"Burki" <nomail@nomail> wrote in message
news:web.42a587f4a69f2e374f17dd8d0@news.povray.org...
> a normal statement in the camera itself. So the drops are no objects.
This is funny. I knew at first sight that the 1st image posted was probably
using a camera normal instead of a plane or something between the camera and
scene. Then when I saw those water drops I thought you redid it by using
actual droplet objects.
I doubt Wagner, there, was the only other person not realizing this. Nice
trick.
Bob Hughes
> trick.
> Bob Hughes
That's what I tought. The first is clearly a normal perturbation on the
camera. Because of the reflections on the main sphere of the second scene,
I tought the drops were real objects...
Wagner
You're fantastic, you know that?!
Man, some day I hope to be this cool...
> > trick.
> > Bob Hughes
> Wagner
Hi again,
some time ago, but anyway.
I posted the code for the sphere in the binaries section.
The posting is called "How to drench your monitor"
What I posted is the code for the wet ball, not for the shriek thing. The
latter one consists of 20 superellies that are randomly rescaled and
rotated:
#declare superelli =
superellipsoid {
<5,5>
scale 1.7
texture {mirrrror} // the same texture of the original sphere
// I put it into an .inc file
#declare rota = seed (42);
#declare scl = seed (43);
#declare i = 0;
#while (i < 20)
object {
superelli
rotate rand (rota) * 360
scale 1 + (rand (scl) - 0.5) * 0.3
translate 2*z
#declare i = i + 1;
But this thing needs 10 - 20 min to render!
Yours,
Bu.
Sorry, I meant scene files, not binaries, see
http://news.povray.org/povray.text.scene-files/thread/%3Cweb.42c911577f00d4b1d61e8c370%40news.povray.org%3E/
Yours,
Bu.
"Burki" <nomail@nomail> wrote:
> Stefan Viljoen <sviljoen@<removethis>polard.com> wrote:
> > Yeah! That's it - see if you remove the magnet maybe the lines start going
> > straight on the checkered plane...
I LIKE the image with the wavy checkerboard and the squashed sphere.
Does a magnet on top of a monitor fall into the category of "post-processing
an image"?? :-)
Perhaps you've discovered a completely new CGI technique!
Ken
