POV-Ray : Newsgroups : povray.binaries.images : An experiment in monochrome Server Time
10 Jun 2024 14:19:43 EDT (-0400)
  An experiment in monochrome (Message 11 to 20 of 25)
<<< Previous 10 Messages Goto Latest 10 Messages Next 5 Messages >>>
Subject: Re: An experiment in monochrome
Date: 10 Jun 2021 08:28:04
Message: <60c20554@news.povray.org>
On 10/06/2021 2:25 am, Bald Eagle wrote:
> Hi Matt,
>>> "m@b" <sai### [at] googlemailcom> wrote:
>>>> Trying to emulate mechanical shading.
> This is clever!  I like it.  :)
Thanks.
................ snip
>> (I am not sure where this function came from - I used it many years ago
>> in another project.)
> I see in your posted code that you comment that "map_type 0" is required - but
> the docs say that this is the default planar mapping, so maybe it's not actually
> a requirement?
You are right - it is the default, perhaps it was a requirement 20 years
ago when I last played with POV-Ray
> I had this bouncing around in my head today,  and maybe it would be faster to
> make some pigment patterns and use a pigment map instead of sphere primitives.
But I would need some primitives to put the pattern on?
http://news.povray.org/povray.binaries.images/thread/%3Cweb.5a7774f01a0c102c5cafe28e0%40news.povray.org%3E/
> You could even just make a single linear pattern and the others would just be
> rotations or scales of it. (have the line thickness be dependent on the color
> channel value)
> The other thing I was thinking was that you might also be able to get an outline
> or shape-following effect if you calculated not only the value of any given
> pixel, but the gradient of the function there as well.  Then you could make the
> lines perpendicular to the gradient / tangent to the curve.
> I know TOK wrote the gradient functions in the distributed include files, and
> there are edge-finding algorithms that give you the gradient of the image as a
> bonus.
Hmm - I need to think about these things. Interesting suggestions.
> This looks like something super fun to play with, with a lot of potential for
> future development!  Good work  :)
Date: 10 Jun 2021 08:31:42
Message: <60c2062e@news.povray.org>
> m@
An example with cylinders instead of spheres, I like the maze effect at
the boundaries.
And a first attempt at edge detection.
m@
Download 'test cylinders 01.png' (128 KB) Download 'image cross hatch 03.png' (181 KB)
Preview of image 'test cylinders 01.png'
Preview of image 'image cross hatch 03.png'
Date: 10 Jun 2021 14:30:00
Message: <web.60c2599b23b82ed51f9dae3025979125@news.povray.org>
Of course.  A thin box or the union of 2 triangles works well.  A plane if you
just want to have the largest possible palette.
But the idea is that you have a lot of stuff going on after you "extract" the
colors.  Rather than do that, you use the color values directly to select a
pigment, by using a pigment_map.
I am curious about
#declare GreyTest = 0.001 + abs(TestK(X,Y,0) -
abs((TestR(X,Y,0) + TestG(X,Y,0) - TestB(X,Y,0))));
What is the underlying logic/reasoning behind this "greyness test"?
> > bonus.
https://www.youtube.com/watch?v=uihBwtPIBxM
skip to 3:30 if you want.
Date: 10 Jun 2021 14:40:00
Message: <web.60c25b8c23b82ed51f9dae3025979125@news.povray.org>
"Tor Olav Kristensen" <tor### [at] TOBEREMOVEDgmailcom> wrote:
> Hi Bill
> Please note that most of the credit for the Vector analysis macros should go to
> Christoph Hormann, which did the heavy lifting. I just suggested some
> corrections.
So noted!  He did an excellent job, especially that clever bit about employing
f_r - which took me a bit of time to wrap my head around.
http://www.povray.org/documentation/view/3.6.1/448/
f_r(x,y,z) = sqrt( x*x + y*y + z*z )
When used alone, the "R" function gives a surface that consists of all the
points that are a specific distance (threshold value) from the origin, i.e. a
sphere.
> Btw.:
> I agree with you; it may be that experimenting with pigment maps will be
> rewarding here.
Indeed.  I think he could get some interesting half-tone effects as well.
rgbf would look great if unmodified spheres of all 3 colors were used.
There's also the potential for using different shapes - boxes, triangles,
hexagons, etc.  I'm also thinking that using cones would give a Voronoi effect.
Date: 10 Jun 2021 17:55:00
Message: <web.60c2896123b82ed51f9dae3025979125@news.povray.org>
I just did this one because it was quick.
Download 'monochrome_be.png' (567 KB)
Preview of image 'monochrome_be.png'
Date: 10 Jun 2021 18:00:00
Message: <web.60c28a6b23b82ed51f9dae3025979125@news.povray.org>
=?UTF-8?Q?J=c3=b6rg_=22Yadgar=22_Bleimann?= <yaz### [at] gmxde> wrote:
> Yadgar
I really just have to say that if you got some dark sunglasses and a leather
biker vest, you could totally pull off that "bouncer at a biker bar" look.
:D
Date: 10 Jun 2021 20:40:00
Message: <web.60c2afe723b82ed58e52cc8789db30a9@news.povray.org>
They make a nice texture that reminds me of mashed paper.
Tor Olav
http://subcube.com
https://github.com/t-o-k
Message: <web.60c2b06d23b82ed51f9dae3025979125@news.povray.org>
This is a multi-part message in MIME format.
Download 'monochrome_be.png' (615 KB)
Date: 11 Jun 2021 06:16:35
Message: <60c33803$1@news.povray.org>
On 11/06/2021 2:27 am, Bald Eagle wrote:
> I am curious about
I wish to represent 4 colours - R, G, B and Grey.
The 0.001 is now redundant, I put it in to prevent a divide by zero
error in a previous version.
TestK(X,Y,0) returns the mean value of R, G, B. (1)
R+G-B will also return the mean if R, G and B are all the same, i.e.
colour is Grey. (Black and White are just shades of Grey :-))  (2)
So the GreyTest (1)-(2) returns zero if R, G and B are equal and a small
value if they are close.
BUT --------------------------------------------------------
You got me thinking, are there any cases where the test returns zero but
R, G, B are not equal?
Answer - yes, the test sometimes falls down when the 3 numbers are
equally spaced. e.g  0.1, 0.2, 0.3    or 0.3, 0.6, 0.9
I was over thinking, maybe this will work:
#declare GreyTest = abs(TestR(X,Y,0)-TestG(X,Y,0)) +
abs(TestR(X,Y,0)-TestB(X,Y,0)) + abs(TestB(X,Y,0)-TestG(X,Y,0));
m@
Date: 11 Jun 2021 12:12:32
Message: <60c38b70$1@news.povray.org>
Hi(gh)!
>> Yadgar
Yes, and I'm about as heavyweight as the typical biker bar bouncer - but
unfortunately, it's more fat than muscle... but nevertheless, I prefer
muscle-powered cycling over motorbiking!
Now playing: Nobody Home (Pink Floyd)
