POV-Ray : Newsgroups : povray.binaries.images : gallery - gallery9_lowkb.jpg [0/1] Server Time
13 Apr 2026 20:31:43 EDT (-0400)
  gallery - gallery9_lowkb.jpg [0/1] (Message 11 to 20 of 34)
Subject: Re: gallery - gallery9_lowkb.jpg [1/1]
Date: 30 Mar 2001 02:12:58
Message: <3AC431E5.EA559D5@spiritone.com>
I love what you did with the stand. It was quite original. I think the
lights should be aimed at the pieces, however, to highlight them. I
would also use a different texture with the statue in the background so
it stands out just a little bit more and doesn't attach itself visually
to the wall so much
Josh English
eng### [at] spiritonecom
Date: 30 Mar 2001 06:03:36
Message: <gfp8ctg1qffjln61frtschfo6r2sublis5@4ax.com>
On Thu, 29 Mar , Lutz-Peter Hooge wrote:
<image>
This image has a great feeling of depth.  I want to see what is round the bend!  And
what is
in the central part of the building?  The pictures are good too.
Any chance of an animation taking us on a tour of this display area?
David
dav### [at] hamiltonitecom
http://hamiltonite.com/
Date: 30 Mar 2001 11:14:45
Message: <MPG.152ecff6785974f69896a3@news.povray.org>
In article <3ac3c6fc@news.povray.org>, big### [at] mariner9fsnetcouk
says...
> That central sculpture could have somebody's eye out!! It's a law suit
> waiting to happen.
The end of the "arms" are above eye-level, you would have to jump at it
to injure yourself ;-)
> Nice render though.
Thanks
Lutz-Peter
Date: 30 Mar 2001 11:21:40
Message: <MPG.152ed19cba878f419896a4@news.povray.org>
In article <3AC### [at] spiritonecom>, eng### [at] spiritonecom
says...
Yes, in a real gallery they would, but I mainly added the lamps to light
up the shadows.
> to the wall so much
I thought it would be too similar to the one in the foreground if it had
the same texture.
Lutz-Peter
Date: 30 Mar 2001 11:27:52
Message: <MPG.152ed309d63706299896a5@news.povray.org>
In article <gfp8ctg1qffjln61frtschfo6r2sublis5@4ax.com>,
dav### [at] blueyondercouk says...
Would take a BIT too long to render...and wouldn't be very interesting in
its current state (the room behind the bend is very much empty) ;-)
Date: 30 Mar 2001 11:29:53
Message: <MPG.152ed381be0abf849896a6@news.povray.org>
In article <3AC3AC1F.7B89E128@gmx.de>, chr### [at] gmxde says...
> Not necessarily if you thereby avoid a lot of additional light sources.  I
> would definitely try it.
Ok, i'll try it.
Somebody has good rad. settings? I havn't done anything with MegaPovs
radiosity yet.
Lutz-Peter
Date: 30 Mar 2001 11:42:32
Message: <3AC4B820.9079498C@inapg.inra.fr>
> radiosity yet.
Below is what I use for most of my radiosity images.
Use HQOn=0 for tests (fast), HQOn=1 for final render and HQOn=2 if you really
have some trouble with radiosity artefacts (may not be enough though).
Turn all "ambient" to 0 and all "diffuse" to 1 for regular objects. You may have
to tweak the light intensities, color intensities, light color and sky color to
get proper effects.
G.
#declare HQOn=1;
#declare QR=1;
global_settings{
        assumed_gamma 1
        max_trace_level 15
        #if (QR=1)
            ini_option "+QR"
        radiosity{
            pretrace_start 1
            pretrace_end   1
            #switch (HQOn)
                #case (0)
                    count 100 error_bound 1
                #break
                #case (1)
                    count 800 error_bound 0.02
                #break
                #case (2)
                    count 1600 error_bound 0.02
                #break
            nearest_count 4
            recursion_limit 1
            low_error_factor 1
            gray_threshold 0
            minimum_reuse 0.015
            brightness 2
            adc_bailout 0.01/2
            normal on
http://www.oyonale.com
Graphic experiments
Pov-ray gallery
Date: 30 Mar 2001 11:48:16
Message: <3AC4B8D0.47B58239@gmx.de>
>             brightness 2
Are you sure about that?
brightness 1 is a fairly universal value that should be realistic in most
cases.  If you change an existing scene for using radiosity, it's often
even useful to use lower values.
Date: 30 Mar 2001 12:25:05
Message: <3ac4c171@news.povray.org>
In the room WIP I posted a while ago which only has one window I have to use
a brightness of above 3 to be able to see anything except blackness, it all
depends on how much of the scene is actually lit by direct light. I
regularly use a brightness of about 2 though.
Kev
http://perso.libertysurf.co.uk/kevin.ellis
Date: 30 Mar 2001 12:29:30
Message: <MPG.152ee17af1ee8c6e9896a7@news.povray.org>
In article <3AC4B8D0.47B58239@gmx.de>, chr### [at] gmxde says...
I had to set it so 0.3, at 1 everything is white... maybe because I use
colors > rgb 1.
But theres another problem: 0 PPS even with HQOn=0 :-(
Only if I switch EVERYTHING off (reflections, isosurfaces, arealights
etc), I can get a preview.
Lutz-Peter
