POV-Ray : Newsgroups : povray.binaries.images : Rendering issues Server Time
25 Mar 2026 03:28:23 EDT (-0400)
  Rendering issues (Message 11 to 14 of 14)
Subject: Re: Rendering issues
Date: 13 Jan 2008 13:00:16
Message: <478a51b0@news.povray.org>
nemesis nous apporta ses lumieres en ce 2008/01/12 22:28:
> I can't help but ask why, why not simply normals?  it's not even a close up...
> there's enough issues with coincident surfaces in plain CSG, put isosurfaces to
> the mix and you're asking for trouble...
Normals would give you different results, the sadows would be different, as well
as the continuation between the different surfaces. That's even if you apply the
normals to the object as a whole. Even at this scale you'd have large difference.
REMEMBER: WHATEVER HAPPENS, HAPPENS FOR A REASON.
Date: 13 Jan 2008 18:27:13
Message: <478a9e51@news.povray.org>
jhu wrote:
> Wow! Thanks for the help and tips. That's some serious isosurface-kung-fu there.
I think Tim gave you the best solution to your problem, so I'll take
this opportunity to slip out the door :)
Sam
Date: 14 Jan 2008 21:45:00
Message: <web.478c1d756c6c555f7bcf5ca50@news.povray.org>
I think I'm going to give up on the isosurface room. Rendering takes way too
long especially with area lights and radiosity. On the other hand, I did get to
finally learn how to use these things.
BTW, is there an isosurface to mesh2 conversion utility?
Date: 14 Jan 2008 22:09:49
Message: <Ex3K+BCWHCjHFw8h@econym.demon.co.uk>
There's Kevin Loney's Approximation Macro. It's rather slow but you only
need to run it once, then you can save the mesh.
http://www.econym.demon.co.uk/isotut/approx.htm
If you can rewrite your isosurface as a parametric, then you can use
Ingo Janssen's Param.Inc, which is much faster.
http://www.econym.demon.co.uk/isotut/param.htm
Mike Williams
Gentleman of Leisure
