POV-Ray : Newsgroups : povray.binaries.images : POV-Ray corporate headquarters Server Time
2 Apr 2026 00:27:48 EDT (-0400)
  POV-Ray corporate headquarters (Message 9 to 18 of 18)
<<< Previous 8 Messages Goto Initial 10 Messages
Subject: Re: POV-Ray corporate headquarters
Date: 25 Apr 2010 22:20:00
Message: <web.4bd4f7978f076cd8cba3fb0f0@news.povray.org>
"Kenneth" <kdw### [at] earthlinknet> wrote:
> Guilty as charged. ;-) I tried out a bunch of different isosurface shapes, but
> settled on this one because it looked somewhat different from a 'cliche' sci-fi
> building. Unfortunately, a bowling pin was the result. :-[
The headquarters building reminds me not of a bowling pin, but of Rosie, the
Jetson's robot maid. This is a very cool scene!!!
Dave Blandston
Date: 26 Apr 2010 01:25:09
Message: <web.4bd5234b8f076cd863ecdb130@news.povray.org>
> Here's an early building test--less bowling-pin like. (I don't recall the reason
> why I didn't go with this shape instead--I did lots of scene tests using it.)
I think it was the colors that clinched it for me.  I actually like the "all
glass" look, very modern and would match your fifties theme well.
P.S. I enjoyed seeing the progression of your work. I'm always fascinated by the
thought process people take to get to the final result.
Date: 26 Apr 2010 03:15:01
Message: <web.4bd53d498f076cd8ae92d9930@news.povray.org>
Looking at both images now, I kind of agree. And it just might be those dark
window 'stripes' in the original post that push the building's design into the
'bowling pin' category. ;-) Something I should have been more critical of.
Me too. (I should probably post more WIPS, as others do.) Trouble is, my scenes
take me too long to write (because I like to experiment with the code)--the
WIP-posting process could extend over months! Which is OK, I guess. Kind of
embarrassing, though, when others here whip scenes together in no time flat.
BUT, wips are meant to be critiqued by others--which is always a good idea, and
can keep a scene's design from progressing down a 'wrong path.' Or at least
bring it to an author's attention.
Ken
Date: 26 Apr 2010 03:20:01
Message: <web.4bd53e858f076cd8ae92d9930@news.povray.org>
I didn't think of that! Ah, the good ol' Jetsons.  Now *there's* some futuristic
architecture!
Ken
Date: 26 Apr 2010 03:46:59
Message: <4bd544f3$1@news.povray.org>
"Kenneth" <kdw### [at] earthlinknet> schreef in bericht
news:web.4bd53d498f076cd8ae92d9930@news.povray.org...
>> by the
> scenes
> code)--the
> of
> flat.
> idea, and
> least
I agree. I used to compose scenes much faster in the past, but nowadays,
they take months to build (and render). However, I often take the *secrecy*
path because the image is intended for the TC-RTC challenge, and I do not
want to show my hand... :-)
Date: 26 Apr 2010 03:58:49
Message: <4bd547b9@news.povray.org>
news:web.4bd49aa88f076cd8ae92d9930@news.povray.org...
> There's an aspect to the entire scene that may be giving it an overall odd
> look:
> The camera has a very wide-angle view (which normally distorts
> everything.) I
> tried to correct for this in the individual objects--rotating them to be
> more-or-less vertical 'visually.'  But I didn't do it to *all* the objects
> (the
> trees are still slanted, for example.) It was an experiment that didn't
> quite
> work out as planned.
There is a piece of *ancient* code that might help you with this, written by
Doctor John. I copy it here 'as is':
// Persistence of Vision SDL include file
// Description: A macro to simulate lens movements in architectural scenes
//  Helps prevent the "falling verticals syndrome"
// Author: John Guthkelch (Doctor John) <doc### [at] linuxmailorg>
// Version 2.0 Released September 2005
// Changes: 1. Improved warning so that camera automatically reverts to
default
//     type if insane values are given for CamPos and/or CamLook
//     2. Corrected silly mathematical error in vertical scaling.This
//     is now correct so switch has been taken out.
Don't forget to switch off Vista Buffers by using -uv on the command line
or Vista_Buffer=0 in your .ini file before attempting to render your image
#macro FieldCam (CP, CL)
 #local CD=CL-CP;
 #if (CD.x!=0 | CD.z!=0) // Note: That's a Boolean OR not an uppercase i
    // or a lowercase L!
  #local HypoXZ=sqrt(pow(CD.x, 2)+pow(CD.z, 2));
  #local VCorr=pow(vlength(CD), 2)/pow(HypoXZ, 2);
  #local CosThetaX=CD.x/HypoXZ;
  #local CosThetaZ=CD.z/HypoXZ;
  #if (CD.x=0)
   #local ShearX=0;
  #else
   #local ShearX=(CD.y/CD.x)*pow(CosThetaX, 2);
  #if (CD.z=0)
   #local ShearZ=0;
  #else
   #local ShearZ=(CD.y/CD.z)*pow(CosThetaZ, 2);
  #declare NoFall=transform {
   matrix <1, 0, 0, ShearX, VCorr, ShearZ, 0, 0, 1, 0, 0, 0>
 #else
  #warning "Viewing vector is perpendicular to XZ-plane.\n"
  #warning "Camera changed to default type.\n"
   matrix <1, 0, 0, 0, 1, 0, 0, 0, 1, 0, 0, 0>
/*********************************USAGE**************************************
#declare CamPos=<Xc, Yc, Zc>;   //Just replace <Xc,Yc,Zc> with location
vector
#declare CamLook=<Xl, Yl, Zl>;  // -"-   -"-   <Xl,Yl,Zl> with look_at
vector
 FieldCam (CamPos, CamLook)
 perspective
 location CamPos
 [angle Whatever] // Not essential but can be used
 [right If_you_want] // Also not essential but can be used
 transform {NoFall}
 look_at CamLook
Date: 26 Apr 2010 08:40:00
Message: <web.4bd588748f076cd8ae92d9930@news.povray.org>
> ...However, I often take the *secrecy*
YES, I know that feeling! (I admit that my B-29 bomber animation was a similarly
'secretive' scene.) WIPS can sometimes 'lessen the impact' of the final work.
But I *do* like seeing them from others, and I shouldn't be so secretive myself.
Ken
Message: <web.4bd5898d8f076cd8ae92d9930@news.povray.org>
So someone actually came up with code to do this?! Thanks, Thomas; I need to
examine this in detail, to see how it works.
Ken
Date: 26 Apr 2010 09:14:11
Message: <4bd591a3$1@news.povray.org>
Oh that is niiiiice :)
Do I have an office? I wonder what it looks like inside...
Tek
http://evilsuperbrain.com
"Kenneth" <kdw### [at] earthlinknet> wrote in message
news:web.4bd33d559bbfa54fae92d9930@news.povray.org...
>A well-kept secret! Somewhere in Dubai...
> Just having some fun with isosurfaces (and textures and media and lighting
> and...)
> I've been re-working some images from the past year that I never posted.
> This
> one isn't perfect; it still has lots of uncorrected elements. But rather
> than
> work endlessly on it, I decided to post it as-is. Suggestions are welcome,
> though; I *might* spend some more time on it. Hard to let go of!
> Ken
Date: 26 Apr 2010 16:50:00
Message: <web.4bd5fb778f076cd8ae92d9930@news.povray.org>
Sorry, office space is at a premium at the moment (*I* can't even get
one)--filled with thousands of stressed-out workers feverishly putting the
finishing touches on POV-Ray v3.7  ;-P  Note the lighted windows--they're
working overtime!! Bah, who needs a crummy old office anyway--I prefer a more
leisurely lifestyle...
Ken
