POV-Ray : Newsgroups : povray.binaries.images : Radiosity data [4x ~11kB] Server Time
25 Mar 2026 09:15:15 EDT (-0400)
  Radiosity data [4x ~11kB] (Message 11 to 14 of 14)
Subject: Re: Radiosity data [4x ~11kB]
Date: 2 May 2001 09:48:10
Message: <Xns9095A121C58D9seed7@povray.org>
in <dvqvetgsa97drekp8a1d6nunenfuhrtoq9@4ax.com> Peter Popov wrote:
> You could do that with the Pre_Scene_Command and Post_Scene_Command
> INI file options.
 My problem with this and Geoff's solution is that you have to render
the complete image twice. The render data are saved when the first
render is completly done, not just after the the pretrace is done.
 When rendering the second image, the pretrace sequence seems to be
done again. Or is this just the reading of the data file?
Ingo
Date: 2 May 2001 10:24:17
Message: <3af01891@news.povray.org>
>> INI file options.
I would assume (perhaps incorrectly) that the pretrace would read in the
file, just as it does when you do it manually.  Or is there something funky
you do in the manual reads?
Geoff
Date: 2 May 2001 11:39:59
Message: <Xns9095B416FC03Bseed7@povray.org>
> in the file, just as it does when you do it manually.  Or is there
> something funky you do in the manual reads?
 Changed count from 80 to 1000 to see if there is a time difference.
First pass the pretrace is finished after 18 min. Total render time, 45
min.
 Second pass, reading the data/ pretrace, 4 min. Total render time 6
min. Quite a big difference, I didn't notice in the earlier experiments
as the total rendertime's where mutch shorter.
Ingo
Date: 2 May 2001 12:07:01
Message: <3af030a5@news.povray.org>
> min.
Yes, that'd make a big difference.  adding the always_sample off might also
make a difference.
Geoff
