POV-Ray : Newsgroups : povray.binaries.images : IRTC detail shot Server Time
9 Apr 2026 01:55:04 EDT (-0400)
  IRTC detail shot (Message 9 to 18 of 18)
<<< Previous 8 Messages Goto Initial 10 Messages
Subject: Re: IRTC detail shot
Date: 2 Nov 2009 23:20:01
Message: <web.4aefade9b57c8bb34726e92b0@news.povray.org>
One thing I forgot to mention that I struggled with is differences in display
gamma, which can really yield a HUGE difference in the *perceived* image output.
I'm told it affects antialiasing too somehow, but... well I must admit that all
good for compositing" and "Windows is 2.2" and "Mac is 1.6" (or something like
that). Whatever. I've seen Warp and Clipka going back and forth about it over
the last few months...
Anyway, I did a lot of test renders and my final density_map values for the
glowing wires media (for all layers of media) were:
   density_map {
      [0 rgb 0]
      [0.5 rgb <0.625, 0.156, 0>*6]
      [0.7 rgb <0.625, 0.304, 0.127>/1.2*6]
      [1 rgb 1]
Here are three renders of the exact same scene file but with, respectively,
default gamma (i.e., no command line gamma), Display_Gamma=1.6, and
Display_Gamma=1.0. I'm not sure why a command line Display_Gamma of 1.0 looks
*completely* different than the supposed default 1.0 gamma for POV-Ray 3.7
[i.e., without any Display_Gamma in the command line])? I guess I really just
file images are identical, but this "display" thing really throws me off, since
all are quite different.
This is one area where I can truly appreciate Jaime Vives Piqueres' ignorancia
mindset... I know what looks good to me, so I adjust according to what I think
looks right (and if it looks right, it *is* right!)
Well, the Display_Gamma=1.0 looks a bit dark, but nice and rich to me in the
render preview, so I just adjust all the other materials and lighting
accordingly to fit with that. Then I have to go into PhotoShop and adjust the
levels on the disk file image until it actually looks like the Display_Gamma=1
render preview window... I feel like there's some mystical something
simple/vital/wonderful I'm missing here in regard to this gamma stuff to make my
art better, stronger, faster  -easier... If someone could explain it I'd really
appreciate it :D
Thanks,
Rob
Download 'nixietubegamma.png' (992 KB)
Preview of image 'nixietubegamma.png'
Date: 2 Nov 2009 23:25:01
Message: <web.4aefb059b57c8bb34726e92b0@news.povray.org>
Ugh, nice typo... actually, that middle shot is supposed to read
"Display_Gamma=1.6"
Date: 3 Nov 2009 00:40:57
Message: <4aefc269$1@news.povray.org>
It does indeed - somehow. POV-Ray does antialiasing in the same color
space it uses for rendering, that is linear color space in POV-Ray 3.7
(unless you use assumed_gamma, which you shouldn't anyway), which has
the effect that the color difference at which AA kicks in /appears/ much
higher for dark colors than for bright colors.
Not ideal, but that's how it is at present. Applying output gamma
adjustment /before/ antialiasing would cause color distortions, depend
on file type and/or File_Gamma setting, and wouldn't fit in the general
architecture of 3.7 anyway, so it's no option either.
Just let it suffice to say that you really should set Display_Gamma to a
suitable value as described in the documentation, as from the next beta
on there really should be no reason left to tamper with the setting.
That's because 1.0 is /not/ the default Display_Gamma; depending on your
system, it should be 2.2 (PC and Unix), or... well, don't know, maybe
1.6 for the Mac version.
That's because for file output, gamma is now governed by a separate
File_Gamma keyword.
The thing is that gamma is not an "artistic" screw to tweak, but a
purely technical one, intended to make sure that what /you/ see is as
close as possible to what /others/ will see.
If you think your image looks too washed-out, but you are sure that you
set Display_Gamma to the proper value (not according to what you think
looks cool, but as explained in the documentation), then what you really
should do is to fix your scene.
If you try to misuse this technical screw for artistic purposes, don't
be surprised if the technical side starts getting in your way.
There's currently still one caveat to this principle, and that's input
image files, which /will/ be rendered too washed-out depending on file
type. Next beta will do a better job there.
(Readers please note that this all pertains to the current POV-Ray 3.7
beta; older versions - including the latest "proper" release, 3.6.2 -
are quite different beasts regarding gamma handling.)
Date: 3 Nov 2009 03:54:44
Message: <4aefefd4@news.povray.org>
"Robert McGregor" <rob### [at] mcgregorfineartcom> schreef in bericht
news:web.4aee3b76b57c8bb34726e92b0@news.povray.org...
> And for those of you that haven't yet tried modeling with Silo 2.1, I
> highly
> recommend trying the free download, and for $99 US it's really amazing; It
> also
> nice UV editing; and POV-Ray export built in (although I prefer OBJ to
> PoseRay
> to Mesh2). I haven't touched Wings3d for months now.
I cannot agree more. Silo 2 changed my life :-)
Date: 3 Nov 2009 05:05:01
Message: <web.4aefff48b57c8bb34ade20e40@news.povray.org>
> "Display_Gamma=1.6"
Thanks for the detailed explanation Rob, I too have never understood exactly how
gamma correction works.. (and I wish that was the only thing I didn't understand
about POV).
BTW I think the 1.6 image is best and now I am wondering what differnce this
would make to some/most/all of my images... Yet another lot of test renders to
perform before I submit my next image.
Sean
Date: 3 Nov 2009 07:15:00
Message: <web.4af01e74b57c8bb34726e92b0@news.povray.org>
Thanks Christoph, I understand a *little* better now... I've gotten used to
"misusing" assumed_gamma over the last several years (with good results I think)
and v3.7 just ignores it.
So if using File_Gamma=2.2 on Windows, does v3.7 actually render in the linear
1.0 gamma space and then gamma correct to 2.2 for file output *after* the
antialiasing?
Date: 3 Nov 2009 08:04:32
Message: <4af02a60$1@news.povray.org>
> antialiasing?
Yes. POV-Ray 3.7 will always render in the linear 1.0 gamma space
(unless using the now-deprecatedd "assumed_gamma" keyword).
Note that File_Gamma does not necessarily change the /look/ of the
output file; this depends on whether the output file format is
"gamma-aware" or not.
Date: 3 Nov 2009 11:53:57
Message: <4af06025$1@news.povray.org>
>> "Display_Gamma=1.6"
> about POV).
> Sean
Display_gamma should be set once only. It's value should be that of your
display.
If your display HAVE a gamma of 1.6, you must set display_gama to 1.6.
It it's gamma is 2.2, you must set display_gamma to 2.2.
If you set display_gamma wrong, your preview will be wrong, your colour
balance will be skewed, and your real image will look different when
viewed with any viewer, and by others on different display.
assumed_gamma will affect the file, but NOT the display. It, to, must be
correctly set. It MUST NOT be set specificaly for a given scene.
You should not need to gamma correct your image in any post process step.
Date: 13 Aug 2014 02:55:01
Message: <web.53eb0af9b57c8bb3e65b575e0@news.povray.org>
Hi
I search a Nixietube to make a visitor Counter.
please can you help me?
how can i download a nixie tube pov.ray set?
Your code i have tried but is not working, missing files.
Thank you for help.
cheers
Andrew
> Hi all, here's a test render of one of the tubes used in my "Time (Steampunked)"
> IRTC entry. My final shot doesn't reveal all the detail so I wanted to show a
> close up :)
> Sad Fact: I've been pretty bad lately about not posting my competition entries
> until the VERY end - in fact, three out of four of my most recent entries have
> been literally posted with only minute(s) to spare (tonight being no exception),
> so as a personal joke I set my alarm clock digits to read 23:59. It wasn't so
> funny tonight though when, with only a couple of minutes left befre deadline,
> the IRTC server was repeatedly giving me a "Too Busy" error code.
> Happy Fact: Luckily I finally did get my shot posted just before the round
> closed :)
> Cheers,
> Rob
Date: 13 Aug 2014 03:15:15
Message: <53eb1083$1@news.povray.org>
You need to contact Robert McGregor.
