POV-Ray : Newsgroups : povray.binaries.images : Crater field update - Mars Server Time
1 Jan 2026 19:10:44 EST (-0500)
  Crater field update - Mars (Message 1 to 10 of 25)
Subject: Crater field update - Mars
Date: 14 Jul 2006 17:50:00
Message: <web.44b8114d6dbc0f41009749b0@news.povray.org>
I compiled the crater field generator code by PM 2Ring with a few
modifications:
New functionality:
1) If desired, large craters can now have a central peak.
2) You can specify erosion - the program will average the pixels the
specified
number of times to simulate eroded craters.
3) Output is to .bmp instead of PGM.  Unfortunately, in this current version
it's a 24-bit file with only 8 bits of info, so an 8000 x 8000 crater field
produces an output file somewhere around 187 MB.  But you can always
convert to .png after you make the .bmp output file.  Maybe I'll eventually
re-write this to produce 16-bit output (.pgm, .tga, or .png).
Also, maybe I'll create an option to import an existing hightfield.  That
would allow you to use a pregenerated landscape and then subject it to a
meteor storm.  Thoughts?
I ran this image 1200 x 1200 pixels, for 1 million craters.  Largest craters
have a radius of 120 pixels, with all craters larger than 100 pixels having
a central peak.
Mike
Download 'mars_craters.jpg' (73 KB)
Preview of image 'mars_craters.jpg'
Subject: Re: Crater field update - Mars
Date: 14 Jul 2006 18:25:01
Message: <web.44b81892b22ae3491009749b0@news.povray.org>
Here's the heightfield (a scaled down and compressed version).
Mike
Download 'craters.jpg' (43 KB)
Preview of image 'craters.jpg'
Date: 14 Jul 2006 23:15:01
Message: <web.44b85c22b22ae349de91941e0@news.povray.org>
> modifications:
Hmm....  Did your program make this image?  (Originally 4000x4000-16bit)
Download 'crater-quartersize.png' (252 KB)
Preview of image 'crater-quartersize.png'
Date: 15 Jul 2006 04:53:51
Message: <44b8ad1f$1@news.povray.org>
Why does it look like the craters are reversed?
Date: 15 Jul 2006 08:45:00
Message: <web.44b8e259b22ae34947d3ae5e0@news.povray.org>
Your screen is upside down.
I think it looks good, maybe could do with a little higher crater walls
though, and maybe a little less craters.
Date: 15 Jul 2006 10:39:47
Message: <44b8fe33@news.povray.org>
   Reversed as in inverted: The crater walls look like they are going
down into the ground, and the plateaus look like hills.
   No matter how long and how I look at the image, I can't see the
crater walls going up.
Date: 15 Jul 2006 14:11:20
Message: <44b92fc8@news.povray.org>
Warp nous apporta ses lumieres en ce 15/07/2006 04:53:
The light is comming from the BOTTOM left.
Christian Science #2: Shit happening is all in your mind.
Date: 15 Jul 2006 14:20:13
Message: <44b931dd$1@news.povray.org>
   No matter how long I look at it, I see bubbles, not craters.
   Perhaps one problem is that the crater walls don't cast shadows.
Date: 15 Jul 2006 14:45:22
Message: <44b937c2$1@news.povray.org>
Warp nous apporta ses lumieres en ce 15/07/2006 14:20:
They do cast slight shadows, toward the TOP and a little to the right, and ONLY on the
ground
outside of the craters. Those shadows are what make you see them as inverted.
Gossip is when you hear something you like about someone you don't.
Date: 15 Jul 2006 23:10:01
Message: <web.44b9ad23b22ae34910f27a7b0@news.povray.org>
> > modifications:
Probably, but it's not my program.  I only modified it to add some more
details.  And it only puts out 8-bit (for now).
Mike
