POV-Ray : Newsgroups : povray.binaries.images : weird media artifacts? Server Time
25 Mar 2026 19:48:32 EDT (-0400)
  weird media artifacts? (Message 21 to 22 of 22)
Subject: Re: weird media artifacts?
Date: 28 Feb 2009 18:50:00
Message: <web.49a9cd257ce87223f50167bc0@news.povray.org>
"clipka" <nomail@nomail> wrote:
> > Jerome wrote:
> >  Well, a POV internal error would be my first guess too, but that
> > doesn't tell Kenneth how to work around it in this scene...
> I think it does: Use POV 3.7 instead :P
> (Yeah, you're right though; admittedly I'm seeing this more from a developer's
> perspective, not the user's one...)
That's OK!  Keep those good comments and suggestions coming.
KW
Date: 1 Mar 2009 17:32:11
Message: <49ab0ceb$1@news.povray.org>
clipka nous illumina en ce 2009-02-27 19:38 -->
> Alain <ele### [at] netscapenet> wrote:
>> intervals 1 samples 100 is much FASTER than intervals 10 samples 10 or samples
>> 10,10. If you use samples 10, 50 the value after the coma is always ignored when
>> using the default sampling method.
> I never really managed to grasp why the intervals are there in the first
> place...
They are usefull when using sampling method 1 and 2. Useless, time consuming,
and can cause some artefacts with the default method 3. Method 3 is the default
since version 3.5. Before that, only method 1 was available.
Also, the syntax "samples Value1, Value2" is a left over of method 1 and 2. With
method 3, Value2 is always ignored.
Now, samples must be set to at least 3.
intervals default's to 1, and should be left alone.
A true friend is someone who reaches for your hand and touches your heart.
