POV-Ray : Newsgroups : povray.binaries.images : A quick povr branch micro normal image. Server Time
18 May 2024 19:41:25 EDT (-0400)
  A quick povr branch micro normal image. (Message 31 to 40 of 97)
Subject: Re: A quick povr branch micro normal image.
Date: 26 Jan 2022 10:03:03
Message: <61f162a7$1@news.povray.org>
On 2022-01-26 09:39 (-4), Cousin Ricky wrote:
> I just looked back at my images, and though f_ridged_mf() showed no
> signs of inversion, f_ridge() most certainly did.  However, I have not
> checked to see whether the inversion was due to bump_size.
The f_ridge() inversion is unrelated to bump_size.
For reference, these are the functions used for the normals:
  f_ridged_mf (x, y, z, 0.1, 3, 7, 0.7, 0.7, 2)
  f_ridge (x, y, z, 0.1, 1, 7, 0.7, 0.7, 0)
Note: The scene file was written for POV-Ray 3.6; the last argument to
f_ridge() should be changed to 2 for 3.7+ compatibility.
Date: 26 Jan 2022 11:30:00
Message: <web.61f175e9c1365d06ea8869266cde94f1@news.povray.org>
hi,
William F Pokorny <ano### [at] anonymousorg> wrote:
> On 1/25/22 08:39, William F Pokorny wrote:
> > I'll look at your idea today and see if I can make something work for povr.
> OK.
> I spent some time looking at testing whether some keyword is defined.
> It's a tangle.
how .. unexpected..  :-)
> The only thing I've come up with, which I think might work, would be for
> povr to re-use a function its currently eliminated in 'f_odd()'.
> My thinking is that povr - or any other non-official and substantially
> different - version of POV-Ray could return some unique double value
> given a particular set of inputs. We'd use maybe certain sets of inputs
> for various derivatives. The current inbuilt function would return what
> it returns. The povr branch or others would be hard coded to return some
> other value which would mean something like: This the povr branch and
> the version is, and it's Monday, or...
> Would using f_odd() in this way be useful or not? It's all I've got for
> options at the moment.
unsure.  a function return to test against would not be very different from
comparing string ids, and it sounds like it would work.  otoh, it feels like,
um, a crutch.  (sorry)  perhaps an effort ought to be made to get clipka
involved, to see how/when the parser gets taken forward from here.
regards, jr.
Date: 26 Jan 2022 11:35:00
Message: <web.61f17775c1365d06ea8869266cde94f1@news.povray.org>
hi,
"Kenneth" <kdw### [at] gmailcom> wrote:
> [running v3.8.0 beta 1 in Windows 10]
> It parses and renders OK for me as well.
yeah, my bad.  'povr's syntax is different, and I had not caught on.
> ... I have never actually used an explicit 'emission' for a sky_sphere;
> it's the common understanding that it is set to 1.0 behind-the-scenes
> as a default (so that the sky_sphere's colors are successfully
> used in radiosity, for example).
"common understanding"?!  :-)  apart from a simple scene I'm hoping to complete
in the next days, I have never used a sky_sphere, so thanks for the
"background".
regards, jr.
Date: 26 Jan 2022 19:37:23
Message: <61f1e943$1@news.povray.org>
Hmm.
Maybe this just a difference between the official POV-Ray functions and
mine, but in the current povr code for f_ridge() those arguments will
more or less return little because the first three to f_ridge are
basically arguments to POV-Ray's internal turbulence function (Noise).
Meaning those after x,y,z are lambda, octaves, omega. A workable result
for povr would be:
f_ridge(x, y, z, 2.5, 3, 0.5, -0.5, +0.05, 3, 1)
I added a last multiplier/scaling argument to the f_ridge* functions
povr because results often gets scaled and this is done faster internal
to the function than outside. At 1.0 no scaling happens.
Bill P.
Date: 27 Jan 2022 04:16:59
Message: <61f2630b$1@news.povray.org>
> um, a crutch.
I've been thinking about this.
Instead of using f_odd() to return additional patch/branch information,
I think it should instead return always a value f_odd() cannot. For
example, 99.0(a).
The 99 indicates the code contains a patch or is a significant branch of
its own. Further, that two additional parse time functions exist in:
patch_str(<n>) and patch_val(<n>)
With this approach we use f_odd() as a hook into all versions of POV-Ray
back through v3.5(c) to indicate the two patch_* keywords exist.
What each branch/patch provider does with those is up to them both to
implement and document to their users.
Allowing any number of strings and values would allow documenting
particular functionality and the version of that functionality ->
"amplify" 0.003.
Is this a better approach(b) than f_odd alone?
It's gets us away from any dependency POV-Ray's official development.
Aside: I had the thought too for a patch_keyword("sky_sphere"). Which
might return say "unchanged". Or "emission sub keyword is now amplify"
or "removed" or "new" or "substantially updated see povr documentation"
or... I'm thinking more about code which self documents to some minimal
degree.
Bill P.
(a) - It happens the return of f_odd (and its twin f_cushion) are
clamped to a -10 to 10 range.
(b) - With official POV-Ray there's been significant effort to maintain
near infinite backward capability so old scenes and tooling writing
POV-Ray SDL continue to work.
A place and value for this approach, but it doesn't come free. The
reality is a fair bit of the backward capability is bent if not broken
to what is documented. To the degree it's tested due old scene and
include files, it's probably workable.
It's much harder to write significant patches if you have to worry
yourself about maintaining infinite backward capability. My povr branch
supports only v3.8+. So as a patch_* return pair I might also have:
"Minimum POV-Ray version" 3.8
If v4.0 development resumes, there will be a point where I won't be able
to retrofit some v4.0 change / feature to povr and I'd then need maybe:
"The povr branch is aligned with POV-Ray version" 3.8
(c) - I'm only aware of patched versions back through v3.6.
Date: 27 Jan 2022 11:00:00
Message: <web.61f2c023c1365d06ea8869266cde94f1@news.povray.org>
hi,
> example, 99.0(a).
> "amplify" 0.003.
gut reaction[*] - yes, something along that line.  while compatibility is
important of course, I think that this mechanism is of value only from current
versions on.  not quite sure I really understand the detail, so I'd write eg:
#if (99 = f_odd(0,0,0,99))
  #if (!strcmp(patch_val("id"),"povr"))
#else
where/how does 'patch_str' get used?
from my admittedly limited vantage I see no downsides, other than that
'functions.inc' (presumably) would need to be sourced.
[*] also .. pleasing that a function with that exact name should get shouldered
with this odd job.  :-)
((real) minor nit, suggest 'fork', or perhaps even 'branch', rather than
'patch')
> degree.
a macro to return a 'dictionary{}' would be real nice.  could have keys for the
changed stuff ("amplify") as well as version/patch level, everything in one
place.  :-)
regards, jr.
Date: 27 Jan 2022 13:40:00
Message: <web.61f2e609c1365d061f9dae3025979125@news.povray.org>
"jr" <cre### [at] gmailcom> wrote:
> hi,
> > example, 99.0(a).
> place.  :-)
> regards, jr.
Aside, or perhaps in addition to, what can be done under the hood,
what if the versioning mechanism not only has internal functions, but checks for
the existence of "versions.inc" in the path?  Preferably this would be a
"wrapper" inc file that then looks for the most recent "versions_DateCode.inc"
to use...
That would allow all manner of code to be run based upon the values returned by
the internal function(s), either in addition to, or instead of the "default"
behaviour.
Also, the output for any given version could be easily updated by people in the
absence of any official developer presence / availability / activity.
Also, I would suggest a way to implement Semantic Versioning, so that all the
little changes that get made along the way can be documented.
Maybe a 9-digit number XXXYYYZZZ.
Just thinking about long-term expandability and making the capabilities
available NOW.
Date: 28 Jan 2022 05:25:57
Message: <61f3c4b5$1@news.povray.org>
On 1/27/22 10:54, jr wrote:
jr & Bald Eagle, Thanks both for the feedback and ideas.
>    #end
> #else
> #end
What I was thinking about was more like:
#declare povr     =  0;
#declare povr_ver = -1;
     #if (!strcmp(patch_str(0),"povr"))
         #declare povr = 1;
         #declare povr_ver = patch_val(0);
#else
The patch_str() and patch_val() would be paired by count. I am leaning
this way because the parser is set up for keywords to always be of one
type.
Having the pair makes it easy to set up a loop to pull more than one key
value pair aimed at creating, say, a table.
Using a count for access, I believe, will make it a little less likely
users will get the feature tangled up on string specification or
interpretation.
Though, nothing would stop any given branch developer from setting up to
pull values out of returned strings in the SDL - if that's the set up
they want.
> with this odd job.:-)
Indeed! :-)
Yes, including functions.inc is a bit clunky and it touches on the
parser performance issue I was trying to address somewhat with my
'munctions' (macro call defined functions) idea - a little work toward
which showed up in my last release.
True to some degree for any include, but when we pull in functions.inc
in particular we define upwards of one hundred symbols in a symbol
table. These can and do collide by hash value(a) which slows down
functions at RUN time as well as slowing general parsing at parse time.
We only include functions.inc to declare - create global symbol table
entries - for each inbuilt function name. For f_odd we could, and
probably should, use(b) just:
#declare f_odd = function { internal(43) }
ahead of the call to f_odd.
This selective declaration of inbuilt functions has always been
recommended against because the positional values in the internal
function table might change. True, but, they haven't actually changed in
a very, very long time - until povr really. There has always been a
performance reason to do the declares for only the functions in
functions.inc you use(c).
(a) - This especially true in official POV-Ray where the hashing
mechanism, though itself very fast, generates hash values heavily
weighted / bunched around the first token character. The povr branch
uses a C++ provided string hashing with very good hash value
distribution - even where strings are quite similar (Fn00,Fn01...). The
C++ method was slower at low optimizations and faster at -O2 and above
for the testing done at the time I changed over.
(b) In povr, I'm using entry 43 for f_elliptical_sphrswp() and I will
have to move f_elliptical_sphrswp() elsewhere.
(c) Though, with hash based symbol/token tables with linked lists
hanging off each node, whether you see any a performance gain depends on
the particular symbol table construction. Having fewer symbols/tokens
will never hurt performance, but it can help quite a lot - depending on
'stuff.'
> 'patch')
Good idea and I guess in the git sense, fork, the better choice because
in the usual practice there will often be branch(es) off major forks for
particular features of the fork. Any branches we should probably handle
as additional _str and _val entries.
>> degree.
> place.:-)
Yes, good idea. Putting more in include(s) that creates a dictionary for
such information would be better / easier. The include could itself
could test the forked version / branch of POV-Ray matches its internal
information. Hmm, we could create csv file(s) and use table.inc though
guess I'm not sure if more or less work/value over just creating the
dictionary straight up?
On automatically including includes, I lean against it. How external
files get searched for and found is today problematic. I've been trying
to simplify the povr fork directory search mechanism. Still a long way
to go there and might have some current changes wrong. Official
POV-Ray's matching attempts are very aggressive in assuming various
directories, file suffixes and such. I think this causes as much
confusion as not in the end.
On versioning... Following some conventions there a good idea, but not
sure it's something to force as part of any f_odd, fork_*() additions.
For someone actually implementing a one off patch, it's meaningless. I
have to say too, as a long time user of such versioned tools, I've found
them not all that reliable - except in maybe the ZZZ minor update
category (small updates to still compile essentially static releases).
Some systems extend the versioning to components / modules / features of
the overall 'user tool' - some allowing the user to pick the version of
behavior for each module. This 'idea' somewhat attractive given the more
aggressive changes I'm pursuing with povr.
For example, I substantially re-wrote 'fog' a year or more ago. One of
the changes was making ground fog work more reliably - it basically,
doesn't function for most scenes in official releases. Last fall I ran
across an old scene that depended upon the particulars of the previous
method to do a sort of fog fade at a large distance. It was a use I
didn't foresee for 'ground fog', so I restored the old method as an
additional option. There are now two versions of my povr fog code.
Maintaining this per feature versioning is something I think works
better where a coder is working on say only a few of modules for a
larger project/tool. I don't have the bandwidth to support anything
complicated like maintaining multiple user select-able versions, but I
might be able to increment some version number per keyword to at least
indicate something changed related to the keyword/option.
I'll think more about what to do versioning wise, what I might be able
to maintain...
Bill P.
Date: 28 Jan 2022 06:00:00
Message: <web.61f3cc59c1365d06ea8869266cde94f1@news.povray.org>
hi,
> > > example, 99.0(a).
> > place.  :-)
> to use...
nice.  made me think there isn't a 'version.inc' yet, so, perhaps, one could be
added to all POV-Rays and variants[*].  standard .inc, only providing a macro or
variable that's true/false depending on whether official or not, and a way to
get info about which executable.  a variant like 'povr' or 'hgpovray' could then
simply add an '#include' in that file to load the specific stuff.  (_if only_
more/most of the code was in 'C'.  anyway :-))
[*] from 3.9 on, perhaps :-)
regards, jr.
Date: 28 Jan 2022 08:15:00
Message: <web.61f3ebacc1365d06ea8869266cde94f1@news.povray.org>
hi,
> #declare povr     =  0;
>          #declare povr = 1;
>      #end
> #else
> #end
> type.
ok, key/value pairs.  thanks for code example (I find "snippets" helpful).  re
my earlier post, that testing and the "cloaking" of 'internal(43)' hidden,
perhaps, behind a "friendlier" bool macro/variable.
> Indeed! :-)
what was its original purpose?  reading that the argument is a "field strength"
made me wonder whether it's anything to do with 'blob's.
that could/would be the content of a 'version.inc'.
> > place.:-)
'table.inc'?  :-)  guess you were thinking 'filed.inc'?  what do you think of a
'version.inc' which, for variants like 'povr', would simply pull in another
include if/where required?
v much agree.
> to maintain...
fwiw, I do not think that it has to be very .. fine-grained, necessarily.  as
long as a user me can establish, in-scene, that the executable supports this
feature or another as easy to use (in conditionals) test(s).
regards, jr.
