POV-Ray : Newsgroups : povray.binaries.images : Piggy! Server Time
7 Mar 2026 16:29:38 EST (-0500)
  Piggy! (Message 1 to 4 of 4)
Subject: Piggy!
Date: 10 May 2009 14:15:01
Message: <web.4a0718c370937c967c6878d10@news.povray.org>
This image took 225 hours to render. It's just a few blobs together. But the
longest areas of rendering were at the connection of the ears to the body and
the legs to the body. Also there's 5 iterations of the blurred reflection code.
Would converting the blob to a mesh make the render faster?
Download 'pig.jpg' (210 KB)
Preview of image 'pig.jpg'
Subject: Re: Piggy!
Date: 10 May 2009 15:28:56
Message: <4a072af8@news.povray.org>
"jhu" <nomail@nomail> wrote in message
news:web.4a0718c370937c967c6878d10@news.povray.org...
> the
> and
> code.
I doubt it, I think the slow rendering-time is due to recursive blurred
reflections.  Try the same scene without reflection (and without focal
blur), and I'm quite sure it'll render in a few seconds
wouldn't look half as cool though :)
cu!
Subject: Re: Piggy!
Date: 11 May 2009 21:50:00
Message: <web.4a08d56a527e51f4695fe9130@news.povray.org>
225 hours?! Oh dear!
I don't know about the radiosity / mesh issue.
But I once noticed that one can save LOTS of time when doing focal blur with
really low quality settings  and antialiasing switched off and rendering the
image twice or three times as big as needed.  And then afterwards just resizing
it to a smaller size (twice or three times smaller) in a graphics program. That
can give much better results (and much quicker) than having high quality focal
blur settings while rendering.
I don't know if this is of any use in this case, though.
Subject: Re: Piggy!
Date: 12 May 2009 13:58:50
Message: <4a09b8da$1@news.povray.org>
*Very* cute.
Could you try this without the blurred reflection code?
I'm not convinced there's much point to having multiple layer's of
blurred reflection if you've also got focal blur.
If you just have one rough surface normal with subpixel detail and I'd
have thought the multiple rays for the focal blur should produce nice
blurred reflections.
I'm guessing the reason for the slow down at the joints is due to
repeated blurred reflections between the legs/ears and the body.
If you do still feel the need to use blurred reflections (instead of
just focal blur) it's a lot faster to have two piggies with different
textures:
One little piggy with blurred reflections and set to no_reflection
Another with a simple surface but set to no_image.
That way you only get the cost of the blurred reflections at recursion
level one - so you are casting 5 reflection rays per pixel.
If you don't do this you could get 5 reflection rays at level one and 25
at level 2 and 5^n at recursion level n (as a worst case if you were
stood between two blurred mirrors)
