POV-Ray : Newsgroups : povray.binaries.images : The final word on blurred reflection Server Time
29 Mar 2026 05:26:35 EDT (-0400)
  The final word on blurred reflection (Message 1 to 10 of 16)
Subject: The final word on blurred reflection
Date: 20 Oct 2001 00:57:30
Message: <slrn9t20pd.ipv.ron.parker@fwi.com>
Well, it may be too early to call it the final word, but I think it's the
final word.  It gives all of the flexibility of the mythical 3.5 patch, with
mostly the same speed, and without making any changes to the code.  I think
it even works in 3.1.  The only limitation is the limit on size in a map, but
even that can be worked around with nested maps.  This is totally awesome.
Maybe I should go without sleep and/or caffeine more often...
Here's some scene code.  Go ahead; render it.  It won't bite.  Don't bother
with the antialiasing.  (I'd post a picture, but y'all have already seen one.)
If your computer has more horsepower than mine, please make that 10 bigger to
get more realistic results.  My render stats on a K6-2/350, 320x240, with no AA:
8 minutes 36 seconds.
Have fun, y'all.  Make sure you do lots of stuff I wouldn't do.
cylinder {<0,-5,15> <0,5,15> 4
    average texture_map {
      #declare I=0;
      #declare S=seed(12465);
      #while (I<10)  // use any value you want here; the higher the better.
        #declare I=I+1;
        [1
          pigment {color rgb 0}
          finish {diffuse 0 specular 0 ambient 0 reflection .8}
          normal {bumps .1 scale <.001,.001,.001>
                  translate <.002*rand(S),.002*rand(S),.002*rand(S)>}
light_source {-10*x red 1}
light_source {  0   green 1}
light_source { 10*x blue 1}
plane {z, -1 pigment {color rgbf 1} finish {specular 1 roughness .1 diffuse 0}}
plane {y,-5
  pigment {checker color rgb 1, color rgb 0}
  rotate 30*y
  finish {ambient .5}}
sphere {0 20 inverse
  pigment {agate color_map {[0 rgb <.5,.5,1>][1 rgb 1]}  scale 3}
  finish {diffuse 0 specular 0 ambient 1}
#macro R(L P)sphere{L __}cylinder{L P __}#end#macro P(_1)union{R(z+_ z)R(-z _-z)
R(_-z*3_+z)torus{1__ clipped_by{plane{_ 0}}}translate z+_1}#end#macro S(_)9-(_1-
_)*(_1-_)#end#macro Z(_1 _ __)union{P(_)P(-_)R(y-z-1_)translate.1*_1-y*8pigment{
rgb<S(7)S(5)S(3)>}}#if(_1)Z(_1-__,_,__)#end#end Z(10x*-2,.2)camera{rotate x*90}
Subject: Re: The final word on blurred reflection
Date: 20 Oct 2001 01:10:39
Message: <slrn9t21hb.irf.ron.parker@fwi.com>
Oops, turns out I did have AA turned on.  But it's not necessary for the
effect.
#local R=rgb 99;#local P=R-R;#local F=pigment{gradient x}box{0,1pigment{gradient
y pigment_map{[.5F pigment_map{[.3R][.3F color_map{[.15red 99][.15P]}rotate z*45
translate x]}]#local H=pigment{gradient y color_map{[.5P][.5R]}scale 1/3}[.5F
pigment_map{[.3R][.3H][.7H][.7R]}]}}}camera{location.5-3*z}//only my opinions
Date: 20 Oct 2001 03:00:48
Message: <3bd12120$1@news.povray.org>
This is very smart. Good thinking.
- Slime
[ http://www.slimeland.com/ ]
[ http://www.slimeland.com/images/ ]
"Ron Parker" <ron### [at] povrayorg> wrote in message
news:slr### [at] fwicom...
no AA:
> effect.
1/3}[.5F
opinions
Date: 20 Oct 2001 03:03:26
Message: <3bd121be$1@news.povray.org>
Oh, it seems if you set the 10 higher than 255, it tells you that the blend
map is too long. And then, if you set it to something lower afterwards,
POV-Ray crashes.
- Slime
"Slime" <noo### [at] hotmailcom> wrote in message
news:3bd12120$1@news.povray.org...
> - Slime
with
> no AA:
> > effect.
> 1/3}[.5F
> opinions
Date: 20 Oct 2001 03:08:13
Message: <3bd122dd$1@news.povray.org>
OK, one more thing; I got better results with the following texture block,
which removes the randomness of the whole thing:
      #declare numiters = 255;
      #declare ix=0;
      #while (ix<pow(numiters,1/3)-1)
       #declare iy=0;
       #while (iy<pow(numiters,1/3)-1)
        #declare iz=0;
        #while (iz<pow(numiters,1/3)-1)
          [1
                    translate <.002*ix,.002*iy,.002*iz>}
          #declare iz=iz+1;
         #declare iy=iy+1;
         #declare ix=ix+1;
- Slime
news:3bd121be$1@news.povray.org...
blend
> POV-Ray crashes.
> - Slime
> > - Slime
> with
> > no AA:
the
> > > effect.
> > 1/3}[.5F
> > opinions
Date: 20 Oct 2001 03:52:12
Message: <3BD12D38.20359B2B@ignorancia.org>
> effect.
  I know... I was just doing this same thing! I was also surprised to
see how average worked so well. It is slow, yes, but it has de advantage
of being slow only on the object with the texture, not in all the scene,
as a heavy aa.
Jaime Vives Piqueres
http://www.ignorancia.org/
Date: 20 Oct 2001 04:03:21
Message: <3bd12fc9@news.povray.org>
news:3bd122dd$1@news.povray.org...
>       #declare ix=0;
>        #declare iy=0;
>         #declare iz=0;
>           [1
>           #declare iz=iz+1;
>         #end
>          #declare iy=iy+1;
>   #end
>          #declare ix=ix+1;
>       #end
Yup, looks a lot better and ten times slower...
Now to add it to my car. Maybe it'll be finished before Christmas...
- Nekar
Version: 6.0.282 / Virus Database: 150 - Release Date: 2001/09/25
Date: 20 Oct 2001 10:30:53
Message: <3bd18a9d@news.povray.org>
Yeah, the old average trick with different normals is always handy. I used a
similar technique to obtain the look of brushed metal quite a while ago:
http://rsj.mobilixnet.dk/3d/goodies/goodies.html
Rune
Rune's World:    http://rsj.mobilixnet.dk (updated June 26)
Date: 20 Oct 2001 10:33:42
Message: <3bd18b46@news.povray.org>
> POV-Ray crashes.
Yep, it would, since blend maps are still limited to 255 entries.  I don't know
about it crashing afterwards.  If it's 3.5b6, perhaps it should be reported if
you can repeat it.
Michael
#declare R=<8,4,.6>/3;#declare C=function{pattern{object{text{ttf"crystal.ttf"
"MDJ"1,0translate-R/4}}}}camera{location-z*30}box{-R,R pigment{rgbf 1}interior
{media{emission.1density{function{C(x,y,z)}density_map{[0mandel 50color_map{[0
rgb 0][.2rgb x][1rgb x+y]}interior 1,1.5scale 60translate<-33.75,2.85>exponent
4][1rgb<2,2>]}}}}scale 24hollow}// (c) 2001 MDJohnson red### [at] wvadelphianet
Date: 20 Oct 2001 10:34:36
Message: <slrn9t32p5.jfb.ron.parker@fwi.com>
>> POV-Ray crashes.
>you can repeat it.
It happened to me, too.  I'll report it. :)
#local R=<7084844682857967,0787982,826975826580>;#macro L(P)concat(#while(P)chr(
mod(P,100)),#local P=P/100;#end"")#end background{rgb 1}text{ttf L(R.x)L(R.y)0,0
translate<-.8,0,-1>}text{ttf L(R.x)L(R.z)0,0translate<-1.6,-.75,-1>}sphere{z/9e3
4/26/2001finish{reflection 1}}//ron.parker@povray.org My opinions, nobody else's
