POV-Ray : Newsgroups : povray.binaries.images : "distortion_field"(fun with eval_pigment()) - 3dHF.jpg (1/1) Server Time
24 Mar 2026 10:43:42 EDT (-0400)
  "distortion_field"(fun with eval_pigment()) - 3dHF.jpg (1/1) (Message 2 to 11 of 11)
<<< Previous 1 Messages Goto Initial 10 Messages
Subject: Re: "distortion_field"(fun with eval_pigment()) - 3dHF.jpg (1/1)
Date: 24 Jun 2000 18:42:15
Message: <39553A05.9DB06DD4@aol.com>
That's cool! I can't figure out a use for it right at the moment, except
looking neat :)
Chris Huff wrote:
> Kind of a 3D height_field...each point is moved by an amount depending
> on the color of a pigment at that point. I will post the source code if
> anyone is interested.
> Christopher James Huff - Personal e-mail: chr### [at] maccom
> TAG(Technical Assistance Group) e-mail: chr### [at] tagpovrayorg
> Personal Web page: http://homepage.mac.com/chrishuff/
> TAG Web page: http://tag.povray.org/
Samuel Benge
E-Mail: STB### [at] aolcom
Visit my isosurface tutorial at http://members.aol.com/stbenge
Date: 24 Jun 2000 23:36:58
Message: <39557e5a@news.povray.org>
"Chris Huff" <chr### [at] maccom> wrote in message
news:chrishuff-A9E786.15235224062000@news.povray.org...
| will post the source code if anyone is interested.
Like you even have to ask?
Must say that I don't quite understand this object.  Were there sufficient
displacement from within the outer surface would that break through the
surface, or overlap along a surface?  This here appears to never go beyond the
adjacent point, so I'm guessing it has a limitation in locations of points
regarding the neighboring points.  I'm just making an observation, not being
critical.
Date: 25 Jun 2000 10:15:17
Message: <395613f5@news.povray.org>
can you do a jiggly cube animation with it?
Date: 25 Jun 2000 11:16:08
Message: <chrishuff-B3A8E8.10203725062000@news.povray.org>
Actually, I already wrote the code for it and did a test render.
Unfortunately, I used too much motion, so it wasn't clearly visible,
though I fixed that.
It is quite simple, just use phase or translate the pigment.
Date: 25 Jun 2000 11:24:27
Message: <chrishuff-8E698B.10285625062000@news.povray.org>
In article <39557e5a@news.povray.org>, "Bob Hughes"
I will post it in povray.text.scene-files. :-)
> sufficient displacement from within the outer surface would that
> break through the surface, or overlap along a surface?  This here
> appears to never go beyond the adjacent point, so I'm guessing it has
> a limitation in locations of points regarding the neighboring points.
>  I'm just making an observation, not being critical.
Just imagine taking a 3D grid, getting the color of a pigment at each
"node", and moving that node a certain amount depending on the color.
I actually used the color vectors to store offset vectors, the color_map
interpolates between them.
I provided a variable to "scale" the amount of motion down. I can turn
it up so you end up with a unrecognizeable, tangled mess of cylinders
and spheres, or scale it down so you have a slightly jittered grid.
BTW, this also demonstrates a possible feature I have been thinking of
trying: some kind of "displacement" warp for textures, and maybe even
the ability to warp meshes(if I can figure out their code). Not quite
"displacement mapping", but close.
Date: 25 Jun 2000 11:33:54
Message: <39562662@news.povray.org>
news:chrishuff-8E698B.10285625062000@news.povray.org...
Thanks.
I think I understand that.  rgb controlled, like "color vectors" in an object
placement sense.
Date: 25 Jun 2000 14:04:50
Message: <t8iclscf4bgfanocg4hb9qpn02b1o9b5qs@4ax.com>
On Sun, 25 Jun 2000 10:28:56 -0500, Chris Huff <chr### [at] maccom>
Oh please do add this! It has been on my wishlist for years and I have
suggested it several times. I really hate myself for not being able to
program, argh!
>and maybe even
That shouldn't be necessary if the eval_* functions make it into the
official because I am sure Chris and Warp will come up with something
along the same lines.
Peter Popov ICQ : 15002700
Date: 25 Jun 2000 15:31:47
Message: <chrishuff-0F51EF.14361625062000@news.povray.org>
In article <t8iclscf4bgfanocg4hb9qpn02b1o9b5qs@4ax.com>, Peter Popov
> program, argh!
It is done. :-)
> >and maybe even
It is possible to do it with the eval_* and vwarp() functions...but the
patch parses a lot faster(I have a mostly complete patch...but it
doesn't quite work yet)
Date: 29 Jun 2000 02:06:05
Message: <395AE653.C83A7A3E@pacbell.net>
Interesting but I like to model this kind of thing by hand. It's more
challenging that way.
Date: 29 Jun 2000 08:36:48
Message: <chrishuff-15C2BD.07365229062000@news.povray.org>
In article <395AE653.C83A7A3E@pacbell.net>, lin### [at] povrayorg
You have hands?!?
Who made them? Are they designed after human hands, or are they the
usual "robotic claw" type? Do they have tactile feedback, or just
limiters so you don't break bones when you shake hands?
