Added a block of buildings in the background. Also added windows, doors
and grass.
I keep running out of memory so I made less grass than I wanted to. I'm
considering converting the walls to a heightfield, but only when the
building is 100% right. Maybe now is the time to start.
Comments and critique will be appreciated.
-Nekar Xenos-
Download 'sunfloweralley3.png' (1305 KB)
Preview of image 'sunfloweralley3.png'
"Nekar Xenos" <nek### [at] gmail com> schreef in bericht
news:op.vcv2eba9ufxv4h@go-dynamite...
> and grass.
Grimly beautiful indeed.
You could use heightfields for the wall sections farther from the camera.
That might already make a difference.
On Tue, 18 May 2010 09:38:08 +0200, Thomas de Groot
>> and grass.
-Nekar Xenos-
> and grass.
Looking better and better!
It doesn't look like a particularly memory-hungry scene... what is it that's
using most of the memory? I would have thought that a heightfield wall would
take far more memory than the equivalent mesh bricks.
Debugging memory usage in POV-Ray scenes is a little-mentioned but very
important task! Turn off media and radiosity and see what the scene uses (render
small with no aa for a quick answer). If it's still eating loads, try
commenting-out elements of the scene and render again to see how the usage
changes. You won't need hi-res bricks unless you intend rendering a huge final
version; in fact, they should be one of the smallest scene elements (memory and
speed were the main motivations for my mesh macros). Lower mesh (and heightfield
- same thing!) resolutions until they're on the threshold of the quality you're
happy with. Make simple low-detail versions for distant objects. Can you get
away with clever normals instead of meshes/isosurfaces?
Hope this helps :)
On Tue, 18 May 2010 10:29:46 +0200, Bill Pragnell
>> and grass.
Thanks!
> that's
> would
The close brick wall consists of a mixture of isosurface, high and low
poly mesh bricks. Further away are low poly mesh bricks.
> (render
> usage
> final
> (memory and
> heightfield
> you're
> get
Thanks. I'll take a look and see. I'll give the normals a try.
-Nekar Xenos-
This is a really neat image. I think the cyan color at the far end of the alley
creates a surreal effect. For that reason it kind of reminds me of a "Twilight
Zone" scene.
Dave Blandston
I really love those bricks!
> the alley
> "Twilight
> Zone" scene.
> Regards,
> Dave Blandston
Thanks. That's what I was going for :)
-Nekar Xenos-
On Wed, 19 May 2010 03:00:28 +0200, TC get-enough-spam-already-2498.com>
I'll put the macro on the Pov Object Collection when I've fixed it up
nicely.
-Nekar Xenos-
I've never looked at the size of my include files before. It turns out my
mesh bricks were 9Mb each. 6 of them. I'll just have to use lower poly
bricks...
-Nekar Xenos-
