POV-Ray : Newsgroups : povray.binaries.images : A quick povr branch micro normal image. Server Time
22 Mar 2026 21:28:27 EDT (-0400)
  A quick povr branch micro normal image. (Message 38 to 47 of 97)
Subject: Re: A quick povr branch micro normal image.
Date: 28 Jan 2022 05:25:57
Message: <61f3c4b5$1@news.povray.org>
On 1/27/22 10:54, jr wrote:
jr & Bald Eagle, Thanks both for the feedback and ideas.
> gut reaction[*] - yes, something along that line.  while compatibility is
> important of course, I think that this mechanism is of value only from current
> versions on.  not quite sure I really understand the detail, so I'd write eg:
> #if (99 = f_odd(0,0,0,99))
>    #if (!strcmp(patch_val("id"),"povr"))
>    #end
> #else
> #end
> where/how does 'patch_str' get used?
What I was thinking about was more like:
#declare povr     =  0;
#declare povr_ver = -1;
     #if (!strcmp(patch_str(0),"povr"))
         #declare povr = 1;
         #declare povr_ver = patch_val(0);
#else
The patch_str() and patch_val() would be paired by count. I am leaning
this way because the parser is set up for keywords to always be of one
type.
Having the pair makes it easy to set up a loop to pull more than one key
value pair aimed at creating, say, a table.
Using a count for access, I believe, will make it a little less likely
users will get the feature tangled up on string specification or
interpretation.
Though, nothing would stop any given branch developer from setting up to
pull values out of returned strings in the SDL - if that's the set up
they want.
> from my admittedly limited vantage I see no downsides, other than that
> 'functions.inc' (presumably) would need to be sourced.
> [*] also .. pleasing that a function with that exact name should get shouldered
> with this odd job.:-)
Indeed! :-)
Yes, including functions.inc is a bit clunky and it touches on the
parser performance issue I was trying to address somewhat with my
'munctions' (macro call defined functions) idea - a little work toward
which showed up in my last release.
True to some degree for any include, but when we pull in functions.inc
in particular we define upwards of one hundred symbols in a symbol
table. These can and do collide by hash value(a) which slows down
functions at RUN time as well as slowing general parsing at parse time.
We only include functions.inc to declare - create global symbol table
entries - for each inbuilt function name. For f_odd we could, and
probably should, use(b) just:
#declare f_odd = function { internal(43) }
ahead of the call to f_odd.
This selective declaration of inbuilt functions has always been
recommended against because the positional values in the internal
function table might change. True, but, they haven't actually changed in
a very, very long time - until povr really. There has always been a
performance reason to do the declares for only the functions in
functions.inc you use(c).
(a) - This especially true in official POV-Ray where the hashing
mechanism, though itself very fast, generates hash values heavily
weighted / bunched around the first token character. The povr branch
uses a C++ provided string hashing with very good hash value
distribution - even where strings are quite similar (Fn00,Fn01...). The
C++ method was slower at low optimizations and faster at -O2 and above
for the testing done at the time I changed over.
(b) In povr, I'm using entry 43 for f_elliptical_sphrswp() and I will
have to move f_elliptical_sphrswp() elsewhere.
(c) Though, with hash based symbol/token tables with linked lists
hanging off each node, whether you see any a performance gain depends on
the particular symbol table construction. Having fewer symbols/tokens
will never hurt performance, but it can help quite a lot - depending on
'stuff.'
> ((real) minor nit, suggest 'fork', or perhaps even 'branch', rather than
> 'patch')
Good idea and I guess in the git sense, fork, the better choice because
in the usual practice there will often be branch(es) off major forks for
particular features of the fork. Any branches we should probably handle
as additional _str and _val entries.
>> Aside: I had the thought too for a patch_keyword("sky_sphere"). Which
>> might return say "unchanged". Or "emission sub keyword is now amplify"
>> or "removed" or "new" or "substantially updated see povr documentation"
>> or... I'm thinking more about code which self documents to some minimal
>> degree.
> a macro to return a 'dictionary{}' would be real nice.  could have keys for the
> changed stuff ("amplify") as well as version/patch level, everything in one
> place.:-)
Yes, good idea. Putting more in include(s) that creates a dictionary for
such information would be better / easier. The include could itself
could test the forked version / branch of POV-Ray matches its internal
information. Hmm, we could create csv file(s) and use table.inc though
guess I'm not sure if more or less work/value over just creating the
dictionary straight up?
On automatically including includes, I lean against it. How external
files get searched for and found is today problematic. I've been trying
to simplify the povr fork directory search mechanism. Still a long way
to go there and might have some current changes wrong. Official
POV-Ray's matching attempts are very aggressive in assuming various
directories, file suffixes and such. I think this causes as much
confusion as not in the end.
On versioning... Following some conventions there a good idea, but not
sure it's something to force as part of any f_odd, fork_*() additions.
For someone actually implementing a one off patch, it's meaningless. I
have to say too, as a long time user of such versioned tools, I've found
them not all that reliable - except in maybe the ZZZ minor update
category (small updates to still compile essentially static releases).
Some systems extend the versioning to components / modules / features of
the overall 'user tool' - some allowing the user to pick the version of
behavior for each module. This 'idea' somewhat attractive given the more
aggressive changes I'm pursuing with povr.
For example, I substantially re-wrote 'fog' a year or more ago. One of
the changes was making ground fog work more reliably - it basically,
doesn't function for most scenes in official releases. Last fall I ran
across an old scene that depended upon the particulars of the previous
method to do a sort of fog fade at a large distance. It was a use I
didn't foresee for 'ground fog', so I restored the old method as an
additional option. There are now two versions of my povr fog code.
Maintaining this per feature versioning is something I think works
better where a coder is working on say only a few of modules for a
larger project/tool. I don't have the bandwidth to support anything
complicated like maintaining multiple user select-able versions, but I
might be able to increment some version number per keyword to at least
indicate something changed related to the keyword/option.
I'll think more about what to do versioning wise, what I might be able
to maintain...
Bill P.
Date: 28 Jan 2022 06:00:00
Message: <web.61f3cc59c1365d06ea8869266cde94f1@news.povray.org>
hi,
> "jr" <cre### [at] gmailcom> wrote:
> > William F Pokorny <ano### [at] anonymousorg> wrote:
> > > Instead of using f_odd() to return additional patch/branch information,
> > > I think it should instead return always a value f_odd() cannot. For
> > > example, 99.0(a).
> > place.  :-)
> Aside, or perhaps in addition to, what can be done under the hood,
> what if the versioning mechanism not only has internal functions, but checks for
> the existence of "versions.inc" in the path?  Preferably this would be a
> "wrapper" inc file that then looks for the most recent "versions_DateCode.inc"
> to use...
nice.  made me think there isn't a 'version.inc' yet, so, perhaps, one could be
added to all POV-Rays and variants[*].  standard .inc, only providing a macro or
variable that's true/false depending on whether official or not, and a way to
get info about which executable.  a variant like 'povr' or 'hgpovray' could then
simply add an '#include' in that file to load the specific stuff.  (_if only_
more/most of the code was in 'C'.  anyway :-))
[*] from 3.9 on, perhaps :-)
regards, jr.
Date: 28 Jan 2022 08:15:00
Message: <web.61f3ebacc1365d06ea8869266cde94f1@news.povray.org>
hi,
> #declare povr     =  0;
>          #declare povr = 1;
>      #end
> #else
> #end
> type.
ok, key/value pairs.  thanks for code example (I find "snippets" helpful).  re
my earlier post, that testing and the "cloaking" of 'internal(43)' hidden,
perhaps, behind a "friendlier" bool macro/variable.
> Indeed! :-)
what was its original purpose?  reading that the argument is a "field strength"
made me wonder whether it's anything to do with 'blob's.
that could/would be the content of a 'version.inc'.
> > place.:-)
'table.inc'?  :-)  guess you were thinking 'filed.inc'?  what do you think of a
'version.inc' which, for variants like 'povr', would simply pull in another
include if/where required?
v much agree.
> to maintain...
fwiw, I do not think that it has to be very .. fine-grained, necessarily.  as
long as a user me can establish, in-scene, that the executable supports this
feature or another as easy to use (in conditionals) test(s).
regards, jr.
Date: 28 Jan 2022 12:55:00
Message: <web.61f42cf8c1365d06ea8869266cde94f1@news.povray.org>
have attached a mock-up example of an inc for POV-Ray proper.  the tag would
just change to 'povr', and either inline or via an include have the specific
stuff, and I think, the 'setidtypes.inc' content too.
forgot.  dictionary, "straight up".
regards, jr.
Download 'eg.zip' (1 KB)
Date: 28 Jan 2022 16:00:10
Message: <61f4595a$1@news.povray.org>
On 1/26/22 09:01, William F Pokorny wrote:
> ...So what's going on.
Well, after digging for a chunk of day, the non-fuzzy result comes from
a "bug fix" made back in 1998 by Nathan Kopp & CEY in the
Trace::ComputeReflection() function of trace.cpp.
Basically after the calculation of the reflected ray direction using the
perturbed normal, they added second dot test of that perturbed reflected
ray with the raw surface normal.
If the perturbed reflected ray was heading in a direction opposite the
the raw surface normal it triggers some code which does one of two kinds
of correction...
Where the perturbed ray direction is opposite the perturbed normal
direction it simply drops back to reflection rays based on the raw
normal.  This is where we suddenly get non-normal-perturbed
reflections...
Otherwise, it pulls the perturbed reflected ray more into alignment with
the raw surface normal by an amount based upon a negative weighting
factor and the magnitude of the dot product of the perturb ray direction
with the raw normal to some degree being stronger up to a cut off set by
the initial test with the perturbed normal(a).
After all the fix up the reflected ray direction is normalized - which
is the expected ray direction state.
Ah, what to do... Thoughts anyone? I'm going to have to think about this.
I don't like that we are basically ignoring perturbed results to some
degree or another - for reflections - beyond certain normal
perturbations point.
With very rough surfaces - think pile of stones - a reasonable
expectation would be to get some degree of all internal reflections. A
darkening due reflections bouncing until they die off inside the surface
structure. This feels like a more correct result to me.
Guess I need to check whether this bug fix is getting done with
refraction too...
Bill P.
(a) - Yep, this second fix/pull toward the raw surface normal might not
always set in a non-opposing direction with the raw surface normal.
(a) Yes, I think this is going to also create some extra
fuzz/inaccuracies for fresnel effects at glancing angles at near
tangents to a surface. There, with certain rougher surfaces, we should
see around the complete 'larger-overall' tangent some.
Date: 28 Jan 2022 17:05:00
Message: <web.61f467c1c1365d061f9dae3025979125@news.povray.org>
Whoa - interesting result of your day of code forensics!
I would tend to start from scratch, and just cancel all of that extra stuff and
see what happens.   Maybe it might explain why they decided to do all of that.
I tend to learn how to approach these types of things by going out and seeing
how various people address them outside of POV-Ray - in Unity, ShaderToy,
academic papers, and other linear algebra / computer graphics / optics / math
resources like websites and video hosting sites.
https://www.youtube.com/watch?v=EBrAdahFtuo
I would try to make a diagram, or write a scene where you have actual objects,
and shoot rays every so often, and show the incoming ray, and then whatever
reflected rays that get generated.   Maybe iterate a color change around the HSV
wheel or something to track how far along the process you are.
Seeing the process and results usually gives far more intuitive understanding of
what the problem is and what the likely solution is, than scribbling equations
and endlessly editing lines of code.
That's my take, anyway.
Date: 29 Jan 2022 05:10:00
Message: <web.61f5112ec1365d064cef624e6e066e29@news.povray.org>
[William P wrote:]
> With povr I've been using the following sort of scene set up to look at
> normals and inversion...
> #version unofficial 3.8; // povr
> global_settings { assumed_gamma 1 }
> #declare VarOrthoMult = ...
> [...snip]
[JR wrote:]
[running v3.8.0 beta 1 in Windows]
I did not even know that there is an 'unofficial' keyword in POV-ray syntax; it
is not mentioned in 3.8's in-built documentation (at least not in the index of
keywords there). Interesting!
So, running JR's very neat little test scene (with his .inc file) like this:
#version 3.8; // no 'unofficial' keyword
global_settings {assumed_gamma 1}
box {0,1}
#include "version_test.inc"
#if (official_program())
#debug concat("prog is an official POV-Ray.\n")
#else
#debug concat("not an official POV-Ray.\n")
#debug concat("ident: \"",idtag_program,"\".\n")
...... it parses and render fine, with the appropriate message.
But if I run it like this:
...... the scene fails outright, with the message
"line 1: Parse error: This scene was created for an unofficial version and
cannot work as-is with this official version."
I'm very naive about this stuff-- but is it to be expected that this
'unofficial' file should also run OK, and even in my Windows version of 3.8
(i.e., a non-"povr" version?) If not, then... never mind ;-) My apologies if I'm
simply "muddying the waters" of this discussion, but I thought I should mention
the parse error.
Date: 29 Jan 2022 07:50:21
Message: <61f5380d$1@news.povray.org>
A look at the basics is good advice.
I did get to commenting all the fix bugfix code and got results more in
line with what I originally expected. As of this morning I'm leaning
toward bringing out various treatments as user controllable variations.
  I can see physical reasons for a few depending upon the actual surface
and the non-perturbed rays. Given that glassy result is probably useful
would likely keep it as perhaps an expanded option. Suppose keeping the
current behavior as an option a good idea too.
Likely the povr default would be no bugfix / adjustments at all as I
think it the result most would expect. I also like the look of it over
the current for usual use 'micro' micro results.
This morning been looking at the refracted side of things.
A simplified view:
Where the perturbed normal is running along with (inverted with respect
to the incoming ray) the perturbed normal is inverted and assigned a
local normal for color calculations.
Where the refracted ray ends in internal reflection the perturbed normal
is used and the compute reflection bugfix gets used as with any other
reflection.
Where the refracted ray continues creating a new refracted ray the,
always pointing back toward the ray, normals - the potentially inverted
local normals - get used
So! The refraction behavior isn't really aligned with reflection
behavior at any given surface intersection where the perturbed normals
point in opposition to the refracted/reflected rays. In the case of
reflections sometimes if in enough conflict with the raw normal.
A realization for me is, while it's possible in some cases to prevent
the inversion of perturbed normals with respect to the major surface
direction with some patterns, it is not possible to do in general
because there are really two kinds of perturbed normal inversion. One
with respect to the surface itself, and another with respect to the rays
involved.
That said, a common to all normal patterns, perturbed normal inversion
option for where the perturbed normal points away from the raw normal
might be of use... This would immediately get us to a state where there
are only the inversions with respect to involved rays issues.
I guess a take away here for POV-Ray proper is where you are using
reflection or refraction, keep the normal bump size smallish (<0.5).
Even so, where rays nearly tangent to the surface, ANY normal
perturbations will invert somewhat at those locations with respect to
incoming rays.
I suppose what can be said generally is the moment we start to fake
surfaces / shapes to some degree or another, the reflections and
refraction treatments necessarily get somewhat heuristic.
Bill P.
Date: 29 Jan 2022 08:14:31
Message: <61f53db7$1@news.povray.org>
Thanks! Stopping with this error is what I expected for "official"
windows versions. This means if we want to write SDL supporting both
normal POV-Ray releases and forks for windows users, we'd need to strip
"unofficial" from #version.
Thanks jr, for the initial versions.inc template. Yes, such an include
could be provided with code. However, we'd need to be careful about
'declaring' any version of POV-Ray to be an official one. Today ONLY the
pre-compiled windows releases are official.
Hmm, suppose we could extend this code to optionally end with an #error
if the desired hook or fork is not found for SDL written specifically
for a particular fork.
 > what was (f_odd's) original purpose?  reading that the argument is
 > a "field strength" made me wonder whether it's anything to do
 > with 'blob's.
I don't know, I think it was likely some unfinished effort where some
initial code got copied. Code wise it was always a match for f_cushion()
and so pointless as shipped.
Bill P.
Date: 29 Jan 2022 10:55:00
Message: <web.61f55e65c1365d06ea8869266cde94f1@news.povray.org>
hi,
made me think what is John/Jane User's perspective?  if they only ever use
official builds on MS Windows, then "the problems" do not arise.  if however
they write scenes which will get parsed by POV-Ray proper or a variant, then
they can source the include.  I think one can simply "turn the logic around"[*]
without harm, ie name the macro 'unofficial_program' + reverse its result.  then
we could write an even simpler conditional:
  #if (unofficial_program())
[*] assuming POV-Ray proper will continue to return clamped values + everybody
else switches to '99'.
re error, sorry snipped too much.  just to confirm, unlike on Windows, the
self-compiled POV-Rays all accept "unofficial" w/out a murmur.  while I can see
the logic, it feels wrong - now.  we're 2nd class users anyway, with RTR not
working :-(.
on the point, if I test in a scene for '6e4ed6c2' (:-)) but the executable is
older/newer/not compatible and won't do, then yes, I think it has to be an
error.
>  > with 'blob's.
I found _that_ definition (and description in the docs) equally .. illuminating.
 </grin>
regards, jr.
