Should the number of decimal places be more than the 3 as shown?  Each of
the rgb color components have only 256 levels--BUT, 1/256 = .00390625 Hmmm...
Perhaps the app could have *user-selectable* decimal places for the output? For
example, I never use more than 2 or 3 places when specifying a color; seems kind
of overkill. But the app could allow more if wanted. (Which means the value
entry boxes would have to be wider?  Or maybe you could simply scroll aross them
to see the entire value?)
11) The 'grayscale' buttons are to toggle between color and grayscale versions
of the chosen color--just to check brightness levels, maybe.  (And this would
change the values in the boxes as well.)
12) The static black and white alternating bars(?) are to give a brightness
comparison to the color/grayscale appearance--possibly useful in tandem with
#11.  Note that I left out a '50%-gray' bar--because I don't really know what
that should look like! Might confuse the issue.
13) The app's size on screen should scale itself to the monitor's resolution and
size--not just a 'set' size for, say, a 1280X960-rez monitor--so that, for
example, an 800X600 screen doesn't show it chopped off on the right. I guess it
would need a 'minumum' size, of course.
Ken
Download 'gamma_1_picker_a.jpg' (250 KB)
Preview of image 'gamma_1_picker_a.jpg'
Date: 18 Jan 2011 03:31:39
Message: <4d354feb$1@news.povray.org>
Am 17.01.2011 21:53, schrieb Kenneth:
That won't work. Due to how the POV-Ray SDL works, it would require
parsing of the whole scene just to figure out the effective
assumed_gamma setting.
Date: 19 Jan 2011 01:25:00
Message: <web.4d368298c140d037196b08580@news.povray.org>
Oops, sorry; I removed those bars from the mock-up (they didn't look too useful)
but forgot to edit out this text.
Date: 19 Jan 2011 01:35:00
Message: <web.4d3685a2c140d037196b08580@news.povray.org>
You're right. :-[  It didn't occur to me that the color-picker would somehow
have to 'magically guess' what was written in the SDL scene; the code is just a
text file, after all. (Hmm...maybe the app could do a quick text search, looking
for 'assumed_gamma'?? Kidding. Or maybe not...)
Date: 19 Jan 2011 02:59:29
Message: <4d3699e1@news.povray.org>
Am 19.01.2011 07:33, schrieb Kenneth:
I guess it will be much easier, much more reliable and sufficiently
convenient to have an assumed_gamma input box in the color picker
(remembering its setting) where the user will have to input the
corresponding value. Presuming of course that they're using "rgb<...>"
instead of "srgb<...>" format, as the latter is independent of
