POV-Ray : Newsgroups : povray.binaries.images : new earth renders Server Time
12 Sep 2025 06:52:29 EDT (-0400)
  new earth renders (Message 1 to 7 of 7)
Subject: new earth renders
Date: 23 Sep 2004 08:05:02
Message: <ciue0t$b6n$1@chho.imagico.de>
I have put up a new gallery with more detailed renders of the earth surface:
http://www.tu-bs.de/~y0013390/pov/earth2.html
I used the same technique as for the older images but the data for these
is much higher resolution (3 instead of 30 arc seconds for the height
data).  I also tried more detailed images for the surface color but
apart from the low resolution the MODIS images are quite unbeatable (no
shading and clouds, constant quality).
Last updated 23 Sep. 2004 _____./\/^>_*_<^\/\.______
Subject: Re: new earth renders
Date: 23 Sep 2004 08:54:44
Message: <4152c794@news.povray.org>
> surface:
> Christoph
A-bloody-mazing
Or in plain English : Very well done with very beautiful results :)
Ger
Date: 23 Sep 2004 08:55:08
Message: <knh5l095dr1robjdutvo1kfuk6pfevga99@4ax.com>
On Thu, 23 Sep 2004 14:02:36 +0200, Christoph Hormann <chr### [at] gmxde>
Impressive and beautiful.
Times/memory/POV version ?
ABX
Date: 23 Sep 2004 09:09:55
Message: <4152cb23@news.povray.org>
news:ciue0t$b6n$1@chho.imagico.de...
: I have put up a new gallery with more detailed renders of the earth surface:
: http://www.tu-bs.de/~y0013390/pov/earth2.html
Those are wonderful!
=Bob=
Date: 23 Sep 2004 09:40:02
Message: <ciujh7$e0j$1@chho.imagico.de>
Thanks.
A few hours/between 100 and 800 MB/MegaPOV 1.1
Date: 23 Sep 2004 14:21:58
Message: <41531446@news.povray.org>
High!
> surface:
Awesome... simply awesome!!!
Of course, I started picking the 3 arcsecond files for Afghanistan just
after I read about the newly published data sets...
I hope that meanwhile even a 0.3 arcsecond (equalling 10 meters per
pixel at the equator) survey is in progress or at least planned for the
nearer future... so I wouldn't have to tackle with those Soviet-made
1:100,000 military maps, nor with the enormous task to program an
interpolation tool for manually extracted contour lines...
See you in Khyberspace -
http://home.arcor.de/yadgar/khyberspace/index-d.html
Afghanistan Chronicle: http://home.arcor.de/yadgar/
Yadgar
Now playing: Albedo 0.39 (Vangelis)
Date: 23 Sep 2004 17:26:53
Message: <41533f9d$1@news.povray.org>
> surface:
> these is much higher resolution (3 instead of 30 arc seconds for the
> height data).  I also tried more detailed images for the surface
> color but apart from the low resolution the MODIS images are quite
> unbeatable
> (no shading and clouds, constant quality).
Almost as good as looking out the plane window!
