POV-Ray : Newsgroups : povray.binaries.images : Airbubbles in icicle test Server Time
6 Mar 2026 17:09:00 EST (-0500)
  Airbubbles in icicle test (Message 1 to 5 of 5)
Subject: Airbubbles in icicle test
Date: 26 Dec 2010 13:23:13
Message: <op.vob2owkz0819q0@gdsentropy.nc.rr.com>
Single icicle with air bubbles, rendered in 4.5min.
I do not know what to think about this prototype yet.
I am happy with the irregular shapes formed by the bubbles, but not
completely satisfied with the distribution.
Real icicles are formed in layers, which I could do by (I think) a method
similar to the way I test if the air bubbles are "inside" the icicle
object.
Right now I construct a sphere based approximation of the icicle and test
against that to determine if the air bubbles are "inside" the real icicle
object. I suppose if I executed a recursive orbiting trace() of that
object, placing air bubbles as well as perhaps *slightly* varying the IOR
of each layer, I might be able to emulate something like what you see at
the following link:
http://www.physics.utoronto.ca/~smorris/edl/icicleripples/icicleripples.html
Any thoughts?
Branching as seen in the following link is next:
http://farm4.static.flickr.com/3475/3238212338_9245029bf5.jpg?v=0
Ian McDonald
Lean Agile .NET 4.0/MVC
Senior Application Architect,
Developer and Security Analyst
Download 'blobtest2011_7.png' (45 KB)
Preview of image 'blobtest2011_7.png'
Subject: Re: Airbubbles in icicle test
Date: 26 Dec 2010 19:15:01
Message: <web.4d17d966105f230966554e20@news.povray.org>
I agree the distribution is not right, but the bubbles do add a great deal of
interest to the icicle. You are certainly on the right track.
Dave Blandston
Date: 26 Dec 2010 19:31:18
Message: <op.vocjqfd60819q0@gdsentropy.nc.rr.com>
I hit the 1 million blob component limit using the air bubbles...so
unfortunately I will not be including that in my first alpha release. :(
On the other hand, they are useless to even have unless you are looking
fairly closely at an icicle...so for general use this will not be an
issue. I will re include that functionality in alpha 2.
Alpha 1 will be released as soon as I clean up the code and polish a few
things, probably hours away now.
> deal of
> Regards,
> Dave Blandston
Ian McDonald
Date: 27 Dec 2010 18:48:29
Message: <4d1925cd$1@news.povray.org>
It may be a viable, if not totaly satisfying, compromise to difference
the air bubbles using a second blob, used uniquely for that purpose.
One blob for the icicle and a second, or 2 or 3 in extreme cases, for
the bubbles.
Normaly, those don't realy contribute to the overall shape.
Date: 27 Dec 2010 20:40:36
Message: <op.voehlvkp0819q0@gdsentropy.nc.rr.com>
ng
few
> the bubbles.
> Alain
I postponed the alpha release for a bit to integrate duplicate avoidance
nearly done with that now, so maybe that will help that as well as impro
ve
general performance.
I suppose a separate blob would be an option, thank you. :) I will explo
re
this issue more once I get the alpha out.
Ian McDonald
