POV-Ray : Newsgroups : povray.binaries.images : Radiosity data [4x ~11kB] Server Time
20 Sep 2025 11:40:24 EDT (-0400)
  Radiosity data [4x ~11kB] (Message 1 to 10 of 14)
Subject: Radiosity data [4x ~11kB]
Date: 30 Apr 2001 08:45:34
Message: <Xns9093967D7FA7Eseed7@povray.org>
Playing a bit with the saving and loading radiosity data option in
MegaPov, to get rid of the blue images when using a blue sky_sphere.
 Blue_blue_rad.jpg shows the standard situation, radiosity with a blue
sky_sphere.
 Blue_wh_rad.jpg, here the radiosity data are used of a rendering with
a white sky. In the final there is of course the blue one.
 Blue_red_rad.jpg, now with the radiosity data of a red sky.
 Blue_wh_nc_rad.jpg, white radiosity data, but in the final all object
colours are removed.
Ingo
Download 'Blue_blue_rad.jpg' (10 KB) Download 'Blue_wh_rad.jpg' (11 KB) Download 'Blue_red_rad.jpg' (11 KB) Download 'Blue_wh_nc_rad.jpg' (10 KB)
Preview of image 'Blue_blue_rad.jpg'
Preview of image 'Blue_wh_rad.jpg'
Preview of image 'Blue_red_rad.jpg'
Preview of image 'Blue_wh_nc_rad.jpg'
Subject: Re: Radiosity data [4x ~11kB]
Date: 30 Apr 2001 10:52:10
Message: <3aed7c1a@news.povray.org>
> sky_sphere.
Interesting, especially the last one.  You can see just how much yellow the
the rearmost ellipsoid picks up from the forward one, and how much blue the
main ellipsoid picks up from the ground, as compared to the sky.  On the
whole, the differences are fairly subtle, but placing the pics next to each
other really helps.
I'd be interested in seeing the no object colors for the other skies.
Geoff
Date: 30 Apr 2001 11:17:54
Message: <Xns9093B0515A34Cseed7@povray.org>
As requested.
Removing objects is also fun.
Ingo
Download 'No_obj_rad.jpg' (12 KB) Download 'Blue_red_nc_rad.jpg' (10 KB) Download 'Blue_blue_nc_rad.jpg' (10 KB)
Preview of image 'No_obj_rad.jpg'
Preview of image 'Blue_red_nc_rad.jpg'
Preview of image 'Blue_blue_nc_rad.jpg'
Date: 1 May 2001 08:48:11
Message: <3AEEB0B4.9AF46A99@gmx.de>
> sky_sphere.
That looks interesting, have you also tried changing the light sources?
Date: 1 May 2001 13:58:47
Message: <3aeef957@news.povray.org>
>> sky_sphere.
Yeah.  Maybe try it with no light sources at all, and ambient set to 0.
That would give a good idea exactly how much radiosity is doing in different
cases.
Geoff
Date: 1 May 2001 16:54:14
Message: <Xns9094E95D2FCEDseed7@povray.org>
> sources?
Not yet, as it currently takes two renderings per image. It would be
nice if the whole process could be automated within POV-Ray. Do the
pretrace, save data, flip the value of a switch/constant, parse the
scene again and render with the gathered radiosity data.
Ingo
Date: 1 May 2001 16:57:00
Message: <Xns9094E9D392635seed7@povray.org>
> to 0. That would give a good idea exactly how much radiosity is
> doing in different cases.
 Is this what you mean. Radiosity data gathering passage, one white
light_source and a sky:
pigment {gradient y color_map {[0, rgb 0.6] [1, rgb 1]}}
 Rendering passage no light, no sky.
Ingo
Download 'rad.jpg' (9 KB)
Preview of image 'rad.jpg'
Date: 2 May 2001 07:20:12
Message: <3aefed6c@news.povray.org>
Exactly.  However, I didn't realize that radiosity makes standard lighting
irrelevant, which it obviously does, or the objects wouldn't be so bright.
I thought it was just an 'extra' light that was added when the color was
determined.
So I learned something from the pic, at least. ;)
Geoff
Date: 2 May 2001 07:21:17
Message: <3aefedad@news.povray.org>
>> sources?
Should be pretty easy using the clock variable.  Just animate a sequence of
two shots, and #if the variables that change.
Geoff
Date: 2 May 2001 08:27:13
Message: <dvqvetgsa97drekp8a1d6nunenfuhrtoq9@4ax.com>
You could do that with the Pre_Scene_Command and Post_Scene_Command
INI file options.
Peter Popov ICQ : 15002700
