POV-Ray : Newsgroups : povray.binaries.images : More glow stuff - attached files (1/1) Server Time
19 Apr 2026 08:49:44 EDT (-0400)
  More glow stuff - attached files (1/1) (Message 21 to 30 of 49)
Subject: Re: More glow stuff - attached files (1/1)
Date: 3 Sep 2000 19:33:00
Message: <slrn8r5l71.9i7.steve@zero-pps.localdomain>
I just love these, can't wait till we get a unix/linux
version.
 11:13pm  up 13 days,  3:31,  2 users,  load average: 2.08, 1.94, 1.92
Subject: Re: More glow stuff - attached files (1/1) - tree.jpg (1/1)
Date: 3 Sep 2000 20:53:35
Message: <chrishuff-6DB995.19551603092000@news.povray.org>
Date: 3 Sep 2000 21:49:56
Message: <39b2ffc4@news.povray.org>
"Chris Huff" <chr### [at] maccom> wrote :
> Hows this?
    Ooo... Pretty lights.... want pretty lights....
Date: 3 Sep 2000 22:14:03
Message: <39b3056b@news.povray.org>
> Does that happen very often? Maybe you should go see a doctor...
I've asked them to increase the dosage of my medication to help reduce it.
> I admit that is one use I never thought of.
Well, now you've just got to try it.
Date: 4 Sep 2000 03:58:16
Message: <39B35654.A220D402@schunter.etc.tu-bs.de>
Chris Huff wrote:
> Hows this? I didn't have time to write a coniferous tree macro, or even
> a good deciduous tree macro, and I need to tweak the color calculations
> of the individual glows to be more vivid, but it looks pretty neat. No
> light sources, just glows.
That looks quite good, although initially i thought of houses, fences, etc.
decorated with those glows.  Combined with some radiosity and some street lamps
it could make a quite realistic nighttime atmosphere.
Date: 4 Sep 2000 08:17:26
Message: <39B392DA.8DDAB99@enst.fr>
Chris Huff wrote:
> And it shouldn't slow the
> rendering down too much, since the visibility checking could be done
> before the rendering. You could do something similar in POV-Script,
> using the trace() function to disable a glow if something passes in
> front of it.
	But then it wouldn't work with reflection/refraction would it?
Actually, I think that the checking needs to be done for each ray which
would slow things down :(
Date: 4 Sep 2000 10:20:54
Message: <chrishuff-7E2F64.09223404092000@news.povray.org>
Date: 4 Sep 2000 10:37:59
Message: <39B3B3C6.7BF803FA@enst.fr>
> Why? Checking from the camera position should be enough.
	I should have added: "if you want it to work with
reflection/refraction". To get the winking out effect in the
reflections, you'd need to check for each ray if the center of the glow
would be visible from the starting point of that ray, then if it is
visible, compute the glow effect for the ray, otherwise ignore it. But
then of course you'd have the same kind of limitations that led to the
introduction of photons, so I guess it's mainly a question of how
perfect you want it to be (and what would be "perfect" in this case
since we're talking about an artistic effect and not a physical one...)
Date: 4 Sep 2000 10:39:35
Message: <chrishuff-7F04FB.09411504092000@news.povray.org>
Date: 4 Sep 2000 14:13:01
Message: <39b3e62d$1@news.povray.org>
Nice new feature! Sure is alot of salivating going on in this thread.
