POV-Ray : Newsgroups : povray.binaries.images : image Server Time
18 Mar 2026 15:44:05 EDT (-0400)
  image (Message 16 to 25 of 35)
Subject: Re: image
Date: 6 Nov 2007 02:55:00
Message: <web.47301cdf2a06dfe9fceffeaf0@news.povray.org>
"Gail Shaw" <initialsurname@sentech sa dot com> wrote:
> "alphaQuad" <alp### [at] earthlinknet> wrote in message
> news:web.472f6d7d2a06dfe9c51101a30@news.povray.org...
> Added a line that may help.
> I usually do this with fog. See below.
my previous post was posted before reading your post. Will try this next but
should be some time before I have a report.
thank you Gail, it looks like what I could not conceive with so little
experience.
Subject: Re: image
Date: 6 Nov 2007 03:03:45
Message: <47301fe1$1@news.povray.org>
"alphaQuad" <alp### [at] earthlinknet> schreef in bericht
news:web.472f54862a06dfe9c51101a30@news.povray.org...
> For anyone following along here, think I found it.
http://news.povray.org/povray.binaries.images/thread/%3Cweb.4381be8f2e4ee441731f01d10%40news.povray.org%3E/?ttop=251451
> &toff=1300
That's the one.
> that was painful going back to nov 2005 and
> not reading some of the subjects, had to look away 'til got I there.
<grin>
Subject: Re: image - some code
Date: 6 Nov 2007 03:39:09
Message: <4730282d$1@news.povray.org>
This is the code I used in one of my images:
//-- start code --
#declare MoonMap =
   material {
            image_map {
               png   "PlanetMaps\MoonMap.png"
               map_type 1
               once
               interpolate 2
            scale <1,1,1>
            //rotate 90*x
         normal {
            bump_map {
               png   "PlanetMaps\MoonBump.png"
               map_type 1
               once
               interpolate 2
            scale <1,1,1>
            //rotate 90*x
            bump_size 1.0
         finish {
            ambient 0.0
            diffuse 0.5
      //rotate <20.0, 0.0, -25.0>
sphere { // Moon
  <0,0,0>,1
  material {
    MoonMap
  scale 80.0
  rotate -90*y
  translate <-300.0, 200.0, 1000.0>
// Sky
#declare BlueSkySphere =
           gradient y
           pigment_map {
            [0.0 rgb <0.6,0.7,1.0>*1.5 transmit 0.5]
            [1.0 rgb <0.437467, 0.824265, 1.0>*1.5 transmit 0.5]
         finish {
            ambient 0.9
            diffuse 0.0
#declare CosmosSkySphere =
            color rgbt <0,0,0,1>
         finish {
            ambient 0.0
            diffuse 0.0
sphere {
  <0,0,0>,1
  texture { BlueSkySphere }
  interior_texture { CosmosSkySphere } //using inverse puts the inside of
the sphere outside
  no_shadow
  no_reflection
  inverse // no need for hollow
  scale 400
//-- end code--
Subject: Re: image
Date: 6 Nov 2007 10:05:01
Message: <4730829d@news.povray.org>
alphaQuad napsal(a):
> from that I applied (inside and out) a gradient (as)"you would give a
> sky_sphere"
> with a transparency but apparently did not have the experience required.
> sphere { <0,0,0>, 2000.0
> interior_texture {
>  // ior 1.5
>     pigment {
>       gradient y
>         color_map {
>           [0.0 rgbf <0.6,0.7,1.0,1>]
>           [1 rgbf <0.4,0.5,0.8,1>]
>     finish { ambient 1 diffuse 0 }
scale the pigment 2000 times.
Subject: Re: image
Date: 6 Nov 2007 13:52:44
Message: <4730b7fc$1@news.povray.org>
alphaQuad nous apporta ses lumieres en ce 2007/11/06 02:39:
> well it was a labor to play with filters.
> and certainly a great deal of help was provided that gave some insight.
> Great.
> not happy with foggy clouds. they are bozo mapped. Bruno's look crisp.
> some ideas mentioned were not completely understood, maybe some day.
> (or some insightful and generous script posting)
> the gradient sphere was never seen but now that I think about it, that pattern
> would go away if you scale y maybe?
> PO
Nice! That's what I can call a beleiveable moon.
You know you've been raytracing too long when you wonder if ground fog or
athmosphere will look better for your company's market share pie chart.
Christoph Rieder
Date: 6 Nov 2007 14:00:01
Message: <web.4730b88ad7c6bfa28ab72f490@news.povray.org>
bump map retrieved from: (is this a good bumpmap?)
http://planetpixelemporium.com/earth.html
Because parts of this works with parts of what I have. rendered as is, there is
no moon with bump map so perhaps the map is in question.
This method does not light the water and detail is lost. Here I am at a loss as
to what to do, to bring back water detail and leave moon as is.
Scripts to scene-files for improvement - maps not included.
Download 'waterscene_06_thom.png' (658 KB)
Preview of image 'waterscene_06_thom.png'
Date: 6 Nov 2007 14:10:01
Message: <web.4730bb1dd7c6bfa28ab72f490@news.povray.org>
here color and detail lost but some water detail saved.
done by mapping a background plane with previous render.
I understand the idea, but pov can do this pre-render for you?
(thereby not losing detail?)
Download 'waterscene_06a_thom.jpg' (619 KB)
Preview of image 'waterscene_06a_thom.jpg'
Date: 6 Nov 2007 14:10:02
Message: <web.4730bb99d7c6bfa28ab72f490@news.povray.org>
Gail's fog method seems to have the effect of blending everything nicely and
lights the water detail
Download 'waterscene_07_gail.png' (180 KB)
Preview of image 'waterscene_07_gail.png'
Date: 6 Nov 2007 15:30:02
Message: <web.4730cdf2d7c6bfa28ab72f490@news.povray.org>
if anyone wants to work on waterscene_05, I've upload another zip to include
this file.
<web.4730cbc43264e6828ab72f490@news.povray.org>
was that a link? still learnin this board. it was here
http://news.povray.org/povray.binaries.scene-files/message/%3Cweb.4730cbc43264e6828ab72f490%40news.povray.org%3E/#%3Cwe
Download 'waterscene_05_aq.jpg' (601 KB)
Preview of image 'waterscene_05_aq.jpg'
Date: 6 Nov 2007 19:00:01
Message: <web.4730ff13d7c6bfa28ab72f490@news.povray.org>
final touch up
Download 'waterscene_09_aq.jpg' (619 KB)
Preview of image 'waterscene_09_aq.jpg'
